Loyale 2.7 Turbo
    238
Everything posted by Loyale 2.7 Turbo
  1. First of All: Welcome !!! Second: I`m not Sure about your Car, Maybe it is a damaged movin` part from the Steering, or maybe something got loose... I suggest you to check it Carefully before Drivin` too much. Good Luck!
  2. Check carefully all the Vacuum Hoses, where they come from / where they go, `cos some of them are critical in Hitachi carbs. For example: the secondary stage on a Hitachi is activated by a Vacuum, if you don`t connect the correct hose there, you can finnish with one of this Three posibilities: 1) A permanent Vacuum = Always acceleratin` to Redline. 2) No Vacuum = No Secondary Workin` so, your car will become Slow and Unpowered. 3) Wrong Vacuum = May activate the Secondary in the Wrong Moments... ...And that`s the posibilities with just one of the many vacuums of the Hitachi... Are you Sure that you`ve Purchased the Right Carb. for your Subie? `cos slighty Different Carbs. can perform poorly... (I tried with a Nissan one... It was a Nightmare!) ...or suck much Gas... Be Careful. Maybe in the Future you Can obtain a Weber... is Better Idea. Weber = No Vacuums (Execept for the one that goes to the Dist. Vacuum Advance) Good Luck!
  3. Well... it sound interestin` I Agree with the Subaru as One Car For Forever, but I do Preffer the Loyale Wagon... ...Also, I wanna Add that Subaru did appear in too many Cartoons, I don`t remember now all, but I remember the 360 in many cartoons... Or the Impreza that won against Takumi, in "Initial D" Anime series of Japan. (the Impreza is of Takumis` Dad) You can see it Here: http://www.youtube.com/watch?v=PsifHojhLNs Or the 360 in "GetBackers" : http://www.youtube.com/watch?v=cpKjBrkCBM8 Also, everyone Gotta Love the Brat, even in the Simpsons show has appeared one: Yes, most People drive "Rollin` Hazzards" Here in my Country... I do Preffer my Subarus...
  4. I wanna see those Pics and Video, but link Doesn`t work... Do you have a Workin` Link? Thanx!
  5. Just to help... I have a friend that got a Hatchback Subie EA81, who has fab. solid engine mounts, and the car became with a weird fellin` almost like you`re drivin` some old VW Beetle... Vibration is high, but also a li`l noisy. He is waitin` for the new mounts to come at the Dealer this December. The fact is that you can drive it with solid mounts, but then you`ll be bored with So much Vibration. Good Luck!
  6. For sure it will be a Nice Great Engine! ... Please, update with More Pics!
  7. ...Yes, with the Right Adaptor Plate... ...And Hard Work! ...
  8. Thank you all for your kind replies, I'll contact SJR now, to ask about a 1½" Front Blocks
  9. Why a two seater Plane, when you can get a "Flying Subaru"? With those 200 wild horses of power, and a Lightweight Brat, you almost fly... Or you can put Wings on your Impreza...
  10. So... Which NGK plug is Better for a EA82? the BPR6EY-11 with the "Y" electrode, or the regular one? On this 21+ years of owning (was my dad's First) my EA82 Wagon, I have used a lot of Spark Plugs, From NGK, to ND, to Champion, Bosch, Beru, Etc... but the NGK gives me better Performance, but I never used the "Y" version of `em... so, Any experience with them will be Welcome! Thanx!
  11. WD40, Marvel Oil, or similar brands should work there as Jerry said. I suggest to take the cable out, and clean it strongly with that penetratin` oil that repels moisture. Good Luck!
  12. Well... I was thinkin' on maybe using Just 1½" Blocks for the Front Struts ... Do you guys think that the Subie will take an added 1½" stress angle on the Axles, without eat 'em fast? Which other Issues will happen if I install 'em? Thanx!
  13. Usually, a Rusted Clables / Contacts on the Main Fusible Links (That`s the Black rectangular Box, in the Coolant Reservoir, near the Battery) can do that, even with a good Battery. I suggest to Check `em Out. Good Luck.
  14. For some reason, some information about subarus is almost like "Hidden" on internet, or unreacheable... I suspected that our Subies with Loyale Bodies (EA82) were made in japan since early the 80´s, when I Accidentally crashed the Glove box of our 1985 White Wagon EA82, and the plastic behind said in a circle: "year of manufacturing" and it said rounding it: 82, 83, 84, 85, 86. And then, I saw This: What do you think about? Also I know that subaru has selled Diesel models (On Justys - with Suzuki) since long ago in Latin America... and there says nothin´ about... but Well, that´s another story...
  15. On Loyales, FWD Front Struts are Lower rise than AWD ones, so YES!, it´s the Way to Go... Good Luck!
  16. Is it Carbed? if so, it´s the Carb, almost or Sure. Try clean it.
