Head Gasket/Head Job?
nipper, this is a good point. considering how difficult it is to reach one of the plugs, it could also be done in conjuntion with the compression test. the plug's already out right? i guess it just depends on the cost of the plugs and if you actually are going to repair the engine.
Starting Woes
johnceggleston replied to The Dude's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi can remember the first time i saw a starter PEDAL one my brother's 41? chevy and how odd i thought it was. not so different any more.
Subaru issues temporary stop sale on all vehicles equipped with 2.5L turbo engine
johnceggleston replied to hklaine's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXit sounds like it would only take a few weeks to present as a problem. too bad they didn't do this with the head gaskets. oh well, live and learn.
Oxygen sensor confusion - EJ22 & EJ25 are different?
johnceggleston replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi think the difference in the o2s for legacy, front and rear late 90s, is the connector. i think the sensor is the same. IIRC the 2 i compared were both denso /bosch wit hthe same number stamped on them, but the connectors were different, i think. it does not surprise me that the impreza changed before legacy, example: impreza went to a the phase 2 auto trans before legacy, a year at least. then in 00 or 01, the 2,2L impreza and legacy went with the same trans, same part number. then they discontinued the 2.2 altogether. it's just my guess, but i think they shared a trans for a while before phase 2, they just had different part numbers (maybe different final drives?). like the 96 outback trans has a different part number from the 97 outback, but the only difference is the production date. your question about swapped engines and not-swapped o2s brings up a good point, but i think the o2s stay with the car. the ecus generally stay with the car. it just doesn't seem too critical about the o2s. maybe that's why you can buy generic o2s, even if they aren't as reliable as oem. so to answer you question, you go with the sensor that fits the wiring and WORKS. hopefully you have several to choose from.
2.2 into 1.8 Imp
IIRC, the heads on the 2.2 and 1.8 are the same, so as long as the engines are of the same years , or matching years , it should.
johnceggleston replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXadvance auto has them the same for these years, not that i'd buy one from advance: Bosch Oxygen Sensor: Part Number: 13702 This product fits the following vehicles - click on a vehicle to see detailed engine information. SUBARU back to top 1998 - 1999 FORESTER 1996 - 1999 LEGACY 1998 - 1999 IMPREZA
Question about the ignition switch cylinder??
johnceggleston replied to pearlm30's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthe firs time i took my ignition switch apart, i used a chisle to slowly back out the security bolts, tap...tap...tap.... once i got it oput i raelized i didn't need to do all of that, live and learn. buy a replacement eithe here or at a parts yard. it would be good if all the locks matched, doors and ignition, but thats not required. the 'security bolts, (i thought these were really neat) are double headed and once they fully seat, the hex head snaps off leaving a rounded off head which is very time consuming to remove. i bought new security bolts and installed them. i'm not sure i'd do it again. any one who goes that far to steal my car can have it. it's insured. the part of the ignition switch / cylinder that the key fits into is easily removed if you have a key. you can then have re-keyed to match you door locks (i paid 20$ in 99). i don't know the headache if the key cylinder doesnot have a key. make sure the one you buy has a matching key. if you buy all the dorr locks as well as the igniton assesmbly, you can swap them out to. but the door locks a harder to install than the ignition aasem. in my opinion. you can't get a tool inside the door to thread in the seconf bolt. you can get them both out, but getting the second one back in is difficult. however ther is a spring clip that holds the door cylinder into the door handle and that helps keep the door handle in place. mine has worked fine since 99 with just one bolt. the rear hatch is easy. it souinds like mdjdc has everything you need.
johnceggleston replied to pearlm30's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi don't know anything about the forester, but not only are all the 90 - 99 ignition swtiches the same, but they are the same as early 90s nissan ignition switches. if you don't get a definte answer here, look up the part number at: http://www.subarupartsforyou.com/ and see what years it fits. do you need the whole unit that bolts onto the steering column with 'security bolts' or just the keyway? good luck.
looking for a break down of the 4eat
you got mail.
ATF change easy??? HA HA
johnceggleston replied to chaos1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyou really need to figure out what you drained and what you filled before you do anything else. from your description of how the car didn't 'shift' after your first attack, it sounds like you drained the trans fluid. use the dip stik on the driver side near the fire wall to confirm, do not start the car. once you are sure it's low add the 3.5 qts you tried to add earlier. hopefully this will correct that part of the error. the less you run it the better until you get the fluid back in ti. next, find the correct drain plug for the front diff and drain it. refill with the correct oil , run drive it a little, and drain and refill again. maybe repeat in a few days. i don't know what this stuff cost, but it's got to be cheaper than reworking the front diff. next, buy a haynes manual for your car, you'll be glad you did.
i have a pdf file that appears to be the FSM for the subaru 4eat. i can't upload it but if you pm me your email, i'll attach it for you. it says, 2) Install the washer and snap ring to the speedometer shaft, and set the oil seal. Then force-fit the shaft to the converter case 3) Install the speedometer driven gear to the speedometer shaft, and secure with a snap ring. the picture for step 3 shows it being done from the insde of the diff case. let me know.
94 2.2 in a 97 OBW 2.5
johnceggleston replied to jbain8's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXgary, does this mean you can't swap a 95 2.2 intake onto a 94 2,2L block and install it in a 95 ? i just assumed the blocks would be the same, or very very close. i have recently come across a couple of 95s that 'overheat'. i was wondering if a 94 engine with a 95 intake would work.
this may help. but i think you are going to have to pull the trans and then remove the carrier. http://smg.photobucket.com/albums/v204/All_talk/Subaru/4EAT/? you can see the plastic? drive gear , the speed sensor mounting hole is in the top right corner of the picture, I THINK. since there doesn't appear to be any way to attache the mechanisim in this picture, is it possible that it threads in from the top where the speed sensor attaches. of course if the drive gear is bad .......
Engine Sludge
i know nothing about turbos.... white smoke would make a lot of sense if the coolant was leaking into the exhaust or intake, but is there oil also in the intercooler that water could leak into? would an engine run if you disabled the turbo and re-routed the coolant line to exclude the turbo? to check for sludge then? probably can't disable the turbo while it is still on the engine. oh well, .................just wondering.
johnceggleston replied to jbain8's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthe 95 leg 2.2L is the preferred 'swap' engine for 96 - 99 2.5Ls. the few things that aren't a perfect match are minimal. there's a power steering line mounting bracket. take the A/C compressor off of your 2.5 and leave it attached to the a/c lines. you'll use the existing compressor with the 2.2L mounting bracket. you can do the same with the power steering pump. this save refilling both. i think there is one other small thing........ but it's a perfect fit. and will run fine. there are lots of write ups on this.
Failed Inspection : Updated
johnceggleston replied to msmithmmx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdon't feel bad. that's why the state requires the inspection, as long as they will go forward, most of us will drive them. some times it's good to have BIG BROTHER looking over our shoulder.
Axle Replacement - need tips
http://www.lovehorsepower.com/SubaruDocs/CVBoot.htm
automatic seat belt help
johnceggleston replied to seth3030's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXther was a discussion a while back wondering if the 90 - 94 us cars had the mounting points for standard seatbelts. apparently the automatic belts were not required in canada. you might be able to install regular belts.
Rear Window washer? 97 LOB...
johnceggleston replied to mcbrat's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXso you need to replace the tank with one from a wagon, yours is from a sedan. post a wabt ad here and some one should have one. or look at the for sale ads, some is bound to have this part, cheap. maybe here: http://www.ultimatesubaru.org/forum/showthread.php?t=86424
legacy gt engine part2..
johnceggleston replied to jeng22's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXis the check engine light on? what is the code? didn't your other post mention low compression?
legcy gt engine..
johnceggleston replied to jeng22's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi'm not so familiar with the '00 - '08s, but the 97 - 98 gt had the outback 2.5L engine and trans with the legacy suspension (maybe a different sway bar and TCU) and legacy tire size (on 16" wheels, but the same diameter). around '01 they discontinued the 2.2L legacy engine so your only choice would be the 2.5L engine. there is no difference between the GT engine and the outback engines. there were some of these engines (2.5 L, SOHC, phase 2?) that suffered external head gasket leaks, coolant leaking down the back driver side? of the engine, i think. so that may be a concern. you can search here: www.car-part.com . generally, the software will include other years that also match, psobably '00 - '03 or 04. sort your search by distance. shipping will / could run $150 and up. what's wrong with your engine?
Transmission Question..
who did the work?
Let it be the end-->Ej25 to Ej22 - which year to use?
in 1999 it all depends on the transmission. some, a very few probably, 99s used the same trans as 98 TZ102Z2DBA. if you have this trans then you have 4 bolts. if they changed to the new engine and not the new trans, which i doubt, then they used 4 bolts on a 6 bolt engine. so just read the trans number on the id tag or at the starter, if it ends in ...JEBA or JEAA or JECA then its the new 6 bolt. if it ends in ...2DBA then it's the old 4 bolt trans. this is for 2.5L legacys/outbacks.
2 motor swap ????
the single vs. dual exhaust ports, you'll need the y-pipe no egr OBD-none ? it will bolt in but you'll always have a CEL. do you have a 96 intake (or 95 A/T intake) to put on it.? that would help a lot. i don't know how it will run with the 98 ECU or if you could even swap ECUs?
strut question
johnceggleston replied to mdjdc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXjamie, thanks for taking the time to look it up. most of us don't have your resources. thanks.
