Knichol Posted August 5, 2008 Share Posted August 5, 2008 I just realized my nieghbor builds prerunner Fords and Toyota's and he thinks it would be great to build up a subaru to plink around with. I have searched through treads but haven't been able to find to specific information on solid axles under subarus. specific question - hopefully someone has already done the research and may save me some time. What if anything has close to the same width axles as an EA82 wagon? I would like to get something that doesn't stick the wheels out too far, (I can adjust overall looks with wheel selection) I haven't pull specs on the typical yota's, datsun, samari's, nissan, jeeps, ford's. If someone has already looked into this please let me know or PM me. Quote Link to comment Share on other sites More sharing options...
bigo1966 Posted August 5, 2008 Share Posted August 5, 2008 80's model Chevy 1 ton should be just right;) . Im guessing a Suzuki samurai. Quote Link to comment Share on other sites More sharing options...
SubPar Posted August 5, 2008 Share Posted August 5, 2008 Brat with Nissan solid rear axle... http://www.ultimatesubaru.org/forum/showpost.php?p=753182&postcount=1 DeathHatch has Yota axles, I think... http://www.ultimatesubaru.org/forum/showpost.php?p=562014&postcount=13 Quote Link to comment Share on other sites More sharing options...
michael appel Posted August 5, 2008 Share Posted August 5, 2008 You would be surprised how wide the subarus really are Quote Link to comment Share on other sites More sharing options...
Phizinza Posted August 6, 2008 Share Posted August 6, 2008 The Toyota Hilux (what the pickup is called in Australia) has almost the same track (width) as the EA82's. Quote Link to comment Share on other sites More sharing options...
Turbone Posted August 6, 2008 Share Posted August 6, 2008 Brat with Nissan solid rear axle...http://www.ultimatesubaru.org/forum/showpost.php?p=753182&postcount=1 DeathHatch has Yota axles, I think... http://www.ultimatesubaru.org/forum/showpost.php?p=562014&postcount=13 Qmans Brat is the ultimate in straight axle setups. Even had a electric locker. It has a Isuzu rearend and a Nissan T-Case. And its a tad narrower than a Subaru track. Death Hatch never moved under its own power I dont think (never finished). Quote Link to comment Share on other sites More sharing options...
MysteriousXTC Posted August 6, 2008 Share Posted August 6, 2008 Toyota solid axles worked realy well for me width wise... When I had yota solids under my wagon they fit damn near perfect, I had wheels with 3.5" back spacing and some 1.25 or 1.5 inch wheel spacers... The tires were 35x10.5 r15 i believe and about half of the tire, 5"s, stuck out on each side... So minus the wheel spacers, adjust the backspacing, and run thinner tires and the width should come out pretty close to stock... Quote Link to comment Share on other sites More sharing options...
Knichol Posted August 6, 2008 Author Share Posted August 6, 2008 Thanks for the info on this guys. We got the car up on his lift lastnight and just through some idea's around on mounting points and what needs to change to make a 4 link work. Quote Link to comment Share on other sites More sharing options...
monstaru Posted August 6, 2008 Share Posted August 6, 2008 i hate you kenny.... Quote Link to comment Share on other sites More sharing options...
MysteriousXTC Posted August 6, 2008 Share Posted August 6, 2008 Thanks for the info on this guys. We got the car up on his lift lastnight and just through some idea's around on mounting points and what needs to change to make a 4 link work. If you have the skills to do so, link is definitely the way to go, next time around I am definately going with links... Quote Link to comment Share on other sites More sharing options...
Subarutex Posted August 6, 2008 Share Posted August 6, 2008 Kenny, you are dreamy. XOXO Tex Quote Link to comment Share on other sites More sharing options...
Knichol Posted August 6, 2008 Author Share Posted August 6, 2008 I know Tex..... I get that way sometimes! Will this happen - I would give it a 50/50 chance. Depends if I can find parts in a cost effective way! Quote Link to comment Share on other sites More sharing options...
MysteriousXTC Posted August 7, 2008 Share Posted August 7, 2008 I know Tex..... I get that way sometimes! Will this happen - I would give it a 50/50 chance. Depends if I can find parts in a cost effective way! From what I have found Toy parts are the cheapest way to go, since they are most plentiful... But if you are going ot do it right it will not be cheap by no means... Also I ran a sami tcase because of the many regearing options out there and compared to other tcases the prices are pretty reasonable too, only bad thing is the tcase will most likely be slanted to the passanger side... This will be perfect for the toy front but not so good for the rear... Quote Link to comment Share on other sites More sharing options...
Turbone Posted August 7, 2008 Share Posted August 7, 2008 I've dreamt of a 4 link for years :-p Are there any Sami's out there with 4 links? Quote Link to comment Share on other sites More sharing options...
MysteriousXTC Posted August 7, 2008 Share Posted August 7, 2008 I've dreamt of a 4 link for years :-pAre there any Sami's out there with 4 links? There are sami's out there with everything from stock built axles to fully linked suspension with 2.5 ton Rockwell axles... http://rides.webshots.com/photo/1114373961053245731ckyoKL Quote Link to comment Share on other sites More sharing options...
MysteriousXTC Posted August 7, 2008 Share Posted August 7, 2008 This was my wagon when it was still independent suspension.... These are pics with the rear solid axle mounted without wheel spacers adn and without aggressive backspaced wheels; Good friend of mine he's 6'5" on a bad day... G'luck with your build, hopefully you will raise the bar for the rest of us... Quote Link to comment Share on other sites More sharing options...
TeamCF Posted August 8, 2008 Share Posted August 8, 2008 I've dreamt of a 4 link for years :-pAre there any Sami's out there with 4 links? There's a Suzuki X90 that runs around TSF on some big meats with a 4 link setup. Crazy lookin' little thing. I'll have to take some pics of it next time I see it out there. Guy did a really good job on it. Quote Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted August 8, 2008 Share Posted August 8, 2008 I've dreamt of a 4 link for years :-pAre there any Sami's out there with 4 links? Ive seem many of them at this site just look around http://www.zukikrawlers.com/index.php Quote Link to comment Share on other sites More sharing options...
monstaru Posted August 13, 2008 Share Posted August 13, 2008 when i measured it out it appeared that a nice subframe could be fabricated that would mount to all the stock locations with the perfect amount of room for a 4 link setup to be built on. i had the frrame and axles under the brat checking width and legnth. the toyota axle up front would render the best outcome i believe.it is skinny enough to pull off, but wide enough for a good stance. i mean basically the 4 link comes from the center (front to back ) of the vehicle.so whetever you are mounting it to should live there.(welded to ************ and bolted to piss.......) Quote Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted August 13, 2008 Share Posted August 13, 2008 Kenny I have a Sammy frame if you want it Quote Link to comment Share on other sites More sharing options...
Knichol Posted August 13, 2008 Author Share Posted August 13, 2008 rolling frame or just the rails? Quote Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted August 13, 2008 Share Posted August 13, 2008 rolling frame or just the rails? frame only Quote Link to comment Share on other sites More sharing options...
