Everything posted by fnlyfnd
I think I know whats wrong
fnlyfnd replied to fnlyfnd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI never removed the IACV. As far as the intake and fumes see http://www.subaruoutback.org/forums/showthread.php?s=&threadid=8304 No codes. The fuel filter, wires, pcv, seafoam has been done in the past 10k. plugs and airfilter in the past 100 miles. The idle problems started after the silicone.
fnlyfnd replied to fnlyfnd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAs far as the flow, shouldn't the air filter and the maf screen help level that out. It also occurs when I take the top half of the air box off (with the filter still attached, of course).
fnlyfnd replied to fnlyfnd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFor what I actually sealed:
So here's the deal: My car has developed a fluctuating idle and a sorta stumble at light throttle. The stumble at light throttle has been around for awhile. I thought it was the IACV. I guess it still could be, although I did test the resistance and I did clean it (while still attached to the car, car running). The fluctuating idle developed after I completely sealed the snorkel using GE silicone II. Now, I believe, the fumes from the sealant ruined the front oxygen sensor. I think the O2 sensor was on its way out and the fumes may have pushed it to its limits. No CEL though, and yes the light does work. What do you guys think?
No resistance on IACV
fnlyfnd replied to fnlyfnd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI tested the solenoid side. Got 10.0 and 9.7 on the 2 sides. So, this isn't exactly 9.0, which Haynes recomends. But you're saying 10.0. Could this be causing the problem? Is this a positive test for having to buy a $400 part? I am thinking its a fuel problem or a wire (opposite iacv) problem.
fnlyfnd replied to fnlyfnd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI am testing the female end of the connector. The part where the 3 wires attach to the plastic clip. Shouldn't I just need a new clip or wires??
I am getting no resistance when i test the 2nd and 1st pin on my IACV connecotr. I do get 9 ohms when testing the 2nd and 3rd pin, but none on the 1 and 2 pins. What do I do?? I am getting a fluctuating idle and a rough idle (the reason why I tested it in the first place).
96 OB wheel coloring?
fnlyfnd replied to eagleb's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthe wheels have a problem with oxidizing at the bead area. Unless they're in good shape, it wouldn't be worth it. Otherwise it seems ike it would be a great idea
Personalize
fnlyfnd replied to Jim B's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI could kepp going and going, so check out subaruoutback.org lots of nice people and cars
Personalize
fnlyfnd replied to Jim B's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXand some more....
Personalize
fnlyfnd replied to Jim B's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYea, I did.
Where to find snowboard rack for 99 Subaru Impreza 2.5 RS?
fnlyfnd replied to rook's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthule, yakima, or subaru .com
What to look for in a '96 Outback
fnlyfnd replied to Dante's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthey aren't rated to tow cars and I ceratinly wouldn't. They're only rated for like 1,000lbs
fnlyfnd replied to Dante's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI dont have any rattles in my shifter. 123K new clutch and engine seals - You should also expect this as it is very common. the '95s dont have the ground clearance as the 96+
fnlyfnd replied to Dante's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhill holder or not the only outback you can get with a 2.2L is a '96 5spd
Forester engine replacement
fnlyfnd replied to Yukira's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXelectronics would be my guess. I definately recomend replacing seals etc... while the engine is out.
95 Legacy - Battery and brake light come on together - help?
fnlyfnd replied to eryque's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXbesides the shifting, I had the same problem awhile back. My alternator tension bolt broke and left the alternator belt very lose.
please take off those tire chains!
fnlyfnd replied to Spiffy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf I HAD to chose two wheels to put them on I would choose the back....just seems to make more sense. I don't know the official rule of chains on awd. Would they add more than a 1/4" in diameter? Maybe air down the 2 tires its going on....
2nd Gen Legacy Front Bumper Cover Removal?
fnlyfnd replied to RallyKeith's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXunless its different than an outback bumper the aiming screw should be only for that, aiming. I just took out my fog lights last week and I removed them exactly the way I described. You have to get down and look up at the bumber indentation of the fog hole (2 screws should be there).
97 Legacy Outback Offroading plans
fnlyfnd replied to PimpinSquee's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDO A SEARCH...haha just playin' Scorpion springs (decrease down travel of the strut which is less than ideal for offroading) http://www.renickmotorsports.com/oscommerce/catalog/product_info.php?cPath=664&products_id=1220 GR-2 http://www.tirerack.com/suspension/Susptabl.jsp?autoMake=Subaru&autoModel=Outback&autoYear=1998&autoModClar=&brand=all This is prolly what I'll end up doing, simply because its the easiest, cheapest, and most available.
fnlyfnd replied to PimpinSquee's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXforester struts wont help an obw. The only thing to do would be scorpion springs and gr2 setup.
Tire Rotation Interval
fnlyfnd replied to BostonSubaruGuy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthats why I said alignment AND BALANCING.
5W20 instead of 5W30
fnlyfnd replied to samkblam's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwhy not use mobil1 gear oil? Isn't that like the slickest oil around
fnlyfnd replied to RallyKeith's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXnah, it would be a total wasit of time to take the bumper off. There are 3 screws that hold the fogs in. Once you get down there you'll see how easy they come out. 2 screws on the top side of the front and one bolt in the back bottom.
Installing Driving and Fog Lights
fnlyfnd replied to brooksblues's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXfront bumper is toughish....do a search "driving lights" maybe. A couple people have done it. Wiring it is easy, hardest part is going throught the firewall which is very easy.
