April 2, 200916 yr Does anyone know where this is located I have finally found out there is a ignition relay but now where is it
April 2, 200916 yr What kind of subie you working on? There are a few different locations depending on your car type.
April 2, 200916 yr ignition realy???...Do you mean the main relay?...either way It should be located above the fuse panel inside the car on the drivers side to the left of the steering column...at least thats where they are in a 91 Legacy, and in my 96 Legacy thats where they put the main relay, FP relay, and sub fan relay #2 ( on models with A/C)... Edited April 2, 200916 yr by EVOthis
April 3, 200916 yr Author well here is the issue my car no longer trys to turn over I checked the starter and its all good battery is good and ignition switch is good but when i turn the key all my lights come on but it doesnt turn over my next thought is an ignition relay any ideas anyone
April 3, 200916 yr Is this the same car as in the thread Help my subaru won't start? see my post there.
January 19, 20197 yr i am working on my 1990 legacy and i think the ign relay is bad, no power to the ecm fuse is good. is the ign relay up above the fuse box and who was the idiot who put it up there?
January 19, 20197 yr 15 hours ago, subpoop said: i am working on my 1990 legacy and i think the ign relay is bad, no power to the ecm fuse is good. is the ign relay up above the fuse box and who was the idiot who put it up there? For the 11th time, it is WAAAY up in the very top corner of the dash. Drivers side. all the way to the left, all the way up.
January 20, 20197 yr 17 hours ago, subpoop said: i am working on my 1990 legacy and i think the ign relay is bad, no power to the ecm fuse is good. is the ign relay up above the fuse box and who was the idiot who put it up there? Nice thread dig... isn’t there another current one that’s working on/covering this already?? Cheers Bennie
January 20, 20197 yr 17 hours ago, subpoop said: i am working on my 1990 legacy and i think the ign relay is bad, no power to the ecm fuse is good. is the ign relay up above the fuse box and who was the idiot who put it up there? Look at page 10 in this pdf..........its been asked many many times. The info is out there in the ethernet. http://lib.store.yahoo.net/lib/mroseusa/EA2EJ.pdf
April 10, 20223 yr I have an 02 Subaru Legacy car stays running when I turn it off and pull the key out Doesn't do it all the time. Instrument cluster just came on and went off After a minute And the key is not in Ignition
