subiemech85
Everything posted by subiemech85
  1. M2 combine we use 5 of them to lite up the field, we also run 2 alternators, 200 amps? total we buy them from Carquest
  2. During my JY run, I saw this sticker it said air conditoned by subaru what's the meaning of these stickers? PS. I also picked up a right front t-belt cover, cap, and Factory tool kit - $5
  3. Madrid, centennial book said we are in the middle of Iowa.
  4. search shutup for my post about trans-x good stuff http://usmb.ultimatesubaru.org/forum/showthread.php?s=&threadid=6433&highlight=transx
  5. The OSRAM SILVERSTAR is the best possible choice at present for halogen headlights because it offers the highest light output. osram.com
  6. I have a custom exhaust removal system. It's better to remove than leak.
  7. Keep your brakes released, and shift @ 3,000 rpm
  8. what cars have webers for ea82? are adapters needed?
  9. Carney's 515-232-5874 or 1-800-262-3808 Ames off of Hwy 69 by B-BOPS You may pull-it-yourself if you ask. ask them where the subarus are on the aerial photograph, makes hunting easier, also ask for a current list of the cars in their "public" yard They are super-nice to work with.
  10. :banana: Went to the local JY Carney's Ames, IA $80 for right front headlight assembly, and corner lamp, heat-air controller, fuses, trim panel for around fuse box, 4WD red shift knob, owner's manual supplement and other info, dowel rod Trecel tilt-o-meter, shft knob, and 4wd knob Left 5 minutes before closing time! They are really nice.! :banana: ?How do i set up the Trecel tilt-o-meter?
  11. $20 interstate blem they remove the lable for you go and read consumer reports about batteries post 30,000
  12. I have used month old root beer left in plastic cup, worked great have also used cold, fresh beer, hot old beer, and fresh cola, all have worked it's a matter of what's available and convenient the ea81 car was washed once a week
  13. read the manual! p.68 part one ea82 http://finleyweb.net/default.asp?id=142
  14. bungee cords torque wrench, beam type socket adapters pry bars self drilling sheat metal screws gear wrenches extensions spark plugs, socket repair manual something to dissolve sticky green or white battery growth -- beer or cola, quality doesn't matter crc 5-56 best lube-penetrant found-- spra-loos at $1 stores tow strap duck tape sealing foam in the can spray silicone lube jumper cables fuses wire multi-meter air hammer impact wrench spotlight flashlight trouble light power inverter air tank adjustable wrenches chop saw cutting torch welder portapower rivet gun drillpress clamps spraypaint angle grinder press pullers battery charger battery booster you can also read the VW survival list @ http://www.cyberus.ca/~markus/vw/checklist.txt also http://usmb.ultimatesubaru.org/forum/showthread.php?s=&threadid=8160&highlight=list Jack and other on-board tool/part recommendations
  15. this guy asked about his carb icing over about a month ago.:santa:
  16. need pics and write-up bought correct plug for gm alt will run 200 wats of accessory lights
  17. search for ea81 no spark mine in sig no spark, not coil, or control module
  18. Trans-X works amazingly well in power steering systems. Metal Blue round can, big X
  19. How do the wires connect to change subaru alt. wiring to GM alt. wiring wanting to run 100+ amp GM 82 Cadillac alt
  20. 85 wagon mech. dash clock has no time display. Lights on HMS buttons work, what's wrong?
  21. found the site reading a google cache archive http://home.brisnet.org.au/~cameronn/
  22. I want at least one Large I would like black, white, or gray preferred one of each if not too expensive
  23. ?how to test the functionality of the heat controller -- vac. operated. mine seems to not work, but every thing else does:confused:
