tunered
Everything posted by tunered
Fuse problem
tunered replied to olivo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
the reason i could see the spark was i quit using mine too,i thought the problem was there but had no way of knowing for sure. you could bend them back or just unhook the lead wire off the back and give it a week and see what happens. -
Abs
tunered replied to meprntr1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
if 97obw keeps hitin them curbs you can get a workout fixin his car. -
Abs
on the gm cars the brake pedal gets real hard and you think it aint gonna whoooooaaaa. -
Abs
i do know that mine works,they sound like a chatter on mine but i think mine was the first version,the first time i heard it i thought something was broke. -
Abs
yea blame it on the brakes,you had to be running 30 when you hit that curb. -
Fuse problem
i believe it relates to what opie says,my phone charger bent the ears down in the cig lighter socket,one day i was swatting a fly and hit the dash and saw i tiny spark down in the hole,you might check this and get lucky. -
the reason you hear so much about head gaskets is because who ever has one go bad they tell all,you are not hearing about the other 50,000 that arent having problems.i think i heard the figure at 10-12 percent failure.i think the ford 3.8 v6 faliure was at 85 percent.yours might go this week and they may never go bad.i wouldnt run scared. jmho.
to get a fair reading on blowby you need to block off the pcv,if its not puffing out the oil fill tube with the pcv blocked its not blowby,if thats not it the engine cant be breathing,air has to go into that block from somewhere,not sure where but we need to find out because something is blocked off. PS blowby will be at its worst at idle.
