February 25, 200818 yr Is there really that big of a difference to cause problems? I just sheared the stub axle in my rear LSD, and I put in one out of a normal diff. The only difference I could see was that the step to the surface the seal rides on was a little different. It seemed to go in fine and turn OK, so I'm running with it.
February 25, 200818 yr I was wondering this too. I just did the swap and wanted to know if it would be worth it to keep the ones from open diff as spares. They didnt look different.
February 25, 200818 yr I don't think there is a difference. I've run with a combination of them before (and currently am, one of each), never had a problem.
February 25, 200818 yr is there something out there that suggests the LSD stubs are different than the non-LSD stubs? i've always swapped them out indiscriminately and never had a problem. i never even thought about it.
February 25, 200818 yr the clutch type LSDs found in the 80's RXs use the same stub shafts as the open differentials. the Viscous LSDs found on the early Turbo Leg, and later new gen vehicles us a different stub shaft that is solid, and is held in with a c-clip. so basically, any rear diff stub shaft from '78 - '90 should be interchangeable....
February 25, 200818 yr Author It's usually said when people are discussing doing the 3.7-3.9 LSD swap, that you need to keep the LSD stub axles with the carrier. They look almost the same, but that one machineing ridge was a bit different, so I wanted to be sure. Good to know that you can mix and match them. The stub sheared at a diagonal, across the splines and through the roll pin hole. Never seen one go that way, usually they just twist off with a clean break. The bearing cap got chewed up by the CV cup because it was off at an angle. Wore near a 1/4" of alluminum off.
February 25, 200818 yr It's usually said when people are discussing doing the 3.7-3.9 LSD swap, that you need to keep the LSD stub axles with the carrier. I've never heard that..... yea, I realized later that the confusion might be from the newer viscous ones where one side has 2 sets of splines.
July 9, 200817 yr yea, I realized later that the confusion might be from the newer viscous ones where one side has 2 sets of splines. I'm trying to find out exactly which models came with this. I've heard the 91-94 Turbo Legacy's have this. Is that right? I'm looking for this axle on the left.
July 9, 200817 yr I'm trying to find out exactly which models came with this. I've heard the 91-94 Turbo Legacy's have this. Is that right? I'm looking for this axle on the left. looks like VLSD axles, sometimes the c-clip (what you call the 'ring') stays with the diff..not an issue if you also have the diff... Kaz
July 9, 200817 yr Thanks. The LSD seems like a Suretrac (cam/pawl) unit as opposed to viscous. It was sold to me from a 96 Jap-spec Legacy as a vLSD but upon closer inspection, the two sides of the 'clutch pack' are very difficult to turn by hand. If it was viscous should it turn easily until the fluid heats up? Also, which US cars came with the axle pictured on the left? I've heard 91-94 Turbo Legacy. Is that correct? Also, car-part.com makes a distinction of pre 10/91 and post 11/91. Which one do I want?
July 9, 200817 yr some info that might help with the new-gen stuff: http://forums.nasioc.com/forums/showthread.php?t=1184807
