Everything posted by fnlyfnd
97 Legacy Outback Offroading plans
fnlyfnd replied to PimpinSquee's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXgood luck dude, and make sure you take lots of pics.
Tire Rotation Interval
fnlyfnd replied to BostonSubaruGuy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think thats a lil much....2x a yr alignment and balance. If the car goes straight and doesn't shake I think you're alright. No as far as rotation yea every 2 oil changes espeacialy with awd
grinding/rubbing while turning right
fnlyfnd replied to fnlyfnd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhahahaha....broken exhaust hangers, need to be welded back on. He said the wheel bearing should be good for antoher 10k before it starts showing signs of wear. I got under the car and didn't notice the hangers, but it was cold out and I didn't like laying on the cold driveway.
replace 5 speed in '99 LGT
fnlyfnd replied to MDW25gt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXuncle scotty's cocktail sucks, dont waist your money...especially if your car gets cold
The 2008 Outback was unveiled at Detroit, pfeh!
fnlyfnd replied to mtsmiths's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe front looks butt. The rest of the car is same as last yr, so thats good.
fnlyfnd replied to fnlyfnd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdisk in back. If it's nice tom. I'll throw it up and do some more investigating
So I developed a grinding type sound whenever I turn right. It only happens if the wheel is turned far enough, like a half turn, and usually needs some kind of speed. I can't figure it out. It sounds like its coming from the back, and devloped after my last time off roading. When I go in for an inspection I'm going to have them look at it, just wondering if you guys had any ideas. I was maybe thinking that the strut is rubbing on the tire? I'm pretty sure its original suspension @ 121k. How would I test this theory out? Again it only happens when turning right, almost sounds like the muffler is dragging on the ground (it's not).
Engine Out! - What do I replace while I'm at it?
fnlyfnd replied to derekd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXoil seperator plate in back...valve cover gaskets....and prev. mentioned items
Safest car ...
fnlyfnd replied to mtsmiths's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXactually I am....the 2005's got bad ratings on the side crash test
Clutch replacement follow up (Fenco/Exedy)
fnlyfnd replied to Subarunation 713's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI just replaced my clutch using a exedy kit, and replaced my flywheel with a new oem one. Still chatters and I'm pissed. 1996 2.2L
clutch adjustment question
So, after a couple thousand miles on a brand new clutch kit and flywheel (and cable) I decided to adjust it today. The car would previosuly shudder in first a bit...and during compression braking, although I wasn't going fast enough for the need to rev match. I now have it adjusted so its better although I still get some slight shudder during compresion braking, sometimes. I can completely strat the car from a dead stop on flat ground in first w/o even touching the gas (idles normal @ 700ish), I even got 2nd to go, but it needed just a smidge of gas - In both circumsrtances I was fineesing the clutch. I think I could have gotten second to continue to roll, but too afraid. It did stall in 2nd when I came to a stop w/o putting the clutch in. The clutch catches IMO close to the floor (but i am used to the old feel) and there seems to be noticeable free play at the top in the pedal range (again compared to the old feel). 3rd gear starts are tough but I can get it. I can still get through all the gears fine. I'm I at optimal setting or should I back it up a little??....or just get a new new clutch kit to save the new $350 flywheel??
All wheel drive is great, but....
fnlyfnd replied to Martinjmpr's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI wanted to get a recovery strap, but couldn't figure out how you would use it if the car(s) don't have a tow hook on them. As in our case with outbacks, all there are, are tow loops. How would a recovery strap connect?? I haven't got a recovery or tow strap yet because of this
$10 per spark plug????
fnlyfnd replied to mnwolftrack's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyou should stick with genuine subaru wires. I say do more searching. I thought a lot of people like the copper ngks, I use them in my 2.2....I did this after searching, but that was a year ago. I don't remember anything about lasers
De-brightonization
fnlyfnd replied to WoodsWagon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLeather sucks. Although, I do believe the leather seats are more comfortable than the others in the first couple gens. Thats pretty fancy with the outback logo in them, must be custom. I don't think outbacks have the logos stiched in....mine doesn't.
Any recommendation on tires?
fnlyfnd replied to DishMan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXnon directional is the real way to go with the option of a #5 spare so you don't have to buy a whole set when you get a blow out. kinda wish my snows were ND, but what can u do
fnlyfnd replied to DishMan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI would say triple treads. It doesn't make any sense to me why you would want bfg a/t for your conditions. a lot of people love triple treads, i don't have any experience with them.
is 215k miles on a ej22 to much
fnlyfnd replied to mellow65's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXrun it to a local advance autoparts, they'll read em for free. 215k is ceratainly high, but you should be able to take further, others have.
Is anything worth saving?
fnlyfnd replied to keltik's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthanks bud
fnlyfnd replied to keltik's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdefinately keep the engine/tranny/rear end. Never know if/when you're going to need that stuff. Maybe find a reg. ej20 (if there is one) and swap the ecu and turbo stuff, along with the tranny (prolly different ratios) and the rear end.
Will WRX 6sp fit to '99 2.5 legacy
fnlyfnd replied to MDW25gt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf its a complete swap (engine, tranny, ecu, rear end) then all you would have worry about is the dash, halfshaft and driveshaft lengths.
Best wipers for my Outback?
fnlyfnd replied to rushsteve's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXValeo...awesome, no streaks, no place for ice to build up, easy install http://www.tirerack.com/accessories/valeo/ultimate.jsp ---buy one - get one
Legacy Hatchback?
fnlyfnd replied to RallyKeith's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI doubt toyota will be any help in the 2 door dept.
Cheaper Shocks create more interior noise?
fnlyfnd replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have never looked at the door for psi, on any car. I always go by the tire itself
Dedicated Winter Tires
fnlyfnd replied to mystro's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI paid $520 for my rsi's installed w/ disposal fees. I dont really think that is that bad, just hoping they last at leats 4 seasons. Stupid snow didn't fall for a month after I got em.
Impreza wagon questions
fnlyfnd replied to SOUTHBAYeric's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDifferent gear oils can help alleviate the grinding problems. Usually its more of a matter of getting used to the tranny. If I shift fast I'll grind 2nd (in the process of getting a good oil in there). Cold mornings I have to double shift 2nd (currently running some crap dyno oil). Manuals can develop toque bind, which is a very costly repair, but if you found a good condtion used tranny than you could replace the whole thing substantially cheaper. autos cost less to repair and you dont have search for a complete used tranny.
