All Activity
- Today
Long time no write... After retirement, I rarely drive my wagon, after it sits for a while, I find the clutch pedal does not return after pressing. I CAN lift it and pump it enough to shift, then, after driving for a while, it starts behaving mostly normally. Anyone experience this? clutch master or slave cylinder????
Something happened to the engine
bushytails replied to oczuk32's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I doubt it's anything actually mechanical, just because it's all cylinders at once. -
el_freddo started following Something happened to the engine
el_freddo replied to oczuk32's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Worst case scenario your valves are stuck open from some gummy crap. You should be able to pull them closed again with the rocker covers removed. If it happens again afterwards, I’d be looking at spraying some sort of solvent or fresh fuel down the intake while cranking to hopefully clean up the gum that’s holding them open. Cheers Bennie -
Bad ECU or something more...?
el_freddo replied to LaMamelle's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If you wanted to test the pump you could re-route the fuel lines so the pump is sucking from a Jerrycan and the return line is sent back to another container to push out any other crap that’s still in the fuel system. Just remember that the jerrycan will empty pretty quickly! Cheers Bennie - Yesterday
LaMamelle replied to LaMamelle's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Thanks for your help and wisdom! Yeah, from what I read online, my next step should be to drop the gas tank and clean out the 16-year-old gas and varnish, which I have been dreading doing, but it's gotta be done. Once I do that, I have an extra pump lying around that I was saving for my wagon, I'll swap it in and see if I can start it up! From what I can tell the two pumps seem to be the same. -
If everything is turning, you probably just washed the cylinder walls, and it'll sound normal again after you fix the fuel problems and get it running for a bit. - Last week
Cobb accesstuner Race downloads available.
Suprimesir replied to machineica's topic in Turbo Engine Tech ('91 and newer)
i send you a DM with the link- 18 replies
- Cobb
- Accesstuner
(and 2 more)
Tagged with:
timmyy1236 replied to machineica's topic in Turbo Engine Tech ('91 and newer)
Does anyone have a copy of 11-14 wrx?I know its serial locked but I know how to get around that just any personal or pro copy that's compatible with 11-14.- 18 replies
- Cobb
- Accesstuner
(and 2 more)
Tagged with:
yodta started following 83/84 turbo wagon front struts?
Cheers! With the lift on this thing, I'll probably have to do some more searching for parts that will fit. I'm thinking I'll do a full overhaul of everything to do with suspension, wheels, brakes, potentially steering. We'll see how the part search goes! Appreciate the offer to help find parts from your local guy. Will PM you when I'm in search mode!
Congrats man, glad you're keeping it on the road. For suspension work, check out King Springs, they have overload springs that stiffen the suspension up quite a bit. Kind of a rough ride but allows for more cargo capacity and handles better. You may have a tough time finding front struts. But they're out there if you keep your eyes open and have patience. Their availability seems to come in waves. Also check out DRW bushings, good polyurethane bushings made by a very small business. If you ever need parts you can't find, I have a local parts guy I plan to visit in the next few weeks. Shoot me a PM if you need anything. :] P.S. you plan on doing wheel bearings while you're in there doing brakes?
oczuk32 replied to oczuk32's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Everything is turning over and getting spark. It cranks, but then stalls out. Based on what someone mentioned, the old varnished fuel may have damaged the valve seat seals or piston rings, causing a loss of compression. I drained the old fuel from the tank and blew out the fuel lines with compressed air. Then I added a couple gallons of fresh gas along with a treatment. I suspect the treatment is doing its job by breaking down the varnish in the tank—but that might be sending residue into the engine. I’ll monitor how it performs over the next few days. -
FOLKS! We have liftoff!!! Cleaned the injector with some carb cleaner and reinstalled. Still had some intermittent issues with misfires but I was able to play around with the distributor timing and took the beast for a rip around town last night. Engine is running great! Next up, suspension and brakes.
Are the accessories (alternator, etc) turning? -
Laven205 joined the community
timmyy1236 joined the community
Tried starting the engine this evening and it sounded like it completely lost compression. Any thoughts?
Well, 2 poor starters from NAPA caused the slow crank issue. The replacement Positive cable helped but when he got a good starter, much better. Aftermarket AT cooler added - has improved the Trans AT Temp. Still taking a bit of starting fluid to get it to start. Once running, it's fine. He can shut it off and start it right back up so fuel pump is working. I'm thinking the ECU is not turning the fuel pump on initially to build pressure. He's checking with a pressure gauge tee into the fuel line. If it's the ECU, I told him we could add a switch to the control circuit of the relay which would let him turn on the pump prior to start. I have to look, but I believe the ECU is just providing a ground for the control circuit of the fuel pump relay. Easy Button, if that's the case.
It'd be interesting to see the temp gauge at 65 MPH versus the last time you drove it. That radiator looks kinda bad, but I took one out of my car that was worse, albeit it was one of the later plastic tank ones. The cooling fins were literally falling out of it. I had a brass radiator welded/repaired like yours is after a wreck in a different vehicle, and that thing lasted nearly 40 years! Some of those guys do great work.
yodta started following What about Largest rim/tire combo for stock ea82??? , 13 inch tire discussion and max tire size
el_freddo started following Oil supply line to turbo
Try looking for a flexible hose with the correct sized banjo bolt fittings on each end. Mamba on eBay sells good products, you just need to find what works - an early RS Liberty/RS Legacy or wrx one could work if the banjo bolts are the same size. Cheers Bennie
1984 GL Hitachi carb Duty solenoids chattering.
Cold idle startup is solid. Ambient temperature was 89°F. After revving the engine to transition out of warm-up, the idle RPMs drop very low. I adjusted the carburetor idle screw to raise the RPMs above 700 and set the timing to just over 8 degrees BTDC. It's improving little by little. I'm currently running a cheap Amazon fuel pump until the correct one arrives from RockAuto (shipping from New York). I can still smell remnants of the old fuel coming from the exhaust. Once the new pump arrives, I plan to add fresh gas to the tank and see if there's any improvement. -
replace 1983 BRAT clutch fork springs
moosens replied to Geluso's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Alright let us know how it goes. My old eyes don’t see the crack I was expecting at the left side near the pivot pin. But hey you’re on the right path. -
moosens replied to oczuk32's topic in Old Gen.: 80's GL/DL/XT/Loyales...
And great info, thanks bushy. Kind of glad I’m sticking with my 70s cars. Good luck. -
Just a little info at this time. The rest of the country pretty much all has the 49 states Hitachi and the Carter single barrel is much less common to the point that those folks now can’t find diddly for their carbs. Carry on. -
The California Hitachi actually flows pretty well. It gets you several horsepower over the 49-state Carter version. There's also a 49-state Hitachi, but I've never seen one here in California. Unless you pair it with other upgrades, I don't think a carb swap will give noticeable power gains. It is, however, more complicated to work on. -
It should run best with the solenoids plugged in. Make sure the green test connector under the dash is not plugged together, then get your 'scope on the o2 sensor line. Keep in mind it's an unheated sensor, and you may need to rev it a little to get it to come to life. It should be switching between around ..2v and .7v every couple seconds. Check at idle, at a constant no-load slight rev, and during gentle driving. It'll always be rich at full throttle, by design. If the o2 sensor is switching at idle, but you have more power with them unplugged, check to make sure the power valve isn't stuck closed. On the topic of power valves, make sure not to damage the gasket around the tiny passage in the middle of the carb when taking the top half off. It's easy to tear, and will smoke and run like total spoob if you do tear it. Also check secondary is opening correctly - it's semi-vacuum-operated and can be sticky. And, of course, clean every single passage and jet in the carb... Also check timing. Rich mixture can hide overly advanced timing. Check timing with vacuum advance unplugged and idle set correctly.
