Everything posted by SOOBOUTLAW
Loyale/GL cupholders, Lets See Em'
I took the back seat out of my wagon for room for two full size spares, and the space behind the console between the front seats comfortably holds two 22oz bottles of....
Lynnwood PAP update
PAP didn't have any EA81 4WD:mad: ! Only 2WD.(as of wed.)
loud clickin all of a sudden
With parts off of MY parts car.
Wheel bearing oil seal
How are the seals supposed to be installed, flat side out or flat side toward bearing? I've seen it both ways.
More Heavy duty struts
The coilovers are on the rear suspension of the EA82 vehicles, as opposed to the torsion bar rear suspension you have now. What do you need "coilover struts" for? The spring is around the strut anyway. Get a heavier spring.
Disty + Water = uncool
Always have a can of WD 40.
Bad wheel bearing will cause the rotor to drag the pads.
HATCHY IS A NOOB!!!
do cvs click only on turns?
My rig has made all kinds of sounds over the years from squeeling wheel bearings to crunch clang bang BAM BAM! Especially when my front diff was going out, or my front CV fell apart and rattled around for two days before I found the prob:grin: .
pieces of subaru youve left on the trail?
And my brakes three times. THREE!!! And the E brake didn't work once either, and I still drove around:grin: !
I lost a muffler once, but on the street:eek: .
Rear diff swap?
Hummer sucks, I've seen 'em in action. Subaru is way superior.
A psycho boxer
You were gonna do THAT with a sawzall and a 99 dollar welder!!??:-\
EA71 to D/R 4wd 5sp
My JDM low mileage EA71 came with a bellhousing and flywheel for a fat case. It's now coupled to a D/R 4 speed with 3.90:1. Used to be 4.11:1 single range.
Where do I get the dual weber carb setup
A 40mm DCOE downdraft would be cool.
Underbody coating
I'll try chevron supreme.
Underbody coating
Some idiot sprayed underbody coating in the wheel wells of my parts car. On the brake line fitting, bolts, nuts:mad: ! What's the best way to get it all off?
I remember a few years ago I came across a site called soobspeed. I think they had kits like that.
dune running?
My bro in San Diego runs an EJ powered sandrail at Glamis.
Anyone seen one of these?
I went skiing there at 49* North, it's a ski area north of Spokane. Skiing and Subaru!!!
Reiter pit
Hatchy has one or two pix on his phone.
Doorless?
I think there are different laws for cars and trucks, but I'm not sure in WA.
going from big to rally style
I had my wagon RWD for a while. Went through a BIG stack of tires with the front parking brake(line lock). Powerslides !!
Speedo fix for oversized tires
My speedo cable has been broken for a while. I don't plan to replace it any time soon.
Serious axel problems
It's lowrider (bone stock, no suspension adjustments yet).
