All Activity
- Past hour
- Today
Calling All Dual Range Owners
SuspiciousPizza replied to SuspiciousPizza's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I have a 3 day weekend coming up so I'll be taking the time to begin trying to take it apart then. I found a section 1-3 FSM for cheap on eBay so I don't have to wait around to get my other one back. I tried taking the T-case cover plate off last night to see if there was anything obvious. The RTV is gonna be a headache, it seriously doesn't wanna budge. Glued, screwed, and tattooed down. My idea for dealing with the RTV was getting it hot with a torch and gently using a razor blade to cut into the softened sealant. I do worry about residue from burning. I'm just going to have to be very thorough with cleaning the internals. I'll be recording as much of the disassembly as I can/remember to. I'll be posting links to the videos when pertinent. I'm kind of glad I got a "broken" box, now I can practice servicing one without the stress of potentially damaging a good transmission. There'll be more to come :] -
el_freddo replied to SuspiciousPizza's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Hmmm… think I’m looking at EJ cases too much these days, I don’t remember the top of the bell housing being so rounded. And those dowel hole up top - never seen that before, maybe a series 1 thing, I haven’t played with those gearboxes before. Cool audio clip. Could be many things - crown wheel touching the low range selector ring if they did a diff ratio swap (in which case, have a look at the pinion shaft for a weld mark); reverse gear partially engaged enough to click/grind like that - or a partially engaged drive gear for that matter too. So many possibilities of what it could be. Either way, don’t just drop that box in (as established)! Looking forward to autopsy pics Cheers Bennie -
You guys are awesome. Thank you for replying. I thought about the ebrake thing also. Lifting up on it slightly when pulling in the driveway starting to be a pain. I could look up schematic and use a jumper wire but maybe as a last resort. I'll look into that module. Must be the drl module that's being talked about?
czny replied to SuspiciousPizza's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Sounds like one of the forks is out of place and gear synchro cogs are hitting as you turn it. Time to open it up, unless you can return it still. -
Hey just so you know the advice I gave you was from a master Subaru tech who did this often. I also had to drop a pan and change out a full transmission harness etc. It’s not too big of a deal really. Good luck. Transmission pan gasket and some sealant if you desire. I think only sealant on the pan not to the block. That’s what I do on my old school pans. Never an issue.
moosens replied to SuspiciousPizza's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I’ve heard tree frogs make that noise. Seriously , doesn’t sound normal to me. -
'79 Brat EJ22 Retrofit Build Thread
moosens replied to mka's topic in Historic Subaru Forum: 50's thru 70's
Is this where some guy chimes in to break your stones about not having a reciprocating saw? Oh wait that’s FB Cool deal. I’m with you for having as opposed to finding out later you have not. You can trash it when the job is done I always say. Keep up the good work. This is very likely on my horizon. - Yesterday
mka replied to mka's topic in Historic Subaru Forum: 50's thru 70's
Got the transmission tunnel and parts of the firewall out as well as the remaining brake and fuel lines. The husk is now well and truly a husk. Some might ask "why the firewall?" when i have a perfectly good Brat firewall and my response is to preserve the mounting hole patterns for the Impreza parts like the brake master cylinder and passthroughs. I may not need them all but this way I at least have good templates or even pieces to splice in where I need them later. Getting the Impreza body scrapped this week and putting the brat back up on stands to get the rear end removed. Looking at it I assumed the removal would be an easier task than it was - there's way more structural stuff in there than it appears at first glance, especially were I've cut it. Took me much longer than anticipated to finish the removal, especially since I was using a 4.5" angle grinder to do it. Were I to do this again or make suggestions to other folks - use a good reciprocating saw at the support ribs - it will make for much cleaner cuts. -
Yes that was center to center. I'll take some photos of the boxes after work to show the mounting hole patterns. Based off the T-case, it looks to me like an 85-87 box. I'm mainly looking at the big blob in the casting on the T-case and the switch locations. I will have to wait before I start tearing into the spare box, my engine rebuilder has my hardcopy of my FSM at the moment so they can check tolerances. The downloaded FSM I have doesn't have any content between sections 2 & 6. (Jumps from engine to electrical) Do you have any pointers for the T-case disassembly, Benny? That's the main thing that is a concern for me. Thanks :] -
Is that measurement centre to centre? I know it’s not much different, bolt thickness really. A cross reference of the lower studs to opposite top bolt hole will confirm I reckon. If you have an EA82 gearbox you’ve already got the good bits. The only thing you need for the EJ dual range setup is the front cases from a dual range EJ gearbox - must be a phase 1 as they messed around and changed some specs in the reverse gear that would weaken it if a phase 2 case was used with phase 1 internals. I reckon it would be worth opening up that box just for a look. Could be interesting to see what was done (or more likely not done). Cheers Bennie -
Which tensioner? We just did the timing belt on a '95 EJ22, and had to get a Helicoil set for M10x1.24 for a stripped bolt hole. I believe it was the bolt holding a pulley, not the one for the tensioner. Anyway, if you have the bolt, just carry it into the hardware store and find a nut that fits it, then you'll know the size. Get a Helicoil kit, fix the hole right, and it's better than new.
- Last week
globochem joined the community
Suprimesir started following Cobb accesstuner Race downloads available.
Suprimesir replied to machineica's topic in Turbo Engine Tech ('91 and newer)
Hi brothers, I'm looking for AccessTuner Race (ATR) files for my 2011 WRX. If anyone can help or share what they have, we can rebuild the full list for the community. Here are some I already have available: 2002–2003 Subaru WRX 2004 Subaru WRX & STI 2005 Subaru WRX & STI 2006 Subaru WRX & STI 2007 Subaru WRX & STI 2008–2009 Subaru WRX STI 2011 Subaru WRX STI 2013 Subaru WRX STI 2014 Subaru WRX STI 2015 Subaru WRX & STI 2016 Subaru WRX 🗂️ Shared folder link: Google Drive Folder Let’s help each other preserve these tools! Thanks in advance 🙏 and many thanks to machineica.- 14 replies
- Cobb
- Accesstuner
(and 2 more)
Tagged with:
Suprimesir joined the community
uncle reg joined the community
T-Steve started following '79 Brat EJ22 Retrofit Build Thread
We did drain the pan and put in fresh ATF before we started driving it. Checked the level after the problem started and it still looks fresh, and about the right level on the dip stick. That's odd that it still looks fresh, the stuff we drained out was NOT fresh. I was expecting the 2/3 left in the torque converter and transmission to darken the fresh stuff.
Hey everyone. I'm looking to do my own 6 lug conversion. I need to drill the holes so the lug nuts don't spin obviously. Does anyone know what size drill bit I need to buy so the splines on the studs bite into the hubs? 9/16" end wrench will fit over the stud itself, 14mm won't, but I feel like the stud could spin in the hole with that size.
Bolt holes have a different spacing (EA box: 7 5/8" or ≈194mm - Mystery box: 7 9/16" or ≈192mm). I did have to eyeball with a ruler as my caliper only goes to 6" so I may be a bit inaccurate. But the mystery box doesn't have the same dowel pin holes the EA box does. She's dry as a bone. After fiddling with the differential more, it does sound like a box of rocks. Definite audible grinding noise to it, this could be due to improper gear alignment/ lack of lube(?) If I have an EA box, does that mean I can get those fancy Aussie D/R internals? Not that I plan to, but if due to parts issues it becomes my only option. :] -
Timing/Strange Idle
SuspiciousPizza replied to Xithael's topic in Old Gen.: 80's GL/DL/XT/Loyales...
When you get the engine to TDC, what landmark in the engine bay does the distributor rotor point towards? It should point towards the brake master cylinder/brake booster. If it doesn't - lift the distributor an inch or two and rotate it (I forget which direction). Remember the distributor gears have a spiral to them, so the rotor will rotate as you insert the distributor. Bolt it down, it shouldn't be rattling around. Just back off the bolts when you set the ignition timing. This way the distributor doesn't accidentally move when you tighten it down. Be sure to have the proper RPM's (≈750, I believe) when you do the ignition timing. :] -
Unrelated to the replies, but since it was idling normally for a bit, me and my grandpa took it out on the road for a test drive, and when we got back, the crank pulley bolt was so loose that it almost caused the belts to completely fall off, which I can only assume means that we did not torque the bolt. Does this mean we have to re-tension the belts? Thanks -Xithael
CEL is not on. I have a timing light, but it seems that the flywheel should be at 20 degrees towards the passenger side when it’s completely on the other side. I believe the timing light had to be cranked all the way clockwise to get the mark to show up. The distributor is loose right now so as to get it in a position that could be correct, but it may be worthwhile to just buckle it down for now to get some kind of consistency? We have new belts, fortunately my grandpa bought some back in the day. As far as I know, we have all the parts, we just need to put it back together, which we’re not far off from.
Yes, this engine has been some time in the works now. It’s been rebuilt from the block, and hasn’t run in 3 years or so. The cams have been timed, I believe? That’s when you set it to TDC and put the belts on? I believe that it’s been done. I have the manufacturer’s manuals, and I’ve checked about timing it, but since me and my grandpa started from scratch, we also had to put new fluids in, coolant, oil, etc. That ended up meaning that we also had to follow the procedures for warming up the coolant to temp, which is in right about the same area as the timing section, but since it has this issue I’ve been wondering: if it has an exhaust leak, is it worth trying to time right now? Like, if we fix the exhaust leak AFTER timing the engine, do we have to time it again? Thanks for the feedback, -Xithael
