December 9, 200322 yr Anyone tried using Restore in their sube's? I've heard it works real good and am considering it.
December 9, 200322 yr This is the stuff in the silver can? right? If so, I used it on some of my previous EA82 Soobs when they started to burn oil. It seemed to help reduce the amount that I would have to add, as for power... Nothing real noticable. This was back before I know as much as I do now, which still isn't much. So you may want to wait for some other responses to see if there are adverse effects.
December 9, 200322 yr REstore is alright if you want to go the cheap way.. Prolong is the best way to go A kid I know ran his subaru with no oil showing on the dipstick for 3 weeks (before it died) after he prolonged it. (Not saying this is good, but hey, it was worth the test.. lol) If your car is just burning oil and thats it, Lucas's Oil Stabilzer works better then Restore. (you get a quart bottle for 8 bucks) use it in your tranny too if you have a manual
December 9, 200322 yr DO NOT USE LUCAS!! I can't think of the site that did this test, anyone have it? Lucas causes the oil to foam like CRAZY when it's whipped around at high speed. The pictures they had on this site were amazing. If anyone has it, please post it. I'm pretty buzzed right now and can't remember many details, somebody fill the guys in? Before I knew about the problems with Lucas, I used it. It actually made my lifter clatter worse. I've found that Subarus benefit best from half a quart of Marvel Mystery Oil with every oil change.
December 9, 200322 yr i never used it in my scooby, oil additives = bad on turbo motors, they work off of heat, and you dont want all that **** caking up the turbo, but on a n/a motor, its the best and ONLY additive i use.. more compression, less oil consumption... My 300z had 140k on it, and its doing good.. the best one was my 90 escort gt, bought it with 95k, it used about a half quart between changes.. i added the restore, and ragged it to 180k, changed the oil every 3k, and added it again... i beleive thats the only thing that held that car together.. and yes, it quit using oil!.
December 9, 200322 yr i've used restore also. i did notice less oil consumption. as for compression, i couldn't tell you.
December 9, 200322 yr you know that smoke coming out of your tail pipe? well, its getting blown right up your a$$ if you buy into any of that motor rebuild in a can.
December 9, 200322 yr it's no cure all, but i don't feel that its a waste of money. i did have less oil consumption. i think it has some larger particles or something in it that is supposed to help seal things up a bit. but by all means, it is no "rebuild in a can"
December 9, 200322 yr i believe in it, ive tested compression before and after, broght the #3 on my nissan up 12 lbs.. much closer to the others
December 9, 200322 yr Author I was wondering if anyone else had the same turbo problem with using Restore. My compression isn't horrible in the cylinders but i was thinking that using it once would top them out. I don't want to mess the turbo up though.
December 9, 200322 yr Originally posted by mitch184 I was wondering if anyone else had the same turbo problem with using Restore. My compression isn't horrible in the cylinders but i was thinking that using it once would top them out. I don't want to mess the turbo up though. i wouldnt use it in a turbo, too much heat.. they use zinc.. theroeticly (sp?) it would help. but in reality, zinc would prolly coke up the turbo.. I just dont know.. ill try it on my car, the turbos on its way out anyhow (smokes just a little bit at high boost when shifting gears)
December 9, 200322 yr That stuff works awesome, i used it on my old hyundai and it took care of most of those old little leaks that made my driveway black. Its good stuff, go for it.
December 9, 200322 yr i never seen it stop leaks before, but now that i think about it, every car ive put it in never leaks a drop... hmm.. i have noticed that it takes a while for this stuff to start working, you just cant put one can in and expect maricles, use every 3000 miles youll notice..
December 10, 200322 yr I had an 85 s-10 blazer with the screamin 2.8:D, It developed a lifter tick and some piston slap. I tryed the RESTORE stuff in the silver can and all engine noises went away. that was 100K mi ago.
December 10, 200322 yr this site's pretty cool; don't know if it's the one with the lucas test though. http://www.bobistheoilguy.com
December 10, 200322 yr Thanks for the link! Here's the Lucas article: http://www.bobistheoilguy.com/images/lucas/lucas.htm
December 10, 200322 yr my dad used that in his 68' thunderbird once.. made it not clatter or burn any oil for about 300 miles, then he let it sit, and it was back to the old problems.. it was really worn out tho hehe.. i'd say use some MMO at every oil change..
