Hey Gang,
I just signed up. I'm new to Subaru's, but am not a newbie. I an experienced DIY wrench. I just bought (traded, really) a dead 1997 Outback wagon EJ25D from my brother in law for effectively $100. He bought it three years ago for his kids, but the engine coughed up a lung two weeks into ownership. The car began to miss on one cylinder and he limped it home. Professionals told him it was probably the timing belt. He parked it at the back of his driveway and there it has sat, until now.
I'm starting a new business, and need a roof rack. The car spent the first 16 years of its life garaged in NYC, and it has only 80K miles. The interior is like new. The exterior is good, but could use a respray. This wagon IS WORTH FIXING. It has only 80K original miles on it.
The Obie experts on YT, from my research, seem to suggest pulling the motor to fix the valves/timing belt/cogs/pulley issues. So that's the plan. I bought the Haynes manual and read it thoroughly. I've watched the Mike Bauer and Briansmobile1 video on YT.
I've bought a good quality engine stand, and following Mike Bauer I've removed the battery, accessories, and the intake manifold yada yada yada. I've freed the exhaust manifold, the two motor mount nuts, and the four engine to bell housing nuts/bolts. Also freed are the four flywheel bolts. I've completed the list via the Haynes manual and am about to rent the hoist. And for your information when I pulled all four spark plugs I found that #3 was smashed in. Houston, we got a problem...
Once the engine is on the stand I shall remove the DOHC heads carefully. I've found a local machine shop in Yonkers, NY, that claims to fix "...about ten of 'em [Subaru cylinder heads] a week." The shop gave me some good instructions on how to remove the DOHC heads off the motor.
The shop told they will call once their diagnosis is complete. I will have to choose what parts to buy, or perhaps a rebuild kit. This is where I'm open to advice from the gang here. I don't know if I will need new cam shafts, or just new valves and springs. I'm pondering if I should do a bottom end rebuild as well.
I'll let you guys know how it goes. Thanks.
-King B.
