How to: Incressing Boxer rumble? (EA82)
This may not be beneficial for me. I usually drive in 2500-5000 range lol...
It will, my friend. It will. :burnout:
It made a noticeable difference in my old wagon. In fact, it let me run it all the way out to valve float at about 7900 rpm. There wasn't much power up there but, oh, did it sound angry!
  • Replies 83
  • Views 17.3k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • well if its spfi then i say block off your resonators in the intake so that its just a single pipe running with out big boxes or tubes with empty space in them, it'll give you a bit more rumble but no
I'm running with my 02 sensor and just a Greddy fart can, my car sounds like god... I tried running it just straight piped, once with the 02 sensor equipped and once without... Both times it was too loud and didn't really put an exclamation on the soob rumble.
Well I wanted to keep it a secret... but I plan on having a custom UEL made for Ned... about 2" if I can and then clear back to the 2.5" glasspack and then a flowmaster muffler...
but Im going with a slight compression bump... going SPFI EA82 under my carb manifold with torque cams... hopefully thatll give my EA82 some real growl... and some power behind that growl
The ea82 header is already UEL.
I found out that it has quite a nice rumble and isn't too loud when the muffler gets ripped off while rally driving through the woods.
An ej22 is really super annoyingly loud when it looses the muffler. And that's EL. Sounds like a rice machine.
It is? I thought it was just a basic Y-Pipe? Looks equal when I look at it, suppose itll look way different when I drop it.
In any case, I still wanna go to 2" :)
The EA82 Header isn't an UEL as a true UEL header, but one side is a tad longer then the other. It needs more unevenness if you ask me. Perhaps more compression for the sound we all want ;)
Right, one side is longer. Therefor it's UEL ...
It actually has a pretty decent rumble. Pull the muffler and drive it around :)
Thats the way mine is. I kinda think the EA82 has a better sound then the EJ rumble.
