Everything posted by junkyardgabe
Finally, new exhaust
watch out low passing exhaust just kinding:D
Front suspension question
that would be the cheapest way and the quickest !
EA82 knocks when cold
or take a long screw driver and stick it to the valve cover and place your ear on the other end then the same in the center of the block and you'll be able to tell which one it is
if you have a impact gun then the rear should take about an hour the front if no bolts break it should take about 1-1.5 hours that and you will also need a spring compressor to do both
Attn PK Davis...
don't worry if it take's a little time for him to get back to you he's usually pretty busy so be patient when e-mailing him
What might this XT be worth?
considering mile and it being in florida and being 4wd i would say probably about $2000-$2500
ball joint or bearing?
the reason it won't make any nose when it's in the air is cause there's no pressure on it but i'd try the balljoint first because the balljoint could be shifting when you turn the wheel
Good Tool for your Junkyard tool bag.....
any of th EA-81 or EA-82 axle nuts
Newb question about a fuel problem...
sound like your choke isn't opening enough or one of mine had a crack in the ignition module so it would run but as soon as it got any heat it would die and would start again until it cooled
have you just tried going to a thinner oil and it could be from someone running it low once
rear shocks in lift sube
has any one treid using a set of coil over helper shock in their lifted subaru s-10 seem to be the right dimensions and length the only thing i see you would have to do is drill out top to holes or use smaller bolts
ea81's.. why'd they change em
i've owned both and i didn't see any power difference. plus with the slight increase in hp is compensate by the increase in weight.not to step on any toe but i'd take either ohc or not their both great cars
found something to drool over.. pics added..
send that thing up here it's old enough herethat it wouldn't need a title and it doesn't look like they'd miss it much
all the bad head gasket i see are on ohc timing belt motor and subaru had to do something to get work back into their garages beside exhaust and cv joints
rough idle. sounds like a cylinder is "dead"
be careful when you grab them wires cause you might find a wire and get what it's got
Silly EA82T coolant problems
if you really want to find that coolant leak go buy a bottle of leak detector from napa and run that through your system for a day. then you'll need a black light where ever there's a leak it will show up as a florescent yellow and go from there. the bottle of stuff is only about $2 or $3
Power Window Problem
i'd change the window switch just to see. but like mine the main power wire had kinked and when the door was open the window would work and when it was closed it wouldn't then it finally stopped working totally if thats any help?
Engine oil
mobil one is always a good idea unless you have oil leaks because it will find them quicker then regular oil and will make those leaks worse .if so just go with a 10w30 during the winter or put a block heater in
Aftermarket Fuel pump's that help Weber's
napa's got a universal one that run's at 5 psi and is like $30-35
lost keys need locks and ignition now..
just pull a door lock and take it to a locksmith they can usually make a key in minutes and cheap as hell and that'll cover all your locks
hazard melting fuses
:-p
P/S pump is noisy........should I replace?
if you do replace the pump try and find a 90 or newer loyale so you wouldn't need a puller to get the pulley off
if you don't have time to find it you could put a breaker in place of that fuse
This is sad...
that and always make sure the filter gasket doesn't stick to the block or you'll be sorry
I hate subaru dealerships part 2
whats a matter with your door locks have you tried going to a locksmith they can usually fixs anything or rebuild it fairly cheap
