All Activity
- Last week
Have continued to observe and experiment with the Haltech. One issue that I've had since I have had a tablet plugged into it watching things the last month is that the O2 sensors would work sometimes but not other times (open circuit error code). And either they'd work the entire drive or not at all. One seemed worse than the other, switched them side to side and it followed so I replaced the worse one and that one seems to be working consistently. Other one occasionally doesn't work, will probably replace that one too. Also dawned on me that the Haltech was only using one of the sensors for the fuel trim. Had just assumed with the dual wideband kit and the EZ36 basemap it was using both. So I have those set for each bank now. Not that it makes much difference, they both seem to read about the same. Another issue was the cruise would work for about the first five minutes of driving and then give all kinds of errors. Went to an older version of firmware and that's back to working consistently. Keep watching the radiator temps. It was finally around 50F this afternoon and I drove the car a fair amount. After being parked for a bit the bottom sensor will be up around 100F but then when driving it starts dropping down at least close to ambient. When I got home and let it idle for a minute though it crept up to 200F, eventually around 218F, same as the top radiator temp. At that point the top radiator temp was actually about the same as the engine coolant temp too which is unusual, normally it reads at least 20F lower. This is still below the temp the first set of fans kicks in but odd to see zero temperature drop over the radiator. Once I ran the big fans, the bottom temp dropped down to about 100F in a minute or two. Even with the AC on the bottom temp dropped pretty quickly (wanted to see if the AC was still working). Top radiator temp and engine coolant temp dropped a bit too. With the big fans back off the bottom radiator temp went right back up to 200F in a minute or two. So that will be interesting to watch. Didn't seem to be in any danger of overheating but the radiator definitely isn't doing much cooling with no air moving through it (duh). Cams seem stable at all temps now. Follow the target pretty well when fully warmed up, bit of a delay when cold but not terrible. Still should get the car on a dyno sometime and actually figure out the best map for those. Got the idle lowered back down to 600RPM when warm and good throttle response. Much lower than that and it definitely hesitates/bogs when you tap the gas. Might play with that more. B stopped by last weekend and I went through the rear struts on the Impreza. I changed the valving to match B's rear struts (according to my notes I had, but I hadn't). So that might soften it up a bit, not that the ride is bad. Will see how it goes. Regardless they have fresh oil etc now. While I was doing that B replaced the pads in the (Mustang) rear calipers. Which can be quite a chore, the one took a while to get the piston threaded back in all the way. Those pads seem to wear faster than the fronts, I think they have less surface area. Also I finally got some different boots for the parking brake cables and B figured out how to get one of them to fit nicely.
Poor idle after rapid deceleration
bushytails replied to SuspiciousPizza's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I haven't cleaned that exact valve, but usually you want to blow a bunch of brake cleaner through every part of it, with the solenoid removed so you can manually move it to all positions, then put a drop of very light oil on the bearing. -
SuspiciousPizza replied to SuspiciousPizza's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I'll check the IAC tonight. It's right out front and easy to access. If it's not carboned up I'll see if there's a resistance test or something I can do in the FSM. I have a few spares kicking around I could try if it comes to that. Also I did do a factory PCV reroute. I know the PCV was definitely sucking oil before I did this. I lost about 1/3 quart of oil over about 1300-1500 miles. I've checked my oil level recently (about 1500 miles since the reroute) and I haven't noticed any obvious loss of oil after doing the reroute. Then again my oil pump leaks so I'm unsure how much of the aforementioned oil loss was due to the oil pump leaks vs the PCV sucking oil. And my vacuum does begin to ever so slightly flutter above 3.5k-ish RPM. Less than 1inHg fluctuation but if you're looking for it, it is noticable. -
Voltage fluctuating with turn signals is 100% normal. Also, no alternator problem, except for a bearing locked solid, will significantly affect idle speed. Valve issues are not caused by sudden deceleration. Any issues with valves closing slowly would show up at high rpm, when they have less time to close, not at idle. At cold start, the computer has the idle air control valve wide open and the mixture rich, like the choke and fast idle cam of a carb. As it warms up, it needs less air to maintain idle speed. To test the booster, stomp on the pedal as hard and long as you would for an emergency stop, while you're already stopped. If it does the same thing, you've found your problem. If it doesn't do it, it's probably not the problem. My money is still on the idle air control valve. -
I'd sure hope it's not the alternator. I swapped in a new one maybe a year and a half ago. The car has always had a voltage flutter and differing fuel pump whine with the turn signals. After I did some electrical work it has gotten better and now drops approximately 1 volt with the turn signals whereas before it was maybe 3 volts or so. I can always check the alternator terminal connections and belt tension. It doesn't sound like the belts are slipping (I'm running both belts in the same pattern since I deleted my AC). PCV valve is a new OEM part I added when doing a full refurb of the engine. I tightened it with a flange wrench too and while I didn't torque it, it definitely felt tight. Sealing the threads would be an easy thing to do. The engine I have in the car now was sitting for a few decades so I do suspect one or more of the valve springs are weak from the valves sitting open for so long. I didn't replace the springs because I couldn't find a full set of inner and outer springs. I'm still in need of outers, I have a full set of inners. Perhaps the springs just don't respond well to rapid changes in RPM? Valves get a little float? My vacuum on cold start is typically 15inHg then as the engine idles for a minute or two it'll creep up to 20inHg while staying at the same RPM (set to 1500 when cold). If the engine is REALLY cold my cold start vacuum is typically in the 12-15inHg range and the creep to 20inHg may take a little longer. -
el_freddo replied to SuspiciousPizza's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Sounds like your alternator isn’t doing its job like it used to. Try coasting down a long incline off throttle, then when back on the juice pedal watch out the rear view mirror for any blue smoke. If you run synthetic oil this trick won’t show up anything. If you have blue smoke it could be a number of things, mine turned out to be a broken ring land on two cylinders from memory (was 20 years ago now). Only showed a plume of blue smoke when off throttle at speed then back on it again until the oil was burnt off. The longer spend off throttle the more blue smoke produced. PCV system faults could be an issue too. The sticky IACV suggestion from bushytails is a good one to start with, as it may be slow to adjust quickly in those situations. If the IACV is dirty/sticky, the question then is why - failing component? Lack of appropriate voltage? PCV allowing oil to be sucked through the IACV at idle, coating it in oil, leading to gumming up over time? -
IAC is "new" a tested good unit that was cleaned and has a new gasket. I initially thought brake booster too. I could always swap in a booster vacuum hose to see if that works. However sometimes my vacuum will flutter with the blinking of my turn signals. My fuel pump will whine at a different tone with the turn signals and my voltage gauge will dip with the turn signals as well. This makes me believe it's a failing fuel pump. In addition to the pump being fairly noisy in general. I do have a spare brake booster if it ever comes to that. Probably wouldn't hurt to swap that in within the coming warmer months. Vacuum doesn't seem to change when I'm on the brakes at a red light. I'd think if it was a brake booster, I'd be seeing vacuum fluttering anytime I apply the brakes and that's not happening. Only on rapid deceleration. I've also noticed the idle issue is more common on downhill slopes (when the front of the car is lower than the rear). Maybe this has to do with the fuel in the tank sloshing forward and it's causing some issue with the fuel pump. -
Dirty idle air control valve (long thing with a big hose coming out the top of it, bolted on next to the throttle body), or leaky brake booster, would be my guesses. -
'89 GL SPFI 5DRMT. When I have to rapidly decelerate, for instance when a light turns yellow or I get cut off, when I get to a crawling pace or a complete stop my idle is very poor. It'll dip down to 250 RPM and my vacuum will flutter wildly within a 5-8 inHg range. If I give it a little throttle and hold it slightly above idle RPM for a few seconds it quickly subsides. I have no issue with throttle response when I'm having these idle issues. The engine responds to very slight throttle input. It starts cold just fine unless the car was sitting outside overnight in subzero temps, then getting it started can take a few minutes and words of affirmation. Any ideas? I'm thinking it's a failing fuel pump or maybe an injector in need of a cleaning. My fuel pump is quite noisy. I have replaced my fuel filter and the fuel that came out of the old filter wasn't dirty. I just haven't gotten the motivation to diagnose anything in this winter weather. Ideally if it is a fuel pump, I'd like to replace it when I do my post-winter rust inspections and general maintenance in the spring. Thanks :]
I haven't given up on the '01 EZ30 I was talking about recently, but have been dealing with higher priority stuff - including acquiring a radiant heater for the garage so I can get the damn thing fixed in comfort. In the meantime, we have an opportunity to grab an (estate) '06 Outback with the 3.0R - low miles (~250K km and an initial ask of $2K CAD). That's newer than anything else we have (or have had), so I've never touched this motor. What do all-y'all think of it? [Edit] I see now that it (the EZ30D Mk 2) is basically the same EZ30(D Mk1) as I'm familiar with, but with the addition of VVT. So my question stands: Do you think it's a good/bad/indifferent change?
Wrenchit1 joined the community
Returning after years...
Turbone replied to msteel's topic in Meet n' Greet. Your USMB Welcome Center
The trans in the turbo will prob have a 25 spline axle, so plan accordingly. Also, its going to be a 3.7 gear ratio, so be sure to swap the rear end also -
317WRBSTi joined the community
0766 joined the community
functionalfilms joined the community
Joepenoso joined the community
I'm running DRW bushing as well. I forget what the factory bushing durometer is but if I remember correctly the DRW bushing are slightly stiffer. I make it a habit to relube the bushing every spring/summer when I descale and treat the rust that forms during the winter. May be overkill but I'm going for longevity. I'm using good quality KYB strut mounts. Took a lot of searching to find them but I trust them more than the typical chinesium parts.
I run 45PSI all around, on 13" wheels... I load my wagon heavy and drive hard, and lower psi always gives uneven tire wear, with the edges (especially outer edges) wearing before the center tread. I've been running Tornel Direccional 205/60R13 lately. Not a common size, but I've been happy with them. Been tempted to get some 15x7 Diamond Racing wheels so I can run much easier to get 15s... What brand bushings are you running? I have DRW everywhere up front except the lower control arm bushings, which are now the odd-shaped Trupro ones. Have been wondering if other brands get better life than DRW's. I still need to find a source of Gen II rear outer bushes - DRW said he can make them if I give him specs. I might mail him the shells from a worn-out factory bushing.
A lot of ebay parts are listed for Leone II... I think they're borrowing the UK nomenclature for stuff. Others are done by 1400/1600/1800, which seems extremely imprecise. AU5/AM5/AJ5 seemed to be the most accurate way to find parts... but ebay's fitment tables were *all over the place*. Doing overly broad searches and filtering by hand seems to be the way to go.
Tires are typically ran at the stock 30-31 PSI. Granted I am on the factory 13" wheels. If I did a 5-lug conversion and got some 15" wheels under it, the ride would improve. I also am running stiffer poly bushings and all my rubber components are less than 2 years old. I don't have a decade or more of use to soften the ride. I'd say I have about 200 pounds of weight added to the car and I plan to add more. The weight, as mentioned, does definitely help. In comparison to a modern USDM (we love soft suspension and cup holders here, neither of which I have) vehicle though, it's almost at the complete opposite end of the spectrum. Okay, my thread hijack is over. Thanks for this write up! Any assistance getting parts on these cars where they belong is greatly appreciated! :]
- Earlier
Awesome write up @bushytails! Also look into https://subarino.com.au - a local guy that loves the MY models and will ship internationally. Just email for a quote on shipping. The years of the brumby will be different to your brat. We got them up to 1992 and I heard of several that were sold new from the dears late as 1994!! We don’t talk in generations - it’s either MY or L series; EA81 or EA82. No estates - station wagons GL and DL are the trim levels of the L series, the MY seems to only get the GL but I could be wrong there. That forwarding service is like one a mate used to use over in the states, they used to call them a virtual mail box and did the exact same thing you did, just the opposite way around. And good old Australia Post… they do their job well but take their sweet arsed time doing it! I usually use DHL for incoming packages and if they don’t do it to my address I either get it sent to work or go with FedX (which I prefer not to). I have king springs on my lifted and EJ’d L series with civic springs in the rear. I like the ride quality of the HD springs, but mine probably need replacing since they’re about 20 years old and probably not holding like they used to! If you drive an empty vehicle these springs will most likely not be nice to ride in. I also wonder what psi you’re running in your tyres as this will have an impact too. Thanks for sharing Bushytails, glad you got your parts and you’re happy with them!
A note on the "overload" King springs. I've had mine for about a year and I'm not sure how I feel about them. The Pros: They benefit high-speed handling, they improve the weight capacity (cargo for wagons or utes, more passengers, etc), they're yellow - they give proto wilderness trim vibes. The Cons: The ride, oh my goodness the ride. It is very unforgiving in terms of comfort. I live in an area that sees significant seasonal freezing and thawing and the buckling of the roads makes for a truly bad ride. Think sitting at the back of a school bus going over railroad tracks bad. I've been debating replacing them with my worn stock springs. The ride isn't bad enough to buy new stock rate springs but that's just my opinion. I forewarn any passengers that haven't ridden in the car about the ride. I do worry about the long term stress on the mounts, bushings, strut towers, etc. However the benefit of better weight capacity and better handling has me on the fence about whether or not they're worth it. I'll be keeping mine for the time being but I will be replacing them at the first sign of excessive wear to suspension components. If you're thinking about getting them, they do what's written on the tin. But be forewarned, they do so at the sacrifice of comfort.
