May 9, 200817 yr Will instal this soon.2" body lift and raised kings springs going into my 00 limited outback. Will update with fitted pics when done
May 10, 200817 yr Author Not quite finished. Left rear kit in right rear kit in Dave[sWK] lift kit builder/master hard at work Steering extension and a couple of bolts for the front to complete.
May 11, 200817 yr Author Haven't dealt with it yet.New tyres come next week,will be dealing with it then.Can't see it being much of a problem as the rear has standard struts and springs and the lift has spaced everything it down equally so no change.The front with the raised springs shouldn't be a problem.
May 12, 200817 yr Its a body lift. If done properly it should change geometry. Are you going to do anything about the anti sway bar(s)?
May 12, 200817 yr Author Whats the ramp over clearence measure?Looks good, just need some MT's now don't know about ramp over,but it will now go up a set of car ramps with out having to put blocks of timber in front. I thinking of making new links that adjust and quick disconnect. This cars my tourer,big trip to alice springs and the finke rally in a couple of weeks.I've got my old wagon for the hardcore stuff.
May 12, 200817 yr For the front? I had to get them for front and rear. The Front just becuase it was at the extreeme limit of adjustment.
May 12, 200817 yr Its a body lift. If done properly it should change geometry. Are you going to do anything about the anti sway bar(s)? I have to do that myself, but I've been told the bolts are a real beast to remove, and i have only noticed a slight change in handling. If I ever have to do the rear bushings then I will swap my radius bars in the rear to correct the sway bar angle.
December 27, 200817 yr any updated pics with new tires? i just purchased a 00 obw and it needs the same btw, how did you clear your signals?
December 27, 200817 yr How big of tires could you fit on there, it doesn't look like there is much more room for anything bigger unless.........:Flame:zzz Jeff
January 3, 200917 yr Haven't dealt with it yet.New tyres come next week,will be dealing with it then.Can't see it being much of a problem as the rear has standard struts and springs and the lift has spaced everything it down equally so no change.The front with the raised springs shouldn't be a problem. So going with the raised springs AND lift blocks, don't you need to do steering angle adjustments and engine mount lowering because of all the added height? I thought someone who'd done lift blocks AND king springs on a new gen had some steering linkage and brake line issues... Looks very nice!! I like all the new gen lifted soobs down under. I think the board's starting to see some in the states, but you guys have the market there!! Looking forward to pix with beefier tires!
January 18, 200917 yr Author Not the best pic .Tyres are 215/70 16 And for those like lifted liberty/legacy and outbacks.A few different gens in this pic
January 18, 200917 yr Author How big of tires could you fit on there, it doesn't look like there is much more room for anything bigger unless.........:Flame:zzz Jeff 215/70 16 fit with no cutting. Could go bigger again though plastic trimming woul be required.The later gen one in the pic above is running 225/70 16 So going with the raised springs AND lift blocks, don't you need to do steering angle adjustments and engine mount lowering because of all the added height? I thought someone who'd done lift blocks AND king springs on a new gen had some steering linkage and brake line issues... No steeering is no problem.The pitch rod needs to be lengthened,i had some spare ea ones which i cut to the right length so it looks factory. The only prob re brakes was i pulled a abs sensor plug when lifting.Unclipped from the holder and plugged back in its fine.
January 18, 200917 yr Author any updated pics with new tires?i just purchased a 00 obw and it needs the same btw, how did you clear your signals? Clear signals?Do you mean the indicater lenses?If so they are factory clear with a amber bulb.
August 17, 200916 yr revisiting old posts today... Do you have updated pix with beefier tires, or are those the final tires on this rig? Can you give some driving impressions of stock springs compared to raised scorpion springs? I'm told they're WAY stiffer, like washboard road driving off road... Interested in scorpion spring ride and raised spring ride.. thanks
