fnlyfnd
Everything posted by fnlyfnd
  1. 20A driver side fan fuse blew again. Both of the fans turn freeely by hand. What do you guys think
  2. I constantly avg. 22mpg in my '96 2.2 5spd. New O2 and complete tune up didn't change my economy.
  3. Just an update: 20A fuse was blown, boy was I happy to see that. Although, now the question is why did it blow??
  4. Mine ripped on me about 1.5wks ago. I've been driving it w/ no concerns in the rain and dusty roads, since I am going to be swapping in a mwe axle. I don't want to go through the process of swapping the boot. It is much easier to pull 3 bolts and a roll pin to put in a new axle. My axle has ~130k on it, so a new axle should last me (I hope).
  5. My pass side inner boot ripped today. The tear is about 2" long, it just happened. I am going to replace the axle with a reman in the near future, but my question is; is it ok to drive for now ~1 week in the rain, highway, etc...?? Biggest question - Highway 4hrs in the rain?
  6. definately go w/ the 2.2 do they have a 96-99 white outback pass. fender??
  7. There is actual MAF cleaner. Just use ngk cheap copper plugs, I didn't think platinums worked well with our engine. It has been discussed endlessly, a quick search would yield good info
  8. I re-gapped my plugs, well 3 of them, the last on requires more effort. I gapped em at like .42ish. It seemed to help, I also ran a bottle of techron. I'll prolly run another bottle after I fill up with some mobil gas. Every once and a while it will stumble, but I think it's getting better.
  9. So I guess I am pinging. I relocated it, just to actually hear the pinging occur. SOB, I have no idea why it is pinging. It only pings in the 2-3k rpm range, seemed to happen more often when I floored it in 3rd gear, going kinda slow. I don't know what to do. I'll prolly bring it in in a couple weeks. What do you guys think? All possibile tune up items have been done in the past 10k (wires - oem, plugs - ngk vpower, fuel filter, front 02, air filter, pcv, seafoam, tbelt, clutch, and all seals besides HG).
  10. I'm pulling it tom. so we'll see. I've seafoamed it a couple times (intake and fuel), so carbon should be at a minimum.
  11. Its a common problem of being over-sensitive, so essentially it's not doing its job. The picture is not mine, I haven't relocated yet.
  12. Does this really work, and can it be a permanent fix. I have had a slight stumble for awhile now between 2000-3000 rpms. '96 2.2 5mt new plugs, wires, filters, 02 sensor, clean maf. It feels like the timming is being retarded, ie: lack of fuel. I was really thinking it was a fuel problem but I've been doing a lot of reading abouth this knock sensor problem. So I am wondering how safe/dangerous it would be to relocate it to the clutch bracket thing, for the rest of time?
  13. I couldn't imagine you could do anything. There is enough room for a squirel's nest in our engine bays.
  14. return the stock springs and get scorpion springs. AA is running a group buy kinda deal, $650 I believe for the EJ lift They are both going to get u about 2"
  15. just use a cheap one, no sense in putting $$ into a muffler on a non-performance 17yr old car
  16. I let the silicone cure almost the entire appropriate 48hrs (it was cold out). So, I think that the little bit of fumes that may have reached the O2 sensor threw it out of line just enough to mess with the idle. Since, I believe, the O2 sensor was already on its way out (the slight stumble at light throttle). I ordered a new O2 sensor so I willl know for sure in a few days. No, I am not just throwing parts at my car. I wanted to replace the O2 sensor when I did the reseal but that extra $100 was just too much at that time. So I am doing it now.
  17. as far as the egr....quote taken from http://www.ultimatesubaru.org/forum/showthread.php?t=35906&highlight=egr+valve - bottom of first page and I also looked in my engine bay
