Longer wheel studs
31 replies to this topic
#1 WJM
WJM
    SUBARU
  • 7,828 posts
Posted 21 September 2005 - 12:01 AM
Any ideas on longer wheel studs for the older subies?
#2 TheSubaruJunkie
TheSubaruJunkie
    I'M BAAAAAACK!
  • 1,938 posts
  • Sacramento
Posted 21 September 2005 - 12:02 AM
Chef Tim found some. He used them on EA81 but im positive EA82 hubs are the same.
-Brian
#3 ShawnW
ShawnW
    Subaru Master Technician
  • Administrator
  • 12,952 posts
  • Denver, Colorado
Napa and custom wheel shops have lots of them if youre willing to change hole diameter or thread type.
#4 Snowman
Snowman
    Midnight Passenger
  • 3,538 posts
  • Haines
Go to the parts store and see what they can come up with that will fit into the hubs? There surely is some vehicle with studs that are similar but longer.
#5 WJM
WJM
    SUBARU
  • 7,828 posts
Posted 21 September 2005 - 12:44 AM
No need.
We have found 60MM studs...that are COMMON....as common as....as any other SUBARU and Nissan out there.
reason i ask before i post answer...to see if anyone has done the proper research.
Think...these 'old cars' are not so 'old'...........
#6 nkx
nkx
    Rallycross Junkie
  • 891 posts
  • Carlisle, PA
Posted 21 September 2005 - 01:10 AM
legacy studs? impreza studs?
#7 TROGDOR!
TROGDOR!
    Pastor of Muppets
  • 2,106 posts
  • Morgantown, WV
Posted 22 September 2005 - 09:10 AM
So, what are they?
#8 torxxx
torxxx
    I void warranties
  • 2,918 posts
  • Fairbanks
Posted 22 September 2005 - 12:04 PM
Yeah I'd like to know what the studs are for. I'm going to need longer studs so I can have an offset plate made for the hubs. I wanna go 1/2" offset to make sure my tires dont rub with the lift
#9 WJM
WJM
    SUBARU
  • 7,828 posts
Posted 22 September 2005 - 01:01 PM
Im only going to give one hint...as its classified and *I* dont have the say so to release the info....
They are COMMON and READILY AVALIBLE.
#10 TROGDOR!
TROGDOR!
    Pastor of Muppets
  • 2,106 posts
  • Morgantown, WV
Posted 22 September 2005 - 02:17 PM
Hmmm, then I suppose one of us with some free time needs to go to the junkyard with a Subaru lugnut and stud in hand and start checkingJapanese cars, starting with Subaru, then Nissan, and on out from there.
#11 JWX
JWX
    Lonely driver
  • 3,073 posts
  • Atlanta
Posted 22 September 2005 - 03:13 PM
only subaru and nissan use the M12x1.25 thread, that I have found atleast.
if you search it will come to you (google be your friends)
#12 chef_tim
chef_tim
    Romans 5:8
  • 4,780 posts
  • Renner, SD
Posted 22 September 2005 - 04:09 PM
http://www.ultimates...&highlight=stud
Oh Yeah, I have them on an EA 81 and 82 car. Tim
#13 dave valiant
dave valiant
    Subaru Nut
  • 570 posts
  • Rapid City
Posted 22 September 2005 - 04:54 PM
Thanks Tim. After I do my engine swap I will be getting these studs and nuts and running the pugs
#14 WJM
WJM
    SUBARU
  • 7,828 posts
Posted 22 September 2005 - 05:25 PM
Nope...the ones we have do not require special-ness....such as a 'press' :-p
#15 chef_tim
chef_tim
    Romans 5:8
  • 4,780 posts
  • Renner, SD
Posted 22 September 2005 - 06:03 PM
Why the big secret:confused: Help a few brothers out:D Tim
#16 WJM
WJM
    SUBARU
  • 7,828 posts
Posted 22 September 2005 - 06:13 PM
I would...but....things like this get posted on her and answered and then a week later some one posts the Q again and no one has a clue. Plus its up to the discover'r to reveal the info...not I.
#17 JWX
JWX
    Lonely driver
  • 3,073 posts
  • Atlanta
Posted 23 September 2005 - 12:47 AM
honestly just go look for them. its really that easy.
#18 critical_max
critical_max
    USMB is life!
  • 167 posts
  • Eugene, Oregon
Posted 23 September 2005 - 01:04 AM
M12x1.25 for Nissan, Subaru, and Suzuki
McGard lockable wheel nuts - 24154SU
Locking wheel nut set by McGard. Suitable for Nissan, Datsun, Subaru, Suzuki.
ray's engineering lug nuts M12x1.25 for "most japanese cars" (other than the big H)
http://www.rxecret7.com/raenlugnu.html
Looks like all Nissans share it?
JWX was right, it was a dead simple google
#19 WJM
WJM
    SUBARU
  • 7,828 posts
Posted 23 September 2005 - 07:04 AM
There is one more...and its also a big brand name....but its a 'nissan brand' and 'jdm'
#20 Handtool
Handtool
    Eat, Live, Breath Subaru
  • 292 posts
  • Yelm
Posted 23 September 2005 - 07:38 AM
Nismo
#21 nkx
nkx
    Rallycross Junkie
  • 891 posts
  • Carlisle, PA
Posted 11 October 2006 - 12:53 AM
old thread bump. do we know the length of the oem wheel studs??
#22 Phizinza
Phizinza
    Yip yip
  • 3,938 posts
  • South Australia
Posted 11 October 2006 - 01:41 AM
just as a guess around 40mm
#23 Kostamojen
Kostamojen
    From FF-1 to BRZ!
  • 1,693 posts
  • Roseville, CA
Posted 23 July 2010 - 02:21 PM
Bumping this to try and get some expert advise from the 80's folks...
I need longer studs for my front FF-1 hubs. The stud turns out to be the SAME as the 80's studs, here is a pic:
[URL]http://i15.photobucket.com/albums/a383/Kostamojen/FF-1%20Project/hubboltcomparo1.jpg[/URL]
The length of the Impreza studs would actually work OK, I only need 1-1.5cm longer studs to work with my spacers.
However I know about the NISMO studs (which are 50mm or 60mm) and ARP studs, but all of those appear to be geared for Impreza/Legacy style studs.
Has anyone used Impreza style studs on their 80's Brats/Loyales/etc. even though their stock stud looks like my FF-1 stud?
#24 ShawnW
ShawnW
  • Administrator
  • 12,952 posts
  • Denver, Colorado
Posted 24 July 2010 - 02:07 AM
I did and the acorn lug nut ended up having a hole thru the end but otherwise it worked ok. This was with a stock alloy wheel 13" thru a brake drum on the rear of my 84 Brat.
Still a little peeved at WJM for this thread. I see his point but honestly a factory Subaru part works fine if you need longer studs.
I have a feeling a stamped steel wheel might not fair as well as it would sit further down on the stud.
#25 Kostamojen
Kostamojen
    From FF-1 to BRZ!
  • 1,693 posts
  • Roseville, CA
Posted 24 July 2010 - 12:03 PM
What do you mean? You mean the open-ended lugnuts?
