Everything posted by SOOBOUTLAW
My next project car!
Is that the one on Craigslist?
Installing a WEBER
No fitting on this one. Got breather filters from Schucks. Looks like mushroom filters hooked up to the hoses.
Installing a WEBER
there are no breather hookups on the air cleaner cover!
Installing a WEBER
We're putting a Weber32/36 electric choke in Hatchy's rig. We are ripping all the emission junk off, and plugging whatever. What to do with the fuel return line? How bout the crankcase breathers, put filters on the valve cover ports?
pimpwagon alert?!?!?!
I drove home on two cylinders from a blown HG once. Water sprayed out the tailpipe like a hose.
possible area for me to offroad...maybe
I went up the Mountain Loop Highway with my wagon and went past a no tresspassing stencil on concrete block up on a gravel road, got stuck good, then forest service guy comes by and asks if we're ok, then leaves, not even trying to get his "Exploder" to where I got stuck. Wimp.
EA81 don't run right
F It. Motor Swap Saturday.
EGR seems to be hooked up fine. Dunno if it works yet, might swap off another motor I got laying around. The vac lines have been messed with. I rearranged some to where they should go, I hope, using reference off the other motor.
dirty fuel tank
I have three vehicles, so three tanks. One vehicle has diff swapped out into another, so that'll be the easiest. Other vehicle needs seals on swapped diff, so I'll pull the tank when I pull the diff.
My EA81 won't run well for some strange reason. It doesn't want to idle or the rpms fluctate from sputtering to 3k, then sputter, then 3k. Fuel pump is good, just changed carb with no change in attitude. Blew out fuel lines, nothing. Any ideas?
dirty fuel tank
How do you clean your dirty gas tank? I've just been draining the fuel and blowing compressed air through the lines. I'm thinking of removing the tank and really clean it out with kerosene.
RX --> Brat
Uhhhhhh... need to buy more cars for 'experimental use only":brow: .
trailer hitch on an ea81 hatch, how strong??
I have this rear bumper that came with my '80 wagon, I think it's AM or homemade, but baby is SOLID! Backed into a tree stump with a bang, no damage except to the stump where the protruding hitch plate is. Never towed serious with it yet, but it's a cool bumper.
Look what I found.....
The flares look like from a '90's Nissan truck.
Clutch Cable Snapped... Yikes!
Done that quite a few times. In the same car. Still got it.
Just bought a Brat
Just a little more rust than I thought...
Just bought a Brat
I just picked up an "83 Brat with canopy, t tops and jumper seats for $900. Needs carb work and muffler, but it's in decent shape.
Anyone rig their lights to a toggle switch?
Yup, electrical gremlins.
How long to wait before.....
You don't wanna get caught messing with a hot car....possession of stolen property, even if you didn't jack it.
new urathane bushings ??
I wish I had a lathe.
How is your old motor doing
That is the first time I've seen anything about an engine piss test.
'83 GL wagon project
I'd like to do that. Also, I would like to modify the body. Hatchback doors are exactly 12" longer than wagon doors, so I'm thinking of a two door wagon, flared fenders(all steel!), wide dished rims and fat street meats (no rubberband tires). T-tops.
I have this wagon I bought for $240 in January, borrowed the suspension and driveline for my trail rig. The front end is kinda mangled ahead of the strut towers. I want to cut it off and put a new clip on eventually, when I get a MIG. But, I don't want to stop there. I'm thinking of building a hot rod out of it... I wonder what Boyd Coddington would do to a Subaru:brow: .
- Doorless?
Loyale Painting ideas
Primer Gray:cool: .
