Everything posted by junkyardgabe
Leather ve Cloth seats?? Which are better
junkyardgabe replied to ssweb's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXgo for the leather it just gets more comfortable with age were cloth you just keep sinking and sinking and sinking...........
You guys are INSANE!!!
most states here you can't legally get away with it but we do:burnout: where there's a will there's away just got to push everything to the limit's:brow:
does ea82 carbed have two fuel filters?(now fuel pump question)
ya just one their not like the EA81 which have two:cool:
I'll be wrenchin all day if you can stop and help/hang
your not allowed to delete post any more mod. are only allowed too
Weird axle failure - pictures too *Updated*
ya that suck when people try to get out of things cheaply because their just ruining their business over be cheap
difficulty of lift installation
compared to most body lift that was one of the easiest one's i've ever done.i did mine in just under 5 hours by my self and i found the rear to be more difficult. because the front if you leave the farthest to the rear bolt just loose it keeps every thing inline and don't over tighten the 6 engine cross member bolts you'll crush the front frame rails if you do. good luck:argue: don't beat your self up to much:madder:
Dude, everyone needs to take this quiz!
i don't want the sti i want to be an 80's subaru if you play it right you can also be an h-6 LLbean wagon
Pictures of my TWB fab bumpers on the wagon.
looks pretty cool are you going to put that grill & headlite asb. on that or the brat
radiator fan
the whole fan assc. $10
radiator fan
more than likely that is just for the motor but that still cheap
got the RX started.. FIXED! Trivia time!
ya you did the head gasket but did you check the compression? just a thought
ping ping ping...No wonder!!
eeeeeeewwwwwwwww! that's not good !whats a rat live under there?
OK, so the new engine is in, but I messed up the electrical
it sounds like you have a bad connection some were your best bet is to leave the key in the on postion and go around and start jiggling wires around near your fuseable link box first they like to corrode under the box then double check all of your connections under the hood
Need help with grill ID
that is definatley 80-81 with the single square headlight i have the same exact one in front of me that subawoohoo just bought
what wheels will fit my '78 Brat?
Qman had a set of jackmans in the market place for sale that would fit it which is the white spoke of that time
Oxygen sensor?
they reccomend that you replace them every 50,000 mile's as part of the tune up
Electric Fuel pump problem
have you checked all of your fuse's my the horn fuse would blow and it would cut power to disty and fuel pump odd?
cat. converter question
does anyone know if a front cat. converter from a 97 legacy will fit a 99 legacy thanks for your help
t-belt covers: yay or nay
find a way to put them on unless you want to change timing belts on a regular basis timing belts hate weather
Downshifting into 3RD...
what i had to do when that started to happen with mine is shift from 4th down to 2nd then back up to 3rd that and around that i couldn't shift into 1st with out coming to a complete stop which sucked
3AT Regulator Gear for '87 GL10??
you'll want to check the inside first but they should still sell them last i seen they were $30-35 for a new one i can get you coulpe if you'd like $25 shipped
i just got the cutest purse
oh how sexy!
Oil is dissapearing...not so bad now, but driveability issues now!
go to napa and by a bottle of leak dye for oil put it in your oil and by the sounds it will show up after 4or5 miles you will need a black light to see the dye but it will be obvious:cool:
oil pan woes..
ya usually when some meat heads change the oil they forget the gasket and then crank that plug in which make it like its welded on.any of the lubes should be able to suck it dry with their rear diff. evac. systems .that cars had a hard life at the lube guys hand by the sound of it.hope your luck starts to go the other way with it now :cool:
Rack and Pinion ?'s
easy if its not power steering but still not diffcult with it shouldn't take you more then a couple of hours
