tunered
Everything posted by tunered
it seems odd that the rear brakes seem to take turns at getting hot at different times,i think i would also jack up the rear and have somebody apply the brakes and see if they are releasing.i cant imanagine not having any brakes when this happens,99 times out of 100 when you have to pump the pedal to get brakes its because of air in the lines,having said that when pressure builds from heat like you are saying that you think it is usally makes more brakes,not less. sometimes it feels like brake fade at its worst but usually you have pedal. kinda stumped here. let us know how it goes.
i dont think thats it,your parking brake does not use the same pads as the rear brakes,even tho heat might transfer that far but i dought it.i would think you would notice dragging brakes,will it coast on a slight grade?im taking bets that there is air in the system. even if it was what you think,i dont think it would effect the front brakes so much as having none.i think a good bleeding would be my first task plus look for leaks around the wheels and under car.
chef, i had a set of goodyears that felt the same way,mushy steering responce and moved around alot in the wind, it was like driving on ballons. why dont you pump up the tires to maybe 35lbs and stiffen the sidewall and take a little drive,it will be a harsher ride on rough road but you will be able to tell if it is in the tires. i have had cars that the struts were wore out 2 years before i got the car and they did not drive all that bad on good road. just a thought .
the first thing you have to learn is to not let shops rip you off,dont know how long its been since they did the work but it would have been taken back if it was mine or never left their shop with the same noise for a thousand dollars. tell us a little more about the noise,only on the gas?how about when you are coasting?does it have the same sound in every gear?
the fuel pressure regulator keeps fuel pressure from being to high,if the injectors are weak and the regulator is bad i guess the extra pressure could possibly flood the engine,other car brands that i have worked on with the vaccum hose off only raised the pressure 3-5 lbs so i really dought that this is the problem.
