junkyardgabe
Everything posted by junkyardgabe
  1. dang that looks like someone took a ballpeen hammer to it
  2. sounds like the ignition module quit
  3. for those of you with that have the high top cap like mine the rear door shocks are the same from an s-10 blazer rear glass just to let you know my cap
  4. they are easy to change nothing special needed to know and nice brat
  5. what are you looking to spend i'm going to maryland next month and i could probably tow it back for you if the price is right!
  6. what did someone back into something and just slapped in a new taillight but that is in pretty good condtion for what you paid cool:cool:
  7. to make this even easier just buy this fan relay it's easy to install fairly cheap and you can run daul fan with different temp setting this is what i use on my v-8 s-10 blazer and works great fan relay
  8. how many miles are on the subaru it sounds like blow by
  9. have you tried spraying carb cleaner around to see if you have any vacuum leaks
  10. i just put a set of four of these in the market place last night
  11. if you can find a set for a monte SS they are the same exact as the brat one's and will fit any EA81
  12. its not to bad i shipped two 14" pugs to McBRAT in iowa and it was only $40 and a extra $10 for boxing
  13. i was running around this new j/y i found a couple of month a go going through their bus's and trailer's have full of stuff i was in this one trailer i went down to the empty end of it just to look and out of the corner of my eye i seen something chrome so i looked under the shelf and found these http://usmb.net/gallery/Subafied/000_0181 http://usmb.net/gallery/Subafied/000_0182 http://usmb.net/gallery/Subafied/000_0184 cool huh?
  14. it to bad every one else couldn't make rear brakes that simple to change
  15. i thought you had miss read that miles!slow down:D
  16. i'm 6'2" and i like how i fit in any subaru i think theres more room in a rx over a xt and i'm 325lb so if that isn't an example for ya i'd don't know what would be
  17. http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=46098&item=2458487455
  18. does any one run headlight covers on there ea81 and ea82 with out composit headlights were can you get them
  19. if you keep pulling it should come up but if not if you pull your glove box out you should be able to reach the plug the led is probably messed up alot of mine have done that to
  20. if you do this you have to also change the rear diff because of gearing is different the only one's that will interchange with a 91 is a 90 or 91 . 92 they changed the gearing
