more efi madness(she runs, and drives!)
i keep thinkin i did it, then it wont do it again...
er27 into a carbureted car. i have spark and fuel, if i try and start it with the pump hooked up, it gets too much fuel and floods. if i unplug the pump, it bleeds off the pressure with a few cranks of the engine, then runs for about 5 seconds, then dies.
when it runs it only goes up to 10 lbs of vac, and im lookin for around 20 at least. so that makes me think my fpr isnt bleeding off enough pressure, because of a giant vac leak. well, the giant vac leak is the idle air controll valve, or whatever. but it wont run without it...
anyone think that disty timing would make your car have less vac at idle than it should?
ug help =/
have you actually checked fuel pressure?that would be really helpfull.
return line pluged?
yes timing will effect vacume. you can actually set timing by watching a vacume gauge.
well, i dont have a brass t and a guage that goes up to 90lbs so no, i havent checked my fuel pressure. i have gone as far as sticking the return line into a bucket to make sure its not the return line. also i pulled a pump off a runing car, and tried it.
i gotta mess with the timing again i suppose.
i marked the disty when i pulled it out, but i think i bumped the engine while it was out. i know im not 180 out, and thats what matters =/
thanks will report back, im so close.
whoohoo, sounds like a drag car, just got her up to temp, and drove around the block. my vac guage is reading around 25+at idle =].
one tooth off on the disty does crazy stuff.
thanks again :banana:
YEEHAW
Can't wait to come over and ride in it.... mabye drive it? :brow: Too bad I'm stuck at work late redoing some crap becuase someone else messed up.... :rolleyes:
Been a while coming but I knew you would do it. :drunk:
=] tom, its easy as pie, all you need to do is hook up the red wire to constant power, the black and white, and the white and red go to the switched power(i used the old +wire on the coil, and wire up the fuel pump just like the diagram. run a wire to the starter, then hook up the tach, oil pressure guage, and the water temp guage, then rev her up! =]
i just went for a more extensive test drive with no hood, its hard to not spin the tires... well tire, its open diff rear wheel drive! =] its time to drive her to texas and dyno tune the hell out of her. when i tell peepl its my dream car they look at me funny. when i open the hood they wont anymore!@#$#$@!!!!
wrx? mines bigger!:drunk: celebration time
any chance getting some track numbers? I'd love to see a 1/4 mile time
Wow. I cant believe you pulled it off. Thats awesome!!! Dyno for sure, track times too :)
Are you using the EA81 tranny?
-Brian
Just added your wiring details to my notes. Thanks for the info... :) :)
You're using the Stock Dash Tach? It reads the 6-cylinder RPMs correctly?
Would love to see this Hatch in person one of these days.........
On another note: They cut the Mon-Fri overtime down, and cancelled week-end OT for a while. (Darn, only 67.5 hours in this week) Maybe, I'll have time to get caught up on household chores, and have time to wrench on the '82 now. One can only hope!!!!
ya, im heading to texas late january, where my cousin runs alamo autosports, and ennis race way is right down the road, so numbers for sure! @sap.
That's awesome!!
And to think, I was told by a mechanic that an ER27 wouldn't fit in my EA82 wagon! Way to go.
Way to go Arch!!! :drunk:
That really shows that you can do anything if you put enough effort forth. That thing must really be able to haul just barely getting on it.
Place your bets!
*Predictions*
I predict mid 15 second 1/4 mile runs at approximately 84-86mph. [On Excellent runs]
If you like burning rubber or have problems with tire slippage, I predict low-mid 16 second runs at approximately 82-84mph. There you have it. ;)
yar, i agree, shes deffinately not gonna be super duper fast, just fast for a subaru.
i cant wait to see how much of the 150hp im gonna get to the ground. 100+ at the wheels would be nice =].
its a 4 wheel dyno, so i could stick my front axles in too.
Its stillpossible to run it 4wd? lower those 1/4 mi. times please. If you can find a Lsd, that car will be a nasty 1/4 miler.
i got a welder, i'll prolly weld the rear end before i install a lsd. they are the rarest items in the subaru universe.
