Has anyone ever had an EA82 transmission rebuilt?
I'm snagging an older dual range 5 speed this weekend from a car I used to drive, and it was OK, but not great. The synchros were a bit weak, it had 150k miles on it, and just is a bit worn out. Definitely driveable, but... eh, just kind of old feeling.
I'm thinking of taking it into a transmission shop or Subaru dealership to have it rebuilt before I swap it into my Loyale (hopefully with an EJ series motor attached). How much would this likely run me?
-=Russ=-
-=Russ=-
don't know how much this would help you, but I got a quote of around 700 euro's, and that included complete new internals (except center diff)
Probably in the range of $500 to $800 for a quality job. Shouldn't need *all* new internals - bearings, seals, syncro's, maybe some shift bits, and possibly a few bushings. The gears and shafts are really not a wear item.
i had an xt-6 tranny with a bad bearing re done by ccr
I found the trannies to get tighter in time, but I do live in a cold place more than not. The top end seems to get taller and taller as things loosen. I took one to 161k and the other to 166k, and now a dual range "thick as a brick" tranny that seems to be the tallest geared stubborn out of all of them. I go to 4th gear after engine is warm into the high 60's mph at a decent rpm before thinking of 5th. I don't know if that means syncros warm or syncros synching- rebuilding one never crossed my mind.I just keep driving it gets better. I am willing to guess the 4wds will take 200hp forever- as we know the ea82s aren't quite there for alot of us oem drivers. Fluids unchanged past 150k is not even a problem where I live, and the fluid is nothing special for the years it has it.
Try this: put about a quart of Rislone (yes, the engine treatment) into your tranny. Drive normally for about a week, or until it seems to be less sticky.
Drain, and refill normally.
Rislone takes the "shellac" off the gears and synchros that builds up over time from heat and old fluids.
It's saved more than one manual tranny for me, and many more for other people I know!
Emily
http://www.ccrengines.com
ATF will do the same thing, just cheaper. Rislone, MMO, etc are just heavy detergent oils. Try spraying down your engine bay with ATF sometime :eek:
I've run manual tranny's with 100% ATF for a few hundred miles and they are CLEAN after that. It won't hurt anything in the short term as long as you are careful with your shifting - racers use it all the time for lower gear resistance, and if you think about it, automatic transmissions have the same gears in them and they run ATF for hundreds of thousands of miles. Using it for a few hundred as a cleaner is perfectly safe.
...I've run manual tranny's with 100% ATF for a few hundred miles and they are CLEAN after that...GD
FYI/FWIW: One of the Fords...Escort/EXP IIRC... used ATF in their manual transmissions. (Also IIRC, they used "F-type" in the manual and Dexron in their automatics.)
mercon-dexron 3 is used in my 98 zx2 (escort 2-door) never had a tranny problem.. the engine does suck balls though.
my trans feels notchy when i shift, the fluids full on the dipstick and looks clean. Should i put some kind of special fluid in it to help that out or what??
try running atf, i did 100% atf in my 5speed d/r tranny and its smoother now and it has 300k on the tranny :eek:
if i were going through this process i'd get that limited slip/locking front differential mentioned in WJM's thread and install it while the trans is apart for sure. how awesome would that be...true 4 wheel traction.
i wouldn't take it to the subaru dealership. should be able to get the same or much better service elsewhere for cheaper.
a few on here have taken apart EA manual trans themselves, they are far simpler than auto's.
Yah, dont overestimate the transmission. BUT, I would bet that a simple detergent treatment would be almost as good in your case.
I had a friend who had to replace the borg-warner T5 in his 92 RS camaro.. and that transmission used dexron III for oil. I have been wondering for some time now, exactly why such heavy oils are traditionally used... unless it is for longevity of oil life. It almost seems they try to ensure that the problems will be minimal by using a substance as close to Grease as possible :grin:
How long should ATF be used and do you have to flush out all the old oil or just drain it and put in the ATF? My 5 spd is really stiff in the mornings.
100 - 200 miles seems to do the job. Just use some cheap ATF. Then drain and fill with a quality synthetic - I prefer the Redline myself. It's not so sticky in the cold. But at $9.75 a qaurt it better be good stuff.
