237
Everything posted by Loyale 2.7 Turbo
Subaru must have been nuts!!!
Loyale 2.7 Turbo replied to pheonix165's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If your Subaru is Front wheel Drive only and 5 Speed Manual trans, Then your Readings are alright: They're intended to Stay Low from Factory, for Fuel economy. Kind Regards. -
There's No Need to use a "Tee" Nor to Share the Vacuum advance Port with the EGR, because the Weber 32/36 (I assume you're installing that Model) Has Two independent vacuum ports in Front, One (The one that comes Open) is for the Vacuum advance while the another one (The one that comes Blocked with a tiny Screw) is for the EGR. To use it, just unscrew the Blockin' screw and hook the EGR to it. Kind Regards.
I need new tunes....assistance please
Loyale 2.7 Turbo replied to dudesmccool's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Thank you! Well... the Head unit is a Sony Xplod MP3, easy to Use and Powerfull, well, Just 52 Watts per channel (52 X 4 = 208 Total output) Powerin' the 6½" Speakers all around is enough for me to Listen my Favourite Iron Maiden Songs :headbang:along the BoomBox, which is Self Amplified; it has all the Harware Built in, but it takes its Music source from the Head unit's dedicated "Woofer" output. I listen Heavy Metal only when I'm Alone... Usually I play Baby Music (Lullabies) when I Transport my Baby Daughter... Kind Regards. -
No. Nope! Loyales came Factory with 4" Front Speakers installed on some sort of 5" metallic adaptor to the Door, While the Rear Speakers came 6½" installed directly to the Door. My Wagons Run Front and Rear 6½" Speakers, I installed the Front ones over the Door Plastic Panel to let them Fit Better, as you can see here: Also I Run a 12" Dual Speakers "Omega" BoomBox that came factory with its amplifier and quiet Cooling fans Built in, in the Rear, as you can see here: Kind Regards. -
Holy Cow! I Really Like the New FB engine Design, for Sure; it Looks like a Wonderful Bulletproof engine that brings back Memories from the EA81 era. The only thing I really don't like very much, is the Car Body that Wraps around that engines... I Miss the Frameless windows with all its advantages and Disadvantages, that designs were Clean. Newer Designs not only has frames but also interruptions on the "Crystal flow" I Know that is to bring the Cab Forward, but I dislike that. Except the New Subaru BRZ: I Really Like it!
Been gone awhile, here is the latest
Loyale 2.7 Turbo replied to True2Blue's topic in Meet n' Greet. Your USMB Welcome Center
Holy Cow! That is a Serious Lift! ... Could you give More Details? I'm Glad that you have a New House, it is Really Beautiful... Kind Regards. -
Subaru sold the last leftovers of Brat bodies in Latin America, with EA82 and front wheel drive transmissions, in 1994. ~► http://www.ausubaru.com/forum/showthread.php?t=23162 Kind Regards.
Thank you... I already know that 215/65 R 15 Tire will be 26" ... the information I need is if my 2" lifted Wagon will have enough space for those tires without Trimming nor Rubbing. ¡Bien, Gracias! Well... Babel fish works somehow like the Google Translator. You're Welcome to my Beautiful & crazy Country, I hope that you'll Like it! Please, let me Know where you want to Stay, so I can go visit you with my BumbleBeast Subaru Kind Regards.
Need a little bit of help on this one
Loyale 2.7 Turbo replied to Subaruby Doo!'s topic in Old Gen.: 80's GL/DL/XT/Loyales...
The ones for the Quad Headlamps Models, like the EA82 DL in the Pic Below... ...has their Mounting arms placed way forward and doesn't fit on the Single Headlamps models. Kind Regards. -
So, I Assume that those Vacuum acumulator Bottles shall have a Built-in Check Valve and if I Ran it mistakenly connected backwards for Long time, Maybe I damaged it... Right now I am away from that Bottle (Left in Home) so I Can't do the Test properly, but I did a Small test when I removed it and found no Check Valve interruption then. I'll Repeat the Test more carefully ASAP. But I'll Like to know: How did that Vacuum acumulator Bottle came connected from Factory?, Shall I Use the Port Number 1 as vacuum in (From engine) and Port number 2 as Vacuum Out (to the Dashboard) or it is Backwards? Kind Regards.
Loyale 2.7 Turbo replied to 6 Star's topic in Old Gen.: 80's GL/DL/XT/Loyales...
So sad that I Live Too Far and it is Very expensive, But I Like This one, actually For Sale on Craiglist: -
Kia Sephia Sporty
Loyale 2.7 Turbo replied to Loyale 2.7 Turbo's topic in Non Soob Cars and Bikes Discussion
These Round 6½" Speakers went to the Front Doors: Here you can see the Old Stock 6½" Speaker, Hangin' from its Wires Harness: -
Kia Sephia Sporty
Also, I obtained Four New Speakers... Here you can see the Old Stereo unit and the New Main Pulley, along the Speakers. Those 600 Watts Huge Speakers are for the Rear install. -
Kia Sephia Sporty
Which I Really Like because it not only is Powerful and extremly Easy to Use: it also has Shortwave bands, such as SW1 and SW2, Useful for Real Long Trips, Basically is the Same Stereo I installed on my BumbleBeast Subaru, but that one is Light Grey with Colour Display. (this one is Black with White Display) Easy to use MP3 and WMA CD's -
Kia Sephia Sporty
So I Obtained a Brand New Stereo. -
Kia Sephia Sporty
When I Swapped the Engine on my Wife's Kia Sephia, I took the opportunity to change the engine & Automatic Transmission mounts Nº 1 and Nº 2 from the Four it has: Here you can see the Brand new Sparkplugs I installed on the Fresh engine: Nippon-Denso's U-Groove. Yes, I broke the Chair too... -
Kia Sephia Sporty
The Electrical tape held there for enough time... So I Obtained a Good Resonance Chamber at a Local Junk Yard and swapped it: Also Cleaned all the Air Filter Chambers and Hoses... ...plus installed a Brand New Air Filter. "Made in Polland" -
Kia Sephia Sporty
The New -To Me- 2003 Spectra's T8D engine works Flawlessly, Strong and Smooth as Silk on the 2000 Sephia; my Wife and I are more than Satisfied with the Overall car Performance, which now has been named: the "KiaStein" I Sent the Radiator to a Local Radiator shop in order to change its Old Plastic Tanks for a New metallic ones. Those are Made from Aluminium: -
Kia Sephia Sporty
interesting that they said "TSD" when is "T8D" -
Kia Sephia Sporty
My Wife's Kia just started to have this issue: Sometimes you Turn the Key and Nothing happens, until the third try or by letting the Key in Start Position some seconds. Sounds to me like I Will remove the Starter for service soon... _____________________________________________________ UPDATE! I Found a GPS + GSM Vehicle Tracking & Disabling device Hiding on my Wife's "KiaStein" That was the Culprit of the Delays on Starting. Please read further info & Photos of the Device in This Thread: ~► http://www.ultimatesubaru.org/forum/topic/131888-my-wifes-car-has-been-monitored-with-gps-without-our-permission/ Kind Regards. -
Somehow I Confused the Vacuum Lines that goes in and out the Vacuum Bottle that is Located under the Windshield's base, behind the Passenger's Strut Tower on the Engine's Bay. Basically, one Line comes to the Bottle with Vacuum from the Engine while the other Line goes from the Bottle to the Vacuum operated control A/C Buttons on the Dashboard. So please correct me if I'm Wrong: The Vacuum Line that comes from the Engine Must be Plugged to the Vacuum bottle's Port Labeled as Number 1 and the Outgoing vacuum line from the Bottle must be connected to the Bottle's port labeled as Number 2, isn't it? I just want to be Sure... Kind Regards.
