All Activity
- Past hour
SubsPNW joined the community
Captain Ford joined the community
SamNoHam joined the community
Bigweld56 joined the community
HuntersSubaruTown joined the community
Roman9324765 joined the community
KarikYeld joined the community
- Today
'79 Brat EJ22 Retrofit Build Thread
mka replied to mka's topic in Historic Subaru Forum: 50's thru 70's
Busy workweek this week - but I got some really wonderful weather today and took the opportunity to get the next notable step dealt with - making the threaded mounting points for the impreza diff subframe. Also before I get too far into it, a protip/safety tip: if someone finds themselves recreating this, or if I decide to do it again - make sure you're using plain, non-galvanized tubing. I'm sure someone has spotted that already and was kind enough to keep their yap shut about it 😅 I used what I have on hand and looking back at it the prep work involved to safely weld this stuff with my setup quickly wiped out any minor cash savings I made by not just going to buy another stick of tubing. I'm sure I don't have to go into details about the dangers of working with galvanized material, but it's worth repeating that Zinc is bad for you in gaseous form and if you're gonna encounter it to take the proper safety precautions. With that out of the way - the photo essay goods: After everything was tacked up and nominally square - I clamped the new frame in its place on top of the bushings, and marked the first hole location for the threaded inserts ( M16 nuts I'm welding in), then center punched and drilled out the hole. I had access to weld the outer half of the nut since it's pretty close to the end of the tube and I used a technique i learned involving some clever placement of smaller access holes to get the inside faces of the nuts fused in. Like the other channels, this will all get boxed in and closed up when i'm happy with the fitment. After this I continued marking and drilling one hole at a time, using the Impreza subframe as a jig to make sure things ended up where they needed to be. I also drilled these holes slightly oversize so that I have a little wiggle room in their placement. Their final positions were dictated with tacks on the welder and then fully welded off of the impreza subframe so as not to melt or damage the bushings. After the new weldment and sheet metal subframe were temporarily assembled together, I put the diff back in it, put it on the transmission jack and then bolted the diff to the front mounts under the car. The original holes and features made for a really handy reference mark and wouldn't you know it, things came out super even. So even in fact, I couldn't help but loosely bolt the lateral links in, prop the trailing arm up, and lean the coilovers (not pictured) up in there without any bolts to get an idea of how things are going to sit. I can almost see it on the ground again! (It'll still be a while). I don't know if I'll be able to narrow the rear wheelbase quite as much as I'd have originally liked, though with a quick google having a slightly wider rear track isn't uncommon and can actually help with certain handling characteristics. I might have to flare my rear fenders, as I do not think I'm going to be able to reduce the rear width the full 9" (4.5" on each side) or so I originally measured without some pretty significant clearancing wizardry beween subframe and coil. I'll have a better plan of attack here once I've got everything semi-permanently affixed to the frame but either way what this is telling me is that I'll probably need to refrain from fully welding in this frame modification until I've got the suspension completely located. I'm also eyeballing putting in a set of rear discs rather than these drums, as I'm not a huge fan of drum brakes and well... I'm already really in the weeds so why not just do it from the ground up? Might get a little more in on this over the weekend, but I'll be playing that by ear. Until the next one! -M - Yesterday
el_freddo started following Door Trim Repair , '92 Legacy AC issue , 1990 Legacy AWD MT CEL not working? Plus weird relay issue? and 1 other
If that device on the dryer is good it sounds like you have a bad contact - or not the correct amount of refrigerant in the system. You should have two electrical devices in the system - a low pressure switch and and high pressure switch. Either of these will disable the system to protect it from damage when the gas pressures aren’t correct/within an operational range.
My '92 Legacy hasn't had working AC in a long time. However, I recently brought it to my mechanic and he tracked the issue to a couple connectors under the hood. The receiver/drier has an electrical connector coming off it that connects with a different connector right next to it. He disconnected them, jumped two of the contacts on one of the connectors with a piece of spare wire, and BAM, the compressor turned on and the car started blowing cold air. My mechanic said at one point he was able to get it working without jumping the contacts by simply disconnecting and reconnecting the two connectors, but that was short loved and now isn't working that way. What exactly do I need to fix here and where can I find replacement wires or connectors? I'm not sure where to start. Attached is a photo of the problematic connectors coming off the receiver/drier.
3-Time Owner Looking To Get Back In the Game
newmexguy replied to WYLDE007's topic in Meet n' Greet. Your USMB Welcome Center
Offed a southern NM bodied five speed 4 x 4 wagon body three or so years ago. Simply too far from the "buyers", wherever "buyers" may be. Put it on craigslist several times over. A young man from Ruidoso came and bought the carcass for $300, he had previously bought the 49K spare EA82 engine I had. Threw in many of the extra parts, as finding homes for them is certainly not easy. Believe his name was "Wyatt" I might have his contact info, in one of my old phones. He might have other stuff, including southern NM hulks. You could also try the AZ user, here, "azdave". Am sure something could be uncovered in metro Phoenix. - Last week
Hoping someone on here can either point me in the right direction, or has some that are laying around that they are willing to part with? There’s a couple numbers thrown around as far as flow goes, 450cc,440cc under usdm testing standards. I’ve also heard them described as 380cc under jdm, not trying to start an argument on flow, anyways just trying to get my hands on some injectors. I believe they are the OR05 from what I’ve gathered. I’ve tried eBay but I’m not sure if they just put the pictures of the right injectors on there and send you spoob, so was trying to find a good source before sending Australia 300 bucks. Thank you!
el_freddo replied to pontoontodd's topic in Off Road
Yeah I’m well aware of this. In some ways I’m jealous. And in other ways, seeing what dipsh!ts have made regardless of our modification laws, part of me is glad we’re not a free for all! Sounds like you have it licked, should be good once it’s all setup! -
Load Ground Power. You need a good complete circuit. Since this started when you changed the battery cable, I'd back up to there!
- 4 replies
- cel
- electrical
(and 3 more)
Tagged with:
Door Trim Repair
SuspiciousPizza replied to SuspiciousPizza's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I've been looking at the rally Leones and their brush guards and I was thinking something inspired by that. Something that mounts to the bumper and wraps around the side to cover the running lights. I'm buying a spare bumper from my parts guy so I don't have to modify my factory bumper. I plan on using industrial rubber vibration dampeners (originally designed to be placed between heavy machinery and a concrete pad to absorb vibrations). Hopefully these will act as a bushing to absorb impact. Otherwise I'd have to figure out some sort of suspension system for it. The rubber dampeners seemed to be the simplest solution. Otherwise I could make the mount out of aluminum tubing and bolt that to the chrome moly guard. The aluminum would act as a sacrificial absorber. -
Rich Mixture, Misfire, Stalling
I believe not all SPFI cars here in the US came with an O2 sensor. California has more strict emissions regulations than the rest of the nation. The California cars got O2 sensors, the cars sold in all other states do not have O2 sensors. I believe. Regardless, not all SPFI cars have O2 sensors from factory. I have found it interesting that despite my car originally being sold in California, it doesn't have California-spec emissions equipment. It has the national standard emissions equipment. I believe the national standard is just an EGR setup and a charcoal canister. No O2 sensor and no EGR temp sensor. -
In case you hadn't noticed we have a lot more options for vehicle modifications than Australia. These pumps are 255lph. Assuming this extra tank is 10 gallons that would take about nine minutes. Could have it going before you even start filling the main tank. Worst case you fill up the main tank, pull off to the side for ten minutes, then go back to the pump. Guess I'll find out. I think this will be the simplest way. One hose connecting the tops of the tanks for venting. One hose connecting the bottom of the secondary tank going down through one of the access panels and down to the bottom of the main tank. Have two fuel pumps side by side teed into that bottom hose one pointing each direction. One of those pumps could run the engine in a pinch. Definitely looking forward to the magically increased range.
Find out where that crackling electrical noise is coming from. Try squeezing/wiggling the wiring loom in various areas to see if anything changes, you could have a break of some sort Weird that everything is rhythmical/at a set time interval - almost like your test connectors are still connected. Are you in the rust belt area? It could be worth going over your earths and ensuring they’re clean if not done already.
- 4 replies
- cel
- electrical
(and 3 more)
Tagged with:
el_freddo replied to SuspiciousPizza's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I doubt there will be too much of a difference between carb cams and EFI cams. Turbo to NA cams, yes, quite a difference but even then the ECU wouldn’t care too much if at all. Cleaning the MAF can induce loads of issues if not done properly. Even then, many seem to report that the MAF is never quite the same after a clean if not done gently enough. Not having an O2 sensor would be an issue for the ECU. Why is this missing from the system? As for timing and pinging, my brumby sits on 4°btdc and runs the best RON “pump gas” we can get (98RON). Any more timing and it pings its tits off. Summer driving can be an issue with pinging at times. If your HVAC system is leaking vacuum that can be fun to diagnose - unless it’s a hose off which will hiss when selected (if post dash switch) quite loudly, enough to know you have a leak. The actuator diaphragms might mask the noise a bit better, however, in my Lseries with 530,000km on it they’ve never been an issue and not replaced in my ownership of 20+ years. I hope you get this sorted. Nothing more annoying than these little issues with no obvious solution. -
Those strips are held on with plastic clips. Best way to remove them is via the inside of the door by squeezing the tabs closed to let them slide out the hole. You don’t need a chime moly bullbar - that will fold something more substantial in the engine bay. What you want is a bullbar that will bend a bit as it absorbs the energy of the animal - thus saving other factory parts on the car that are harder to come by. Nothing is certain pin this though. Maybe a full exo-cage will do the trick, but where do you draw the line?
Yeah righto. That’s against our Australian Design Rules (ADRs) over here. Can’t pump fuel between tanks when refilling. Not saying it isn’t done, just that if you’re found out or cause a fire somehow you’ll be raked over the coals for it. And a Fawcett pump would be bloody slow - about 2L per minute transfer rate. Would be better off plumbing in a fill tube between the main tank and auxiliary tank with a one way valve towards the aux tank. There would need to be a vent line to the filler neck to help with the transfer. Or just have a secondary fill pipe off the filler neck to the aux tank so it fills after the main tank is full. Many ways to do it without over complicating things. Our Pajero (Shogun/Montero) sports a dual filler neck behind the filler cap so we can choose to fill the main tank or the auxiliary tank. This secondary filler pipe follows the main tank until it needs to head to the aux tank. Its pretty awesome the first few times being empty on the fuel gauge, then hitting the aux pump switch and watching (from time to time) the main tank gauge go from empty to full without pulling over -
Okay, the CEL codes did not come back, but the weird relay clicking continued, and has deepened into a stranger mystery.... So, after clearing the codes and not noticing anything too weird while driving it around for a while, I finally got the opportunity to ask a Subaru tech friend of mine about the relay clicking. While the key is in and turned on, without starting the engine, the fuel relay kept clicking on and off, pretty steadily. We listened to it with the hood open in a quiet garage and were also able to hear the fuel injectors *definitely* squirting fuel! (Confirmed when we let this go on for a bit and then the engine was flooded when I went to restart it) Even *more* ominously, there was a fun electrical crackling sound, like something was sparking a little bit every now and then. She even got a bit of a zap touching somewhere on the exhaust manifold, near the coil pack. But after unplugging all the spark plug wires and continuing to poke and listen, we found out that if we unplugged the connector for the IAC valve, the clicking and fuel injectors stopped (?!) We tried unplugging and plugging in the connectors for the injectors themselves, but that made no difference. It was *only* when the IAC connector was unplugged that it stopped. So...some kind of weird ground inside the IAC valve sensor portion?? Or...something else? We're both kinda stumped. I also tested the IACV according to the manual (testing for resistance across the pins of the connector on the valve itself, and testing for battery power at the harness connector) and everything was within parameters there. Before I go hunting for a new-used IACV to swap in just to see if that does anything (apparently they're not cheap LOL), does anyone have any speculation? Thanks everyone! This car always keeps me on my toes 😂
- 4 replies
- cel
- electrical
(and 3 more)
Tagged with:
I do not have an O2 sensor nor an EGR temp sensor. My coolant temp sensor is a good quality sensor and it's basically brand new. New doesn't mean good, I haven't tested it but I'd be rather surprised if that was the culprit. The car has always had a fluttering idle, even with a completely different engine. Also it's a D/R so there's no 4WD vacuum assembly like on a SR4WD. I wouldn't be surprised if the HVAC system has a leak. I'll give the hoses behind the dash a look. Interestingly the vacuum flutter on cold start isn't as bad and subsides much more quickly if the oil was preheated. Maybe one cylinder has bad rings? I brought the timing up to 15deg and I was pinging on regular. No issues with pinging when running premium. The heads have been resurfaced for sure once. No clue on their prior history. I'm not sure how the ECU learns mixture and timing curve but perhaps the ECU is expecting SPFI cams and the carb cams are making it freak out? I doubt this but it's a thought I had. -
RoadnReel replied to SuspiciousPizza's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Sounds to me like a timing or air issue. I would bring the timing to 8-10 degrees BTDC because of the carb cams and see what happens. You said you cleaned your MAF, so that shouldn't be a problem, but your O2 sensor could be sending slow signals. -
Numbchux replied to pontoontodd's topic in Off Road
"One for each direction" I remember him saying he doesn't want to have to separately fill the aux tank. He'd like to flip a switch while filling the main tank to transfer it up to the aux tank. And then activate the second pump to transfer it in the other direction when needed. -
Coming home from work this weekend I smoked a deer. Luckily my headlight took the brunt of the impact but the deer spun around and caved in my driver side door. It ripped off some of the side protectors and damaged the protector on my door. I'm talking about the 2.5" wide black plastic pieces. Are these pieces held on with plastic clips/rivets or maybe a double sided tape? How would one remove them? I'll be installing a "new" door in the coming weeks and once I get my hood straightened out I'll be back on the road. Next summer I'll get my door fixed and a buddy and I are going to repaint the car. I also will be welding a bull bar from chrome moly tubing so I don't have to worry about deer as much in the future. Thanks :]
Transfer pumpS? Why plural? Only need one. -
The reason for 14g was the distance more than the amperage. I used 12 ft, it's erring on the side of caution, but probably a good idea. If 5A is peak, not continuous, 16g is probably fine. But you'll start seeing voltage drop, which can be hard on motor contacts/brushes. The cleanest and shortest path from the alternator would help that. I looked up the stuff I used on my 4Runner. I'm using these in different Amperage ratings, but they're available in many variations. Maxi Relay + connector and terminals, here's an 80a version of the relay https://www.waytekwire.com/catalog/relays/mechanical-relays-and-connectors/cit-relay-and-switch-a3k1ccq12vdc1-6-maxi-relay-spdt-80a-12vdc-max-145vdc- Surface mount manual reset breaker https://www.waytekwire.com/catalog/circuit-breakers/high-amp-circuit-breakers/eaton-s-bussmann-series-184080f-01-1-surface-mount I buy a lot from Waytek, or Mouser. -
Thanks for all the advice on this. Good to have someone else looking over my shoulder making sure to at least warn me when I'm doing something I shouldn't. Yes, we're just using these as transfer pumps. One for each direction since they all seem to have a check valve built in, the only reversible ones I can find are pretty expensive. 14ga seems overkill for 5A. I use 16ga for almost everything. Will take a closer look at the ABS wires for sure, I like the idea of just using them for power and then grounding the other terminal of the pumps. Will probably see what other wires are running back there we're no longer using too. On the topic of wiring, any suggestions on a relay/fuse good for 80+ amps? Want to put both the pusher fans on the secondary fan circuit. Figure I'll switch the big relay I add with the stock wiring/relay. Those fans pull almost 30A each (over 30A when submerged in water apparently). Planning on putting both the puller fans on the primary fan circuit, they are small and don't draw as much so I should be good there. Currently have one of each on each circuit on 30A fuses.
Personally, I don't think I would trust ABS wires. Small gauge, and twisted pairs. Maybe use all 4 rear ABS sensor wires as positives, and then ground to the body Using this calculator, default voltage drop and temperature, 14v, 5a, 12ft run, they recommend 14g. Alternatively, 22 g wire has about a 20% voltage drop. -
I’d set it up as an aux Fawcett pump to transfer fuel from the aux tank to the main tank. Far simpler than trying to run a second high pressure pump and work out valves/relays to switch fuel lines to avoid back feeding and sort out the redirection of the returning fuel (unless you run a deadhead setup with zero fuel return). This sort of thing is something I want to do with my brumby under the tray behind the cab where there’s a decent cavity. -
2.2 OBD2 swap into ‘85 Brat
el_freddo replied to Greentractorfarmer's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The fix for a sloppy gear stick/shifter is cut a slot in about 20mm approx, parallel to the shaft’s location. Make the width a few mm at least. Do this on each side of that bracket. Then drill out the hole on the bracket while on the shaft so both are done at the same time. Shove a bolt in it with a metal lock nut, tighten the living daylights out of it and you’re done. If the gear stick is still sloppy but in a different way, you need to replace the bush on the bottom of it, the one that sits in a cup on top of the gearbox. Access this via the cab with console etc removed. I’m yet to do this, I was told a bit of garden hose over the end of the gear stick placed back in the bush does the trick. Well done on sorting out the running issue! There must be something in the mix on the old setup that does something that the charcoal canister does now.
