All Activity
- Today
totem joined the community
- Yesterday
What’s your lift combination with the heights/block size for the strut block, engine crossmember blocks and the gearbox crossmember blocks? What sort of springs are you running in the front end? I’m wanting to understand how your lift is possibly effecting your CV angles to max them out. Can you also measure the distance between the ground and the highest point on the arch of your mud guard/fender when the car is sitting naturally and then when jacking it up right at the point that the rubber starts to lift off the ground. This should measure your droop or downwards travel amount in the suspension.
- Last week
From what my Parts Catalog says (and it only goes up to '90 so YMMV), the Loyale used a 95AC-23 axle (PN 23221GA373) which has 23 splines and a length between boots of 242mm. These axles are actually the shortest of all the OEM axles. You MIGHT (maybe, possibly, no guarantees) be able to get away with a longer OEM axle. The 87AC axles (PN 23221GA233) have a length of 257mm between boots. The 82AC axles (PN 23221GA244) have a length of 265mm between boots. You could gain up to 23mm in axle length with OEM axles which are better quality than modern production axles. Sorry I didn't really answer your question. Me personally, I'd drop the car to standard height and swap in used OEM axles. But that's just my opinion. Second option I'd personally go for is keep the lift, buy some 82AC axles and see if they work. Third option I'd go for is getting the Rock Auto extreme articulation axles. I'm sure they'd work, but for how long? And by that time would you be able to get them again? Going to stock gives you the most flexibility with parts and greater parts longevity. I'm beating the "keep it stock" drum pretty hard, but whatever you choose to do is your decision, I can only offer my opinion. :] P.S. looking for the right axles can be a major PITA. If you need alternative part numbers just shoot me a line.
Ok, my Subaru buddy came over today and immediately confirmed the most likely candidate is the CV's being maxed out with the lift. Not sure how the old ones survived but perhaps they were meant for a lift. Anyone know a good option for extreme articulation CV's? Looking at these off RockAuto but any other suggestions would be awesome! https://www.rockauto.com/en/moreinfo.php?pk=13224045&cc=1270134&pt=2288&jsn=591 Cheers!
EA82 Cleaning & Assembly Questions
SuspiciousPizza replied to SuspiciousPizza's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I'll just scrap the HG's and go out to my engine rebuilder to grab an extra set I had given them. Those are OEM gaskets anyways. -
el_freddo started following EA82 Turbo Heatshield Replacements? and Need Insight 96 GTB reliability
I second what Numbchux said about the single turbo conversion - it’s a very common conversion for the twin turbo “aids”. If you replace vacuum lines do this methodically - cut the old lines open once the new vac line is installed. You’re looking for restrictors known as “pills”. These need to be retained for the system to work properly. Otherwise the usual remains in terms of turbos and reliability. Harder you go the quicker things will need maintenance attentions and usually the wallet flogging.
el_freddo replied to LaMamelle's topic in Old Gen.: 80's GL/DL/XT/Loyales...
A turbo beanie will probably suffice. Or you could fold up some sheet metal to do the same thing the original chimney did in the first place. I have an STi converted SF forester that’s a sleeper - built by a mate. This does not have a bonnet scoop, rather it sports a turbo beanie and a water to air intercooler. The paint on the bonnet is not effected and I dare say it’s seen more heat than your EA82t will ever generate. -
el_freddo replied to SuspiciousPizza's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Ooh, part of me says it’s not a good idea to back them off and go again on those head gaskets. The other part of me says go for it, they’ve not seen a heat cycle yet. Worst case scenario you pop a HG prematurely. It an EA82 and not too complicated at the end of the day - “just” your time and some money. Your call on replacing the HGs if you choose to back them off and inspect those bolts. Do a search looking for a post by General Disorder about doing this exact thing with reusing head gaskets. I can’t remember what he recommended. -
It's 30 years old. It's only averaged about 1k miles per year, but it's traveled halfway around the world. Sitting is very hard on cars, depending on the environment. Being shipped across the pacific is very hard on cars. This is not going to be a turnkey car. The is going to be a labor of love (or money). Have something else to get you to work on time. There's nothing inherently wrong with the mechanicals of the EJ20H. Those are great heads, very difficult to warp. One of the better phase 1 shortblocks out there. But, the twin turbo systems are notoriously complicated. Using a nest of vacuum hoses and a bunch of solenoids to actuate all of that. Those hoses will likely be rotted and leaky. Good documentation on them is slim. Electronics are outdated, capacitors are likely leaking and causing a bunch of little issues. Anything rubber is dryrotted, anything greased is sticky. Many parts are shared with other models, some of those will still be available. Anything specific to that model with likely be very difficult to get. Convert to single turbo and a modern ECU, and it would probably be a great car.
Howdy! I've seen in the manual, and photos of other EA82Ts that they all have this heatshield/cooling funnel that shoots air from the bonnet of an XT right to the turbo. And I only noticed that was missing, just now. I assume this won't cause the car to explode if I don't have it, but I also assume that these are about as easy to find as a needle in a haystack. Does anyone have any recommendations for a 3rd party option? Will any fitting heat shield or sock suffice? Or is it even necessary, since the turbos not exactly the largest one out there. Thanks in advance!
96GTBWagon started following Need Insight 96 GTB reliability
I bought a beautiful 96 Legacy GTB 31k miles two months ago. the interior is immaculate. The outside is very good. zero rust. What I could not see with my eyes just got me good, I took it to one of the best Subaru enthusiast mechanics in NJ and they told me it needs a head gasket. I called a bunch of other shops in multiple states nearby and found much cheaper but in talking to one mechanic they said the engine is very reliable. Most others said the engine will keep having issues with gaskets, warped heads etc. I am trying to get an impartial view on the EJ20H motor/turbo/trans and all other costly repairs. Also, most if not all said if you need spare parts you are likely done for, which i understand but i’d like an impartial to see what other GTB owners have seen. May have to sell it which I hate to do bc I love the car but I won’t be able to ride out several $5-$10k repairs.
Sounds good. I actually installed the heads last night but I think I'm going to undo the head bolts and redo it. The front upper corner head bolts on either side went in a little crunchy and my gut is telling me to redo it. Those two head bolts were extremely caked in... Something. A brownish white powder that looked like instant 3-in-1 coffee. I had the heads cleaned but those bolt holes had some grit left in them. I missed seeing it until those bolts went in crunchy and I inspected the holes. All the bolts were cleaned and the threads were chased and blown clean. When I redo the heads then I'll make sure to oil under the bolt heads and washers. Shouldn't take too long, just undo the bolts, clean the bolt two bolt holes, re-clean all the threads, and torque to spec. Should I let the heads sit torqued for a day before retorque? :] -
moosens replied to SuspiciousPizza's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Wow my phone typos yeeehaaa -
Maybe i missed it but have you gotten an engine stand and flushed those head bolt holes? That’s going to be key. Same with bolt threads. Don’t sweat it all. Designs like these cam towers are reasons I have closed my chapter or EA82s but hey its your special engine so i understand your commitment. But to a lot of is older folks its just an EA82 and just do tour best, don’t go nuts with retotqueing the cam tower and etc etc but i am NOT a mechanic. Good luck. -
Do under the bolt head too. Engine oil will suffice. -
Thanks for your response. It feels like a wobble from the rear wheels but it could be a strong vibration. I can't see any wobble when I ride my bicycle beside or behind the car. It starts wobbling at bicycle speed and continues getting worst as I continue to slowly accelerate and stops as soon as I take my foot of the accelerator. After my process of elimination I have concluded it's either centre drive shaft rubber bushing, the transfer box, or the transmission. As there is no vibration coming from the front wheels and the auto transmission seems to functioning fine in all respect, good fluid, no leaks, and changes gears nicely, I tend to think its the drive shaft. I can not fine a new replacement for the centre bushing/bearing so I would have to buy a new shaft to eliminate that possibility, and the work to re & re. I was hoping I could easily and cheaply turn it into a FWD vehicle only. BUT, I also can't locate a new power transfer solenoid to re & re and not sure of what can of worms I may be opening up to replace it. The car has low mileage and motor runs well but it's been used like a work horse and has been beat up other wise, kind of like me at my old age and abused by hard physical work, so I'm hoping to get some more use to enable a big clean out of the salvaged construction materials around my home so my kids won't have to deal with my junk. So I'm looking for a simple, cheap fix to get a little more life and abuse out of it. Any future suggestions would be very much appreciated. My car has been a good work horse so I hate to put it out to the pasture yet while I still have a need for a beater. Thanks again.
96GTBWagon joined the community
SubeeIN207 joined the community
You're going to drop the suspension ~8" and leave the steering rack where it is? That's going to require so much modification to the knuckles to try to maintain the geometry, much lower offset wheels (which will put more load on said steering). You don't need an entire second factory crossmember. You only need brackets to support the motor mounts. Add a plate to grab the 2 studs on the "back" (now front) of the differential. Generally at that height, the lift blocks spacing the crossmembers and other suspension pickup points are tied together to make a bit of a frame, and then the transfer case and "front" (now rear) of the new differential can mount to that. Good picture of the bottom. You can see all the extra bracing added from the suspension mounts, and crossmembers that mount the diff and tcase. As well as rock sliders. And a good picture of a front crossmember/engine mount situation. Lots of room for the steering shaft.
I have another question regarding oiling the head bolts. After doing some reading online, specifically for rebuilding EJ's, some people really stress oiling the underside of the washers (knew that) as well as the underside of the bolt heads. Doing this makes sense but the FSM doesn't mention doing that. So is it okay to only oil the threads and the underside of the washers? Or should I also oil the underside of the bolt heads? Also some people really stress using a high-pressure assembly lube rather than engine oil. The FSM specifically says "oil". I know it's not rocket science but with how rare parts are, I want to take my time and do it by the book and learn from other's experience rather than learn the hard (and expensive) way. :] -
Thanks man. I'm definitely familiar with the shifter joint fix on the EJ series as I've done it three times before and makes me hate roll pins. I shot DRW an email to see what they have for it, I appreciate the referral.
el_freddo started following 1996 Subaru Legacy with bad rear wheel wobble
When you say rear wheel wobble do you mean vibration? This could be caused by many things as noted - start with the basics: - check mounting bushes of gearbox, diff and tail/propshaft; check centre bearing of the tailshaft for movement. - check uni joints for any play. ANY movement in one of these (where you can move one bearing cap closer to the other without the other one moving) means you need to replace it. Which means mods or a new tailshaft. - check rear CVs for any unexpected movement. Also realise that putting the 2wd fuse in will still see the rear drive shafts, diff and tailshaft spinning when the car moves. It just won’t receive power from the gearbox - assuming you have the auto from your description. What speeds do these vibrations occur? Is there a specific gear it happens in? Can you induce it by driving “manually” by selecting the gear the auto is to be in? If it occurs in all gears when accelerating my thoughts are it will be an issue with the auto.
