loyale cooling question
I have a 92 loyale and It always runs "cool." It takes forever to warm up and when it does the temp guage only goes up about 1/4 of the way. Is this normal?
I know that the cooler a car runs the better(to a point) but I dont like how it takes forever to warm up. Any ideas? oh, and the car has a newer radiator(1 year old) and no a/c fan.
Thanks
Jon
the thermostat could be stuck open.
If you're trying to get ready for winter, make sure that you have a 190 degree thermostat in your car. Last year, I tried going through winter with a 180 degree thermostat in my '88, and it never really seemed to warm up at all. With a 190 degree thermostat, it was much better.
I agree with GLCraigGT about the stuck open thermostat. Since it stays open all the time, the coolant never gets a chance to heat up as it should. It will take the coolant a considerable time to warm up and still never reach optimum temperature. Replacing the thermostat will fix this problem. I would use a OEM unit and be sure to put in the correct side up.
Yes, thermostat is the problem. When I swapped radiators I put in the 195 degree thermo, it was nice in the summer, but never let my car warm up in the winter. So I switched back to the 180 degree thermo. Warms up perfectly again. Both are available for that model so make sure you get the right one.
  • 1 month later...
I finally got around to getting a new thermostat and it still is running "cold" I tersted the old thermostat and it opens in hot water and closes when I take it out. What else should I check?
you need to check the accuracy of your gauge. how does the air from the heater feel?
normaly it seems subes warm up rather quick.
I also have a 92 loyale and and i just put a (new to me) but otherwise use radiator in my car and it also runs pretty cool but about 1/4 up on the gauge and it takes about ten minutes to warm up. Best of luck.
Mike
my car used to alway take forever to warm up.[when it was a spfi]
if you're worried about heating up your car on cold winter mornings, maybe invest in a block heater
Its warm but not "hot" like in my other cars. And today when driving it to school(1 hour away in city/highway driving) it was barely above the the C mark and there was very little warm air. The radiator gets warm on the inlet side but it ice cold on the outlet side. Im confused :confused: I was so hopeing that the t-stat would fix everything.
one make shure any time you put a t-stat in make shure its subaru oem from the dealer along with the nice rubber and metal gasket that that are subaru only items, imho, anyway.
i would get another t-stat and see if it makes a differnce its possible that you got a bum new t-stat. ...........
My '92 Loyale also "stays" very "cool" with the needle about an 1/8 inch above the C even after driving the car on the highway. My first thought was that a previous owner had removed the thermostat...
Ben
