Uberoo Posted June 30, 2007 Share Posted June 30, 2007 There is a rumor that ford tempo springs would lift an ea82 front end about 1.5" and give a better ride.This is completly false.uncompressed the springs are about 2.5" longer than the stock springs.Plus they have twice as many coils that are slightly thicker than stock springs.Besides,you would have NO downtravel at all,none.They possibly could work if you had an Ej22 plus 100lbs of front bumper.They could be cut to fit but I think I will just return them to get adjustable struts and RX springs. edit:Im gonna try cutting one coil off and see if that would make a differece Quote Link to comment Share on other sites More sharing options...
Gloyale Posted July 1, 2007 Share Posted July 1, 2007 There is a rumor that ford tempo springs would lift an ea82 front end about 1.5" and give a better ride.This is completly false.uncompressed the springs are about 2.5" longer than the stock springs.Plus they have twice as many coils that are slightly thicker than stock springs.Besides,you would have NO downtravel at all,none.They possibly could work if you had an Ej22 plus 100lbs of front bumper.They could be cut to fit but I think I will just return them to get adjustable struts and RX springs. edit:Im gonna try cutting one coil off and see if that would make a differece I think Loyale 2.7 used them. Makes sense for a six cyl. And have you seen the fiberglass he's added to his bumper? it probably is almost 100 lbs. Quote Link to comment Share on other sites More sharing options...
Uberoo Posted July 2, 2007 Author Share Posted July 2, 2007 After I cut a coil off the tempo springs they lifted my EJ swaped wagon atleast an inch.They are alot firmer.Just sitting it takes almost as much effort to push the front down as the back with accord springs.In fact they are stiff enough I dont believe a bumper and a winch would cause them to go down much.So if your EA82 is front heavy try a set of tempo front springs with a coil cut off(I used a chop saw) Now I just have to ovel out the strut mount holes to fix my camber... Quote Link to comment Share on other sites More sharing options...
Knichol Posted July 2, 2007 Share Posted July 2, 2007 What year and model (if it makes a difference) of the Tempo work on these not so uncommon EJ82's? Quote Link to comment Share on other sites More sharing options...
WoodsWagon Posted July 3, 2007 Share Posted July 3, 2007 Do you have a picture of how much coil you cut off? Like a full 360 of coil, or how much? I've got about 120lbs of bumper AND an EJ25 in the front, so I'm interested. Quote Link to comment Share on other sites More sharing options...
Uberoo Posted July 3, 2007 Author Share Posted July 3, 2007 one end of a tempo spring is ground flat,the other end the coil just ends.Just line your chop saw so it grinds the edge of the end of the spring then cut the coil heres a quick drawing I made in paint. cut spring.bmp Quote Link to comment Share on other sites More sharing options...
Uberoo Posted July 3, 2007 Author Share Posted July 3, 2007 What year and model (if it makes a difference) of the Tempo work on these not so uncommon EJ82's? I got mine from an 89.I dont think it makes a difference though. Quote Link to comment Share on other sites More sharing options...
El Toro Posted July 7, 2007 Share Posted July 7, 2007 i think i will try a set. my front end has a ton of metal. might not need the cut. we will see...... Quote Link to comment Share on other sites More sharing options...
Uberoo Posted July 14, 2007 Author Share Posted July 14, 2007 I checked the engine weight of a tempo verse the 2.2L subaru.it seem the tempo engine can be 307lbs to 419 lbs.So if thats the case you have 39-148lbs to play with as far as adding more weight to to the front end.most likley 148 because 307 is probally stripped... Quote Link to comment Share on other sites More sharing options...
crazy D Posted July 14, 2007 Share Posted July 14, 2007 what if you took your strut blocks outand just had really long springs? (suspension type lift) Quote Link to comment Share on other sites More sharing options...
carfreak85 Posted July 14, 2007 Share Posted July 14, 2007 You would need longer struts otherwise the taller springs will eat up all your droop travel. Quote Link to comment Share on other sites More sharing options...
monstaru Posted July 15, 2007 Share Posted July 15, 2007 now were loggin'................. Quote Link to comment Share on other sites More sharing options...
Uberoo Posted July 15, 2007 Author Share Posted July 15, 2007 it is suspension lift.and yes I have like no downtravel... Quote Link to comment Share on other sites More sharing options...
crazy D Posted July 16, 2007 Share Posted July 16, 2007 it is suspension lift.and yes I have like no downtravel... is that a problem>? downtravel= good right? Quote Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted July 16, 2007 Share Posted July 16, 2007 is that a problem>? downtravel= good right? for offroad its a problen, loss of flex Quote Link to comment Share on other sites More sharing options...
Uberoo Posted July 16, 2007 Author Share Posted July 16, 2007 as of yet I still haven driven this thing yet.Although from stock height you only have 1.5" of downtravel anyway...err actually if I jack the front of my car up I think I can go up about an inch and a half then tires lift off the ground...But what is a longer strut that bolts in place? Quote Link to comment Share on other sites More sharing options...
pinksock Posted July 17, 2007 Share Posted July 17, 2007 so my car is lifted, are these springs going to help with handling or do they just lifted it a little more?? Tony~ Quote Link to comment Share on other sites More sharing options...
Uberoo Posted July 17, 2007 Author Share Posted July 17, 2007 they will easily hold the weight of EJ22,beefy bumper and a winch...(pure speculation of course but judging by how firm they are...) ok I am not gonna post in this thread anymore till I actually have a chance to drive my wagon around...shooting for wedneday... Quote Link to comment Share on other sites More sharing options...
Uberoo Posted July 19, 2007 Author Share Posted July 19, 2007 drove it yesterday.it is a bit more jarring than normal.if you drive on a rough road the springs make the harshness go away.they could stand to be a little bit softer.on other hand there is like no body roll through the corners and thats with the 2" of lift. Quote Link to comment Share on other sites More sharing options...
crazy D Posted July 20, 2007 Share Posted July 20, 2007 drove it yesterday.it is a bit more jarring than normal.if you drive on a rough road the springs make the harshness go away.they could stand to be a little bit softer.on other hand there is like no body roll through the corners and thats with the 2" of lift. so do you like it better than stock? how is this gonna improve offroad wise? this is just up front right? Quote Link to comment Share on other sites More sharing options...
Uberoo Posted July 20, 2007 Author Share Posted July 20, 2007 Not sure about offroad yet.speed bumps are hell.it limits travel in the front but the front didn't have much travel stock... As for the ride I like it.the wagon doesnt roll through the corners.it totally stable at freeway speeds.it drives slightly different but then that may be because it is RWD for the time being(one of the original(old high miles) CV's exploded) Quote Link to comment Share on other sites More sharing options...
MilesFox Posted July 20, 2007 Share Posted July 20, 2007 how much difference in height are the new springs. i spaced my front crossmember about 5/8" the front end feels tight but when i roll into a corner i can feel the sudpension go negative camber and take the steering wheel with it a little. really if the front was stiffer altogether i think it would corner better. Quote Link to comment Share on other sites More sharing options...
Uberoo Posted July 21, 2007 Author Share Posted July 21, 2007 they lifted the front end about 1.5" after a complete coil is cut off. now I have a slightly weird problem.one spring still allows the suspension to "bounce"-ie some give.The other side is totally stiff.I wonder if I installed that stiff one wrong or something.The ride is comparable to a heavy duty 80's dodge truck.a little jarring but not to bad.plus no body roll though the corners...Now I just need to fix my positive camber...Where did I put that die grinder? Quote Link to comment Share on other sites More sharing options...
crazy D Posted July 28, 2007 Share Posted July 28, 2007 so have you taken this thing offroad yet? Quote Link to comment Share on other sites More sharing options...
Uberoo Posted July 29, 2007 Author Share Posted July 29, 2007 no,it blew a headgasket... Quote Link to comment Share on other sites More sharing options...
