fnlyfnd
Everything posted by fnlyfnd
yea i want to know
Seafoam......
fnlyfnd replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Glad it worked out for ya. Did u turn off your car after you sucked in the seafoam for a lil while. You should suck it in (car will smoke) but then turn it off for about 5 minutes, restart it and rev/drive around. Make sure this is done on a hot engine -
Seafoam......
good to know, time to change my habits. -
Right now my biggest concern is getting a clutch/fixing oil seals, and Tires. Then underbody armor, extending the rear diff breather (still don't know what to do), fan switch, sealing the coil with a lexan type box. maybe not in this order, cause again I am broke.
Body shops suck. Aligning a door as previously mentioned is a PIA and does require a lot of patience. I tried adjusting my old jetta door, and 7/8 of the time it came out worse than it originally started as. The latch and the striker might not line up well, and cause the door not to shut all the way, or at all. You might have to lift the door to get it off/on the striker. Top and bottom lines might not line up. Windows might not line up... Etc, etc, etc....... This is why I didn't even mention fixing it yourself.
Seafoam......
Manrius, you mentioned "...how long you drive the tank to..." What does that have to do with the buildup of carbon in the engine. Not knocking you, just curious as I would have never thought that would have anyhting to do with it. -
Forgot to mention that I needed to cut the hole in my fender to about 4.5" in order for the flashing to fit.
Seafoam......
It doesn't eat seals. Thats left for the polar bears. It does clean all the crap off the inside of the engine, which is most likely sealing your seals from leaking. -
Seafoam......
It may cause oil leaks if your seals are old -
working on a lift tho...... The boot is a rubber roof flashing.
stuck the pipe in the hole and bolted it down. no pics, will get some over the weekend tho So you guys just love to hate the newer guys, huh? Sorry I don't have a ea w/ a 4" lift some super swampers and a welded diff. I gotta stick with low overal cost and reliability so I can be a student. I am just trying to add some character and cheap insurance for when I do make it to the big mud holes.
ha, ive gotten ************ about it not being used before. I need a new clutch before I do anything. I am lucky to get from point a - b now. so give it time, o yea i need new tires too. My logic: do the cheap stuff first
Donaldson "Top spin" Pre-filter. Link in pdf format: http://www.donaldson.com/en/engine/support/datalibrary/000207.pdf I didn't want to worry about doing a dual inlet setup. This keeps the rain, bugs, and hopefully snow, out of the pipe.
With work, ordering wrong parts, waiting for parts, school, recieving wrong parts, and rain, the snorkel is now complete. Pics:
Why not a electric impact wrench from harbor frieght for like $50. Not a cordless, but an actuall corded wrench. I have used one before doing a suspension swap on a 1985 jetta(read 20 yrs old, at the time). Got the car rolling in about a hour. I did soak the bolts a day prior, but still, a hour - thats damn good. I have also used a cordless snap on, but for that money you should just get a compressor.
