December 5, 201015 yr Replaced the rear stay bushing for the shifter, the tranny mounts with STi mounts, and installed a short throw shifter on my parents' Outback. Wow, what a difference! No more bouncing shifter while getting on and off the throttle and far less slop in the shifter either.
December 5, 201015 yr Removed the engine out of my 1984 Subaru DL. Thought it was an EA81, but was surprised when it was an EA71 engine
December 5, 201015 yr Really? I thought 85 and up was EA82s? I suppose the brat and STD hatch were EA81s still.
December 5, 201015 yr The only models to offer the EA82 were the 1985-94: Loyale/GL/DL Sedans and Wagons (Not Hatchs) RX 3-door coupe and 4-door Sedans The hatch had the EA81 up untill '89 or whenever the last Hatch was made (Varies per country)
December 5, 201015 yr ^ Thats what I meant lol. I know that the Loyale in 1994 had the last EA82, and the Legacy had the EJ22. Off to go put engine back in the beast
December 6, 201015 yr Working on why it wouldn't start, no fuel, no spark....checked coil, bad Ohm so replaced it, distributor rotor and distributor ...still didn't start. Checked fuel pump, not getting voltage....after all that (and joining USMB) figured out the timing belts are bad, yea way bad. Have a set on order; hope the weather stays nice this week in Idaho. Edited December 6, 201015 yr by Crofty65
December 6, 201015 yr Author The only models to offer the EA82 were the 1985-94: Loyale/GL/DL Sedans and Wagons (Not Hatchs) RX 3-door coupe and 4-door Sedans The hatch had the EA81 up untill '89 or whenever the last Hatch was made (Varies per country) Even wierder, the STD hatch was a 1.6. It was a turd and I loved it! The other hatches were 1.8 No a/c, crank windows, no accessories to speak of, just a stripped down hatch, got 38 mpg if you babied it.
December 6, 201015 yr tune up on the wagon and tinted the fogs!! :banana: and just ordered front cv shafts and wheel bearing cuz apparently my passenger side decided to grenade on my pops while he was at work:banghead: Edited December 6, 201015 yr by mudER wagon
December 7, 201015 yr Today my 91 Loyale received a 2 1/2 inch muffler on the stock exhaust. In the last week, I've added a 1 farad capacitor and hard wired my 400 watt inverter. Other than that in the last 2 years I have pretty much just put gas in it. 90600 miles and still kicking along nice. NA ea-82 2wd Edited December 7, 201015 yr by donnieru
December 7, 201015 yr Went junkyarding. Found me some mint heater switches, and a few random interior pieces i needed. Also stumbled on a D/R 5 speed that they said i could have for $150 (and they'd even remove it for me!)
December 8, 201015 yr got my rear struts in no more bouncing wagon! the struts were so blown when I took the springs off the strut just collapsed.
December 8, 201015 yr SHE RUNS! LuLu, my 1984 Subaru DL Sedan ran today. Purred like a kitten... Well, the exhaust was off so more like she roared like a lion But Im very happy. She went 155k on her EA71 engine before the rod knock made GD and I think of swapping out the engine. When we pulled her original engine, we found it was an EA71, not the EA81 that we thought, so now its replaced and here soon she will drive back home to Hillsboro...
December 8, 201015 yr Author SHE RUNS! LuLu, my 1984 Subaru DL Sedan ran today. Purred like a kitten... Well, the exhaust was off so more like she roared like a lion But Im very happy. She went 155k on her EA71 engine before the rod knock made GD and I think of swapping out the engine. When we pulled her original engine, we found it was an EA71, not the EA81 that we thought, so now its replaced and here soon she will drive back home to Hillsboro... wow, that car is so clean? any known reason why it 'sploded? at least she runs and drives again! glad to hear that!
December 8, 201015 yr SHE RUNS! ...... we found it was an EA71, not the EA81 that we thought, so now its replaced and here soon she will drive back home to Hillsboro... Could I Ask with Which engine did you Replaced the EA71? Another EA71 or a EA81? Kind Regards.
December 9, 201015 yr New thermostat in my '91 Loyale. Now I've got heat even when I'm going down the mountain.
December 9, 201015 yr Got the engine in LuLu a few days ago. Started it up and it runs great, just need to do the PCV routing to the other valve cover and the air cleaner. Few other things that have to be done: Clean engine bay (its gross) PCV Routing Bad flasher (signals stay on when they should flash)
December 9, 201015 yr Could I Ask with Which engine did you Replaced the EA71? Another EA71 or a EA81? Kind Regards. To answer that, I replaced it with an EA81. We had one laying around that just needed cleaned up, had about 170k miles (my EA71 had 155k) so it was pretty close. She rides smoother now, whole new car... Even shifts better (4WD clutch in 2WD car)
December 9, 201015 yr wow, that car is so clean? any known reason why it 'sploded? at least she runs and drives again! glad to hear that! Abuse most likely... I didnt notice it when I bought it, but when we did maintenance, first start up had a pretty audible knock and then even after it warmed up we still hurt it. Didnt explode yet, but we want to tear into the engine and find out what made it knock
December 9, 201015 yr sorta reminds me of my lifter tick that makes my wagon sound like a bada*S lawnmower only mines bout to splode lol. still havent done cv shaft but, i tinted the tails on it some day ill actually have to take pictures and figure out how to post them here.... some day...
December 9, 201015 yr I brought one back from the dead Zeh Nite Vagon iz ALIVE And its for sale PM me for details Oh, and I twiddled with the BRAT trying to get the engine and transmission to mount up. Its harder than it looks when you're doing it on your own. Twitch
December 10, 201015 yr I removed one axle from the rear end. I found that my shock mount, the bottom rubber peice that slips in, is in peices, kinda not good. Makes for a rough ride. Hadnt been long luckily. And the odometer turned to 159k. Thats over 10k since Ive had it... i think. ha
December 10, 201015 yr i checked my coolant this morning and it was low. ive developed a leak somewhere around the carbadurator. changed the crossover hose that wraps around the front of the carb and t's into the hardline. went to town didnt fix it. grrr....
