Topics posted by 211
Slight overheat after engine-out head work
By 211, in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
- 11 replies
- 960 views
Will 2.5 Head gaskets work for JDM 2.0 (non-turbo Legacy OBW SOHC)
- 9 replies
- 806 views
ECU compatibility for 2000 OBW manual trans
- 12 replies
- 669 views
"System Too Rich" and all-4-cylinder misfire. At whit's end. about to take it to a mechanic
- 9 replies
- 818 views
The "new" CCR engine rebuilders?
- 10 replies
- 2457 views
Will Laptop+ Inverter + Cigarette Lighter = Disaster? 1 2
- 25 replies
- 2404 views
Bad clutch (slipping) or could it be master/slave/hydraulic related?
- 12 replies
- 1641 views
Strut replacement questions 1 2
- 27 replies
- 3081 views
Spring compressor tips for strut replacement.
- 16 replies
- 3650 views
OEM alternative CV axle?
- 19 replies
- 1399 views
Uneven brake pad wear, overhanging friction surface. Rotor too small?
- 6 replies
- 2438 views
Should I have a cabin air filter? 2000 OBW
- 7 replies
- 956 views
B-Pillar weather seal binding on window corner.
- 2 replies
- 385 views
Interior accessory light bulbs; dash, switches, buttons, etc. What sizes?
- 1 reply
- 502 views
New Timing Belt Delivered: "Important Information Inclosed"!?!
- 22 replies
- 8618 views
2.0 vs. 2.5L as replacement motor: what are the main diffs? 2000 OBW
- 7 replies
- 7610 views
Replaced RH front wheel bearing; howling only 1/2 gone. Transmission?
- 4 replies
- 607 views
trailer hitch options/reviews for 2000 OBW
- 4 replies
- 478 views
Flakey Flasher. Where's the relay?
- 9 replies
- 1548 views
slow loss of clutch hydro pressure when in heavy traffic
- 6 replies
- 680 views
'Juddering' while turning; new steering rack installed.
- 19 replies
- 7719 views
Windshield replacement cost
- 7 replies
- 4073 views
Transmission and Rear Diff Fluid Change Questions
- 2 replies
- 572 views
Semi-intermittent "Whistling/Squeeking" noise from engine compartment.
- 5 replies
- 2796 views
Exhaust Woes; Signs of a failing Catalytic Converter
- 6 replies
- 2173 views
