April 15, 200620 yr I cam across this Manual online its the manual that Subaru sent out the rally prep the RX. The place where i found this is no longer up so I made a PDF for easy downloading and viewing. http://level4racing.com/rxModManual.pdf
April 16, 200620 yr AWESOME!! it starts out prety cool listing modifications but then the cool parts with #'s (not liek they're available:( ) sport ecu, suspension& mounts, strut tower bar, body reinforcement, under gaurd. all i can say is :slobber: :slobber:
April 16, 200620 yr I've been working my way down that list.. have a few of the engine mods done (ones that don't require new parts). if those are Subaru part numbers, has anyone tried to track down any parts? also, from what ive heard there is a few more pages floating around somewhere. no luck finding them though...
April 16, 200620 yr yea good info. Gives me a bunch of ideas for my 88 RX coupe sitting at the shop with the engine pulled with blown HG's. I got all the parts, cept for a new oil pan (old mechanic musta dropped this engine)
April 16, 200620 yr on the pages concerning the turbo mods, there is a section on removing the boost selenoid (that thing inline from the turbo to wastegate on 87 and newer models). does anyone have an idea why you would need a turbo from a 85/86 model to replace 87 and newer turbo's? is the wastegate different? also.. anyone done the wastegate mod with the adjustable turnbuckle? rllywgn
April 16, 200620 yr on the pages concerning the turbo mods, there is a section on removing the boost selenoid (that thing inline from the turbo to wastegate on 87 and newer models). does anyone have an idea why you would need a turbo from a 85/86 model to replace 87 and newer turbo's? is the wastegate different? also.. anyone done the wastegate mod with the adjustable turnbuckle? rllywgn You must have mis-read.87 turbos don`t get replaced w/86s. All turbos get replaced w/the sport model. No difference between 86-7 wastegate acuators but the rally mod uses a different one.
April 18, 200619 yr wow thats some cool stuff. I have done a good deal of those mods already or at least have dreamed of them. If someone finds that those parts are available still I will flip out. That would be too cool.
April 18, 200619 yr on pages 23 and 24 it states some mods to the intake I understand the removal of the so called "snorkel" but what is this part about the intake boot mod? I know wich part they mean, the protruding piece of plastic, but what to do with it? who knows?
April 18, 200619 yr Author I think there just talking about fliping it around and cutting the excess off.
April 18, 200619 yr Author Did anyone do the mod on page 26 or 16 of the PDF? I want to do this but think I might need to do some other mods first and replace my rear o2 sensor.
April 19, 200619 yr yeah intake mod on the "cup".. flip it around, cut it so its about 3/4 inch tall and remount it with the "cup" base inward.. smooths out the intake flow. this works well with removing the intake box inside the passenger fender. also, and not for the squeamish... cut the bottom of the air box out, cheap open air in a sense, add the k&n filter 33-2010 for best results rllywgn
April 20, 200619 yr some one should get this parts list to subygal, she could tell us if the parts are available and how to find em.
April 23, 200619 yr some one should get this parts list to subygal, she could tell us if the parts are available and how to find em. good luck with that.
April 24, 200619 yr ya, but I've already tried, and its subiegal. I do have a plan though. just have to get the connections down under.
April 24, 200619 yr ya, but I've already tried, and its subiegal. I do have a plan though. just have to get the connections down under. definatly let me know how that goes.
April 24, 200619 yr JWX - I got a buddy that lives in Austrailia. Let me know what we need from down there and I will have him try to track it down
April 25, 200619 yr I will be goin to the Subaru dealer tomorro to get some head gaskets,... i will take some part numbers and see what i can find.
April 25, 200619 yr I will be goin to the Subaru dealer tomorro to get some head gaskets,... i will take some part numbers and see what i can find. cool deal man, let us know what you find.
April 26, 200619 yr No good The parts dont exist in their parts books. Interestingly, the ecus in the parts book were numbered 22611AA*** (there was about 20 of them), our rally ecu had a part no. of 22611AA580, but wasnt in the book What is 82 Kpa in psi? Gannon
