237
Everything posted by Loyale 2.7 Turbo
Yes, but those RX and RS are Sedans, and came without saying "Loyale" on their door's moldings, only "Subaru" or "Leone", Since it is Supposed that the Name "Loyale" existed after 1990 only. But, this is a Turbo coupe, Not a sedan, and is pre-1990 ... That is why it is very Rare, saying "Loyale" it seems no one has noticed that, but me... Kind Regards.
Kia Sephia Sporty
Loyale 2.7 Turbo replied to Loyale 2.7 Turbo's topic in Non Soob Cars and Bikes Discussion
Now I only need to Obtain both Backin' Plates, brand new Because Rust eat 'em at the Junk Yard. This are their Numbers: -
Kia Sephia Sporty
Kia Sephia Sporty
Kia Sephia Sporty
Kia Sephia Sporty
Let me Share some Photos of the Parts Sent by Mr. Robert (Gottacruise) -
Kia Sephia Sporty
Well, after some time waiting, Mr. Robert wrote me an e-mail, he had to obtain both left & Right Calipers Brand New, because the ones from the Junk Yard were seized, rusted beyond possible Repairs. Also he Disassembled and Cleansed everything, prior to Shipping; and send me Photos of the Complete parts' inventory! Thank you Mr. Robert, you're Awesome! The Shipped Box, which almost weighed 80 Lbs, is on its way... -
Sorry to read about the accident, I hope you will be Alright soon. This thread needs more progress photos... Kind Regards.
Hello from wenatchee
Loyale 2.7 Turbo replied to Leitah's topic in Meet n' Greet. Your USMB Welcome Center
Welcome! We love Subaru Photos here, wanna upload some? Kind Regards. -
If it has the Nippon Denso Distributor, then it will be No Screw, but if it has the Hitachi Distributor, yes, a tiny screw... and seems like it is Hitachi because you wrote that you can't pull the Rotor. Have you checked if there is a broken Timing Belt? Kind Regards.
weber stumble at wot
Loyale 2.7 Turbo replied to scubaroo84's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Believe me, I ran my "BumbleBeast" without the Return line nor the Fuel Tank's vent line hooked for a Decade (then I reconnected it); both were Hangin' down, next to the Brake's Booster and that completely avoids high pressure build up on the tank, also avoid fuel starvation. I kindly suggest to try running a straight fuel line from a single outlet fuel filter to the Weber carb, and let both tank's lines (Return and vent) unhooked for Testing Purposes; also you might want to drive during the test, without air filter, in order to be Sure that those are not the causes of the issue. Then let us know the Results... it is easy and worth try. Kind Regards. -
On the EA82 engines, you can advance the timing further than stock specs when they has a Weber carb; in fact seems like they like the advanced timing when they has a Weber. I went as far as 22º despite that the Stock timing should be at 8º, but I run my "BumbleBeast" @ 20º; now talking about the EA81 engine you have, I bet that at 8º the timing will be somehow "Retarded" for the Weber... So, I kindly suggest you to try advancing the timing, instead of retarding it; try it at 18º or around that and give us feedback. Also, I only run a single outlet fuel filter on my "BumbleBeast" and the return line isn't hooked; in order to avoid fuel starvation during high acceleration moments, in example: Passing another car on the Highway or going uphill loaded. Maybe you can try to close the return and see if that changes your engine's acceleration behaviour. Kind Regards. -
Yes I Agree... Flooding instead of Lean; but also seems like the Ignition Timing is not set properly; so I kindly suggest you to check the Timing / move it 'till it develops better performance. Kind Regards. -
Have you checked if the Ignition Coil sends power to the Sparkplugs? Maybe the Weber just got Dirty... Have you Tried with Carburator Cleaner?
Does it Crank or is completely dead? If is completely dead, check for Fusible Links. If crank but not catch, it could has: Low Gas / No Fuel Pump Running \ Burnt ignition Module. Give us more details to properly help you find out the issue. Kind Regards.
Thank you for Sharing those part Numbers. Remember: as I described on the Writeup, I used the Front Coil Springs from a Junk Yard's Tempo, so they were not as stiff as the Brand new ones; other forum members used the Coil Springs for the V6 Automatic + A/C tempo, which are too stiff for the Subie... they had to cut one and a half turns from them to fit. I Kindly suggest you to read carefully the Writeup. Kind Regards.
Hey ... you can download your copy, look for the link on my shared files! According to the Laws of my Country, it is not piracy to share digital copies of items that are no longer available in their original version, as long as you don't obtain any profit from them, nor damaging the copyright owners rights. So, I only pasted a Link found online... I'm not obtaining any profit, and that book is obsolete. Kind Regards.
- 171 replies
- Loyale 2.7 Turbo
- Rear Park Brake
- (and 8 more)
Nope, I Can't ... that is for my Own Readin' pleasure. I'm trying to save my eyes from too much Screen Light... Kind Regards.
- 171 replies
- Loyale 2.7 Turbo
- Rear Park Brake
- (and 8 more)
