Everything posted by jamal
				? 6 speed into 1999 legacy? does it fit?
jamal replied to 1999roadrace's topic in Subaru Retrofitting
nasioc classifieds. There are usually a few 6-speeds for sale at any one time. Also there are detailed write ups and lists of all the stuff you'll need there. Do you plan to also swap the R180 and brembos? -
	yeah, I'm working on a new lighting/electrical setup. Upgraded headlight wiring with relays, room for a second set of FF1000 driving lights, and possibly some fog lights to go in my new turbo bumper. With my supertones that will make for 6 relays. I intend to build a relay/fuse box for all this stuff and place it behind the pass headlight, and run a big wire straight to it from the alternator.
	Aha! that's why my seat doesn't move forward and back very smoothly. Also you should note that the 02-03 seats (which I have), sit lower than 04-06 seats. Even with the height adjustment all the way down my seat is about an inch higher and I couldn't find an easy way to swap or modify the rails to lower them. If I were shorter it wouldn't be a problem but as it is I plan to find something lower. The added bolstering is worth it though, especially the way I drive.
	I have a set of RS calipers and brackets sitting in storage. I was going to put them on my car but decided to go the next step bigger, then a friend was going to put them on his rally car but that ended up not happening. They're missing a few bolts, the rear slide pins, and clips and shims, but if you want to save some money on used parts you can have them cheap. It'd also put you partway towards a rear disc conversion if you have drums.
	what are you trying to do, put on new pads and rotors or replace it all with something bigger? The 99 Impreza has two different front brake setups, and only two. 276mm rotors with 2-pots on the RS, and 1-pots with 260mm rotors on everything else, regardless of wheel size. Also, while the RS came with 16" wheels, the brakes will fit under 15s.
				Motor Build
jamal replied to faithless88's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I would use an STI 2.5 and 6-speed if my budget allowed, and swap the whole drivetrain/dash/ecu/brakes etc into a GC. I figure it will cost $12k or so to do it myself. 300hp without touching a thing on the motor. This: http://forums.nasioc.com/forums/forumdisplay.php?f=79 along with the other technical forums on nasioc, will give you a good idea of what people are using and what kind of numbers they're getting. There are a lot more people over there building fast soobs. I think you're severely underestimating the cost to have a hobby track car, especially one with 300hp. Come back when you have all that cash burning a hole in your pocket. Until then, if you want to window shop: Crawford i-speed world one racecomp engineering oakos etc... http://forums.nasioc.com/forums/forumdisplay.php?f=23 -
				block question
jamal replied to mdjdc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
yes, but it will result in a slightly lower compression ratio, so combined with the lower displacement the power loss would be pretty noticeable. The only thing you need to do is use 2.5 headgaskets. -
				Air Intake
jamal replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Is there something wrong with the stock system? The stock filter flows more than enough air for the motor, and while aftermarket ones such as K&N do flow more air, they also let more dirt into the motor. They also draw cool air from the fender. There are some cheap ebay piping systems that should work with the stock air box, which could be worth trying.
