FIXED!! Trany delayed forward engagement
I posted a couple of weeks back about owning a 99 Leggie OBW with AT trouble. It had the cursed delayed forward engagement. I drained the ATF, and refilled with Amsoil synthetic ATF, and a can of Trans-X AT slip-stop & leak fix. After 10 minutes of driving the car, the problem was fixed. I don't know if the Amsoil or the Trans-X, or the combination of both, but whatever, the problem is gone. The Trans-X is advertised to swell seals. The car now shifts promptly into Drive after shifting from Reverse when stopped. Before, I had to wait as long as 5 to 10 seconds for the car to shift into Drive mode, while slightly revving the engine. What a PITA that was. My wife was on my back big time to sell the car. I feel like I dodged buying a wy trany, if I kept the car......
Life is good. I am happy!!
Thanks to all, who offered advise!
  • Replies 360
  • Views 147.4k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • From personal experience, seems like the Trans-X fix will last about a year, then shifting From R to D will return. Drain and fill tranny 3 times with short drives between drains, then add Trans-X wil
  • Resurrecting an old thread. Another success using Trans X, I have a beater 2000 OB with about 280K miles, it had been running pretty well then started with the delayed engagement pattern, it was bad e
  • Parts America ships to everywhere in the USA , not to Brazil.....On their site the real product we where talking about is not mentioned... Auto zone also is an domestic affair. Nobody on the site is
Posted Images
Great! Glad to see others who are willing to give the fluid/additive cocktail a shot. Bob
  • 3 weeks later...
It has been about 3 weeks since adding Trans X and 5 quarts of Amsoil synthetic ATF. I also changed the external AT filter. So far so good, the trany performes flawlessly, with no issues. I would highly recommend this course of action to anyone with a 99 or 00 that is having trouble with trany delayed forward engagement.
I've been running just the amsoil syn atf in an '00 outback since 96k now has 123k. It hasn't had the delayed engage issue (yet!). The trans-x might be helping out too, I used that in an old '88 lincoln when the trans started to act funny and it did help for a while.
  • 3 months later...
I also own a 99 Legacy Outback with a multi-year history of AT slipping in low gear. I finally fixed it :banana: (at least for now!) Below is a brief history of my problem and solution (thanks to Rooster2):
* 3 years ago...transmission slips in low gear every so often...not a big problem
* 2.5 year ago...changed transmission fluid (didn't fix problem...but doesn't get much worse either)
* 6 months ago....slipping is more often and lasts longer, so I added Lucas slip and leak stop and change transmission filter (doesn't fix the problem).
* last 6 months...problem gets worse and slips all the time
* 2 weeks ago...drain a quart of AT fluid and add Trans-X. (I now have a mixture of AT fluid, Lucas and Trans-X). Slipping has entirely gone away! :clap: I'm shocked...This was my last attempt at fixing this problem before going to an AT shop for an expensive repair/replacement. I'm convinced that the Trans-X fixed it.
I will come back to this website if the problem returns and report back. But, in the meantime, I am a very happy camper!!
I've been reading this website for a while and thank everyone for taking the time to add you advice and experience.
Glad to see you have good results with Trans X. I dont have trany problem but might as well put one in as routing maintenance.
Thanks
It has been about 6 months now since I posted the original "FIXED!!," so far so good. Trany continues to operate normally. I continue to sing the praise of Amsoil syn ATF and a can of Trans X.
  • 3 weeks later...
Do you happen to know off the top of your head how many quarts of oil these transmissions hold? I am having the same problem you were, I am at the point of rebuilding the transmission however if I can get by for another 6 months this way I would much rather go that route.
About 3.5 qts.
wait a minute, when you pull the plug and drain the trans you get about 3.5 qts, but the trans holds more, almost 3 times more for the 2.5L trans. check your manual, or do a search .
there was a post listing the correct amounts just last week.
I disagree if a 3.5 quart drain figure amount if it is listed in the car manual posting. I think the figure is wrong if we are comparing same Subie year and model. I have drained both my 98 and 99 Subie Leggie OBWagons. Upon refill, it takes about 4 quarts plus one pint. I then check fluid level with engine well warmed up, and engine running. With this method, the fluid level reaches the full mark on the stick. The drain method only drains about half of the trany's ATF capacity. The other half remains in the torque converter.
BTW, it is now 7 months, and about 5K miles since I first posted the "FIXED!! Trany delayed forward engament" message. The problem continues to remain FIXED. I couldn't be happier with how my trany is performing.
The word ABOUT (About 3.5 qts.) would mean that it could be more or less. As always use the dipstick for the finally measure. I'd buy 5 qt. so I'd have extra to top it off later. What a bunch of sticklers!!
Any idea where i could order it for shipment to Brazil (the Trans.X) ?
Amsoil is headquartered in Minnesota, USA. Do a google search on Amsoil. Also, a google search for Trans X to find a distributor or retailer near you.
Ams oil is not the problem , but where to find and order the miracolous "Trans-X AT slip-stop & leak fix" ?
Google did not work for me .
Yea, I looked around on Google for Trans-X. I found only testimonials by people that have used it. I will swing by an Autozone store, where I bought it, and report back who manufacturers the product.
I agree, where does one find Trans-x. I live in NC with the traditional Advance and autozone.
Any help as to where one in NC finds Trans-x?
It's was made by K&W which was bought by CRC about 10 years ago.
http://www.crcindustries.com/auto/content/prod_detail.aspx?PN=402132&S=Y
Looks like parts america carries it.
http://www.partsamerica.com/ProductListSimple.aspx?Category=2129
Yes, I just went to Autozone, and bought a can of Trans-X Automatic Transmisson Slip-stop & Leak Fix to keep on my parts shelf, and also to report contact info here. However, Porcupine 73 scouped me, by reporting here first. Here is some additional info......the Trans-X part number for the can is: 402015, for the 15 oz can. This is the size can that you would want to purchase to add to your Subies tranny.
I also checked out CRC industries website (as listed above), who manufacturers Trans-X. IMO, their website is about worthless. The website says very little about Trans-X, or where to purchase the product world wide. However, Parts America (website listed above) should be able to ship you Trans-X world wide. I hope all this helps!
Auto zone also is an domestic affair. Nobody on the site is interested to be a middle-man , also for more real parts in the future ?
My Impreza is the only Subaru in about 2000 miles from the next dealer...
Suggest contacting Trans-X manufacturer at: custserv.crc@crcindustries.com to see if they have a Brazilian sales network. If not contact me at: Fish6525@yahoo.com. Maybe I can help. (Rooster2)
  • 2 months later...
Just checking for an update on this issue. Still Fixed? Anyone else tried it? I think I am about to try it myself.
Hi, I am Rooster2, the guy who wrote the original thread. After 8 months, my trany continues to perform well with the Trans X additive to the automatic tranny.
About 3 weeks ago, a friend of mine who ownes a 99 OBW was have the same trany delayed forward engagement problem. His was much worse then mine. He was having a terrible time trying to get his trany to engage into Drive mode from Park mode. I drained his trany of ATF, added the Trans X and new ATF, and he says his trany has worked perfectly ever since.
Suggest draining and refilling with new ATF several times if your existing ATF is really dark and dirty, then on the last fill, add the Trans X. Further suggest adding really good ATF, as in synthetic ATF for best results.
