junkyardgabe
Everything posted by junkyardgabe
  1. these are for my brat which i have done the ea82 rear disc too. so i'm not worried about the fronts i know they'll clear. thanks for your help
  2. will an ea81 wagon wheel fit over and ea82 rear disc brakes set-up with no mods?
  3. so beside being stronger could you replace it with a non-turbo or does it also have a diff. gear ratio to
  4. are the 92 legacy turbo automatics tranny any dif. then the legacy non-turbo ones and if so what are the dif.
  5. will 96 legacy wagon rear struts fit a 96 impreza wagon?
  6. what my problem is when i start it on cold morning it's ticking pretty loud until it warms up and then its practicly none existant until the next morning it hasn't got any worse in a year (15,000 miles) i took it to the dealer and they said it it was either a rod bearing or main but why would these quiet after warming i would think they would get loud once the oil thinned out any clues anyone:confused:
  7. i was wondering if my 97 subaru impreza with a 2.2 has hydraulic or solid lifters?
  8. The key to my 97 Impreza L is stuck in the ignition. It can turn and all, but it seems as if the shifter won't go all the way into park or something to release it. Any ideas, or similar stories? Also, the trunk may be stuck shut too. This is a new purchase for us, so I haven't gone all through it. But that is what I've seen so far. Any suggestions? Katrina
  9. Just wondering if anyone has researched this before? Thanks in advance for any tips you may be able to provide. (Katrina)
  10. Does anyone know how to reset or bypass the factory security module. I have a 97 Impreza L that will not start. (Older cars are my thing!) There is clicking in the dash when trying to start it, that's about it. Any ideas?
  11. who would have been making brushgaurds about 5 years back in california i picked up a brat last week and it came with one that someone had made.the guy said he got it from someone on this site within the last five years or so.
  12. $37.95 ain't that bad of a price for headlight covers:)
  13. there 27-9.5-15 super swampers and i did have to trim the fenders a little bit like a 1/2" on the back of the fender and i just folded the corner up in the front. i didn't have to trim the rear quarters at all:cool:
  14. YAYAYA i was wondering who was going to ask? just before i went to take the picture that side fell off. GTS MADE THEM PART #GTO751S 84-88 monte carlo ss are the same exact shape i found out but the # above is the subaru # FIT'S QUAD HEADLIGHT 83-92 IF THAT HELP'S ANYONE:cool:
  15. this is what i want to put for a plate on it?
  16. the wheels are eagle 589's and that is a 3/3 lift thank's
  17. here's some new pictures of my brat it's almost ready for the road:cool:
  18. don't scare us like that !!!!!!!!!
  19. the widest i've run in a 13" is a 205/60/13 and it cleared everything fine
  20. come to maine this is ea82 country up here you can't go around a corner with out seeing one i just saved a rust free 86 ea82 3dr 4wd auto. tranny with a blown motor that came into the yard and a rust free 88 2wd ea82 wagon that was a one owner car so just keep looking. look high look low subaru have a tendancy of hidding in the strangest place's:brow:
  21. you've only got a few days before the alt. craps out on you and a pair of tires should run you more than $25 i would think 13" aren't that exp. any way for new ones
  22. you could have a broken brake pad clip that keep the pad from rattling
  23. their not to bad to replace because some of the one i've had to change the oil on i could get the clips out or they were screwed up some how so we would have to take the whole skid plate off to change the oil the hardest bolts to get to are in the wheel well area:madder:
