Everything posted by DaveT
EJ for an EA71 swap?
The ej will be a big power increase due to bigger displacement and more sofisticated technology.
Those Old engines are very reliable. But hard to find parts for now. An ej swap is a big project. I'm not sure how severe the frame mods are for fitting on into that older style. Typically ej swaps are into ea82 powered cars. The frame rails AR narrower in the older cars,. You need an engine, wiring harness, ecu from a doner car, and an adapter plate, at the minimum.
- 92 loyale clutch cable replacement broke
'93 Loyale oil leak, coolant loss and gurgling noise. Head gasket?
The jgiggle pin is a part of the thermostat. It's a loose pin in a hole. It allowas a time amount of coolant to leak through, and also giggles when you squeeze the upper radiator hose. Note, oem and high quality aftermarket thermostats have them. Don't use cheap ones that don't.
for the EA82s I've had, I did reseals around 150K miles. Because oil leaking everywhere. One or 2 earlier because run low on coolant and over normal temperature caused bubbles in the coolant headgasket failure. If you go down to the headgaskets, you have no choice but to do all those other seals & gaskets. Do the valve seals. Maybe lap the valves, clean off the carbon build up, if any. I get the head set and conversion kits from Fel Pro, everything in there, except the anaerobic sealant for the cam towers, and don't use the intake gaskets, get those from a dealer. Also, get the 2 oil passage orings from a dealer. Big hint - get everything ready to disassemble the engine. Go for a drive to get it up to normal temperature. Park it where you are going to work, and immediately and carefully loosen the intake bolts. It's good to learn the different feel between the bolt yielding vs turning in a corroded hole, so as to reduce the chance of snapping one. Working the sticky ones back and forth can save a lot of trouble. Same applies to the head bolts, but it's hard to get that far in fast enough, so a space heater and a heat gun help with those. I put a meat thermometer in whatever hole is handy near the bolts I'm working on - you want normal operating temp, not much over.
EA81 seems to be lacking a cyclinder
This is an older generation car, more people who know them will see the post in the older generation sub forum. 3.0 vs 1.8 plus the diffwrence in technology is a huge amount less power.
diagnosing ac problem
DaveT replied to abstoler's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThey may have designed it with one size too small wire. Or not enough turns on the coil. Or a point where heat concentrated or vibration.
NEED HELP FAST UNKNOWN EA82 PART
I can't tell from that view. It's not a push rod like any I've seen. The end would have to be more of a ball shape, and shiny from the contact.
Oh, the oil leak. Probably the dried out oring on the passage to the cam tower. By now, if those have never been replaced, they're due.
You have to find that coolant leak asap, or you will need headgaskets for sure, if you don't already. It could be a slow leak to the exterior or an intake manifold gasket. But once you run over normal temp while low on coolant, the head gaskets get damaged and begin to fail. Exhaust gasses get pumped into the cooling system. Waiting a week to check the level, when you know it's going down is too long. The level on the recovery tank should be monitored. Check the radiator for air by sharply squeezing the upper radiator hose. Listen for gurgles and the jiggle pin. Anything more than a little gurgle of air is some thing to watch. Especially if the level in the recovery is changing.
School me on Year Changes...
The engine from the heads down will interchange. You need to swap the spfi manifold ans harness onto the 86 engine. Probably the distributor also. The fenders are the same, except trim might vary. Not sure about the power windows, my 86 had manual windows. I'd guess they are the same, but can't verify without spending quality time with my 2 FSM s. I have 86 and 90, and it's great for checking such things out.
Possible Ej22 Time Belt Pulley failure - Please Help :(
DaveT replied to johnnyispy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWd 40 won't stay there long, so that's very short time only .
- IAC Gasket Questions
Lower Temperature Fan Switch in 1991 Loyale?
Oem thermostat for loyale is about 190. I've been running a 180 in one of mine for a number of years now, never noticed any ill effects, but the heater seems a little lower output.
Hello and a Query
Hello, welcome Lots of info, and helpful people on here. The question would be seen by more members in the newer generation forum.
Rear passenger doors locked?
maybe, maybe not. If it's exposed to extreme temperature cycles, and little driving, a little water on the oil cap I've seen. The normal tell for headgasket to cooling system leak is air getting pushed into the coolant, not the coolant into the oil. Except for 1 very bad overheat with low coolant have I seen that.
Subaru Mechanical Problems
DaveT replied to mmboys07's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah, cars in the war of slant 6s had air in the radiator to handle the expansion, and iirc, most didn't have recovery tanks. I actually added one onto a car or 2. The whole system was setup to keep the air in the the top of the radiator, so it wasn't a problem. Of course, part of what made it possible is that everything was bigger. You have to have a decent volume of space to hold the air and for the water to not mix and drag it back through the system..
Ok, always good to check the simple things first.... I never had to deal with your problem, but I'd look at removing the seat to make getting the door cards off easier?
DaveT replied to mmboys07's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI don't know what the normal service intervals are for new cars. But if they are more than a week apart, it's very easy to loose enough coolant through a small leak to ruin head gaskets or worse, in any engine. I learned long ago to do this, as I mostly have only maintained older cars. If I were to buy a much more expensive newer one, I still would check frequently, as a lot more is at risk. When I began driving, the guys that pumped the gas checked oil and coolant while the pump ran. I just got used to doing the checks on my own when everywhere went to pump your own gas. I'm used to cars that have gauges, I don't like the trend back toward stupid lights at all. By the time those lights come on, it's too late, especially if it's due to low coolant level. In most if not all Subarus, if enough air is in the coolant system, it eventually interferes with the water pump circulating coolant. It doesn't take a huge amount of air. Maybe a couple of water bottles worth. Air pocket gets into water pump. Water pumps suck at pumping air. Coolant stops circulating. This can make the radiator not hot, since air was still cooling it. Head gaskets get toasted. Sometimes the pocket moves, and circulation restarts. It gets random. I am most familiar with the older models directly, newer ones mostly from what I've read on this forum.
DaveT replied to mmboys07's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCoolant level should be checked weekly for average daily driver. Both in the overflow tank, and the upper hose, by squeezing and listening for the jiggle pin and gurgling of air. Waiting for an over temperature indication on the dashboard is too late.
Subaru Repair Manuals
+1 what Downwash wrote. I did find a Chilton manual I got with a car useful for helping determine which parts were interchangeable between years, but aside from that, no substitute for a fsm.
Quiz Time- 2 Door Coupe Question
Not sure what they would be for. BUT if you can't get rustproofing / paint on the inside after welding, that's a problem...
AC clutch kicks on intermittently 1991 Loyale
The compressor cycles on and off depending on the heat load on the evaporator. There is a thermostat in there that controls it.
Thwre is a switch that disables the power locks for the back doors iirc...
- Directional & Hazard Lights Not Working
