Everything posted by msmithmmx
Failed Inspection : Updated
msmithmmx replied to msmithmmx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI changed the rotors, pad and e-brake shoes, what a mess. All of the listed parts where completely shoot. I am a little embarrassed I let it get so bad. There was nothing left.
Some questions to better my subaru
msmithmmx replied to seth3030's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes, thats drain and refill, twice
msmithmmx replied to seth3030's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFor the trans flush, each time you drain you will need 4.5 quarts. I suggest you drain , drive a few miles and drain again. Shift it through all the gears while in the driveway.
Wheel Bearing Question
msmithmmx replied to msmithmmx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt does read as..... "Prepare the new tapered roller bearing for installation. Do not remove the bearing stay (plastic piece inside the bearing) at this time" Note: Do not disassemble the bearing. Do not add any grease to the bearing.
I purchased the front wheel bearing OEM for my 98 OBW. It looks packed! should I use the factory greese or is there something better out there?
Ball Joint Replacement
98 OBW 190K, I am replacing from driver side wheel bearing and figured I would do the ball joint while I am there. I am using a aftermarket ball joint and there is no grease in the rubber grommet. What grease shoud I use and how much?
I'm sorry, skid on iced road and hit a tree
msmithmmx replied to rverdoold's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXKnowing that you are OK, I will be the first person to ask. Are you selling parts from it?
msmithmmx replied to msmithmmx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI am doing the work myself. There is no way they pulled the rotors off to check the shoes. They pulled the lever and got nothing.... Work starts tommorow on this car. My guess is 2 nights after work should do it. on my list of things to do all they wanted to do is replace the front tire. I am addressing the wheel bearing because it has been making anwefull noise for 20K miles and I sure is the cause of the inside of the wheel being bald
msmithmmx replied to msmithmmx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe end on the cat side is so thin from it rusing away it will not pull tight enough. I need to install a replacement flange. DOES IT EVER END
msmithmmx replied to msmithmmx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat could be next, I have a leak at the spring joint that I can't fix.....
I failed the PA State Inspection today here is the list. It cost me 31 bucks to fail and I have 2 weeks to fix it all or I get charged again. Just venting. My 98 OBW has 190K 1) Need new back brakes (70 bucks with rotors) 2) Need new parking brake shoes and adjustment (70 bucks) 3) Front left Wheel bearing (100 bucks) 4) Front left tire (ordered, 71 bucks) 5) Need duplicate vehicle regestration, because I lost mine (7.50)
EJ25 to EJ22 swap in progress. IT"S ALIVE!!!!
msmithmmx replied to crazyhorse001's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCongrats..... You are taking that leaking water pump very well
msmithmmx replied to crazyhorse001's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI had the same problem. Take a nice size wood chisel and rubber mallet to the seam along the bell housing and engine along with some PB blaster
msmithmmx replied to crazyhorse001's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRemove the IAC valve and you can get right in there with a regular wratchet. With your free hand put a wratchet on the harmonic balancer, that will keep it steady as you remove them the 4 bolts.
Timing Belt Kit Question
msmithmmx replied to 2000outback's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI used that same type kit for my 2.2 and an Ebay water pump for 16 bucks. 6K miles and no problems. Just use OEM seals
msmithmmx replied to crazyhorse001's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou might not have smeared masking tape but those Brother labels will fall off, what is worse?
Leaking oil filter
msmithmmx replied to roninwva's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow many miles on the old bugger? Did you change or have any service done on the car before this started?
New Subaru owner(90 Legacy)-need help!
msmithmmx replied to jsellers's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwow. did you pay with a credit card? Call them and get your money back I am sure the shop will not part with the money the took from you. Did they give you the old part?
high pressure solenoid circuit fault
msmithmmx replied to bdecriscio's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYours transmission was working before the swap, correct? Now its not. I don't think its electrical. There are lots of threads on this forum warning not to touch the torque converter during the swap.
msmithmmx replied to bdecriscio's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWas it the hi pressure solenoid that was replaced? I am also thinking that when he pulled the engine he may have cocked the torque converter amd now its not sitting right.
1998 is the price to outragous
msmithmmx replied to xr2guy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXInsane, I would drawl the line at 4K. Thats all it would get on Ebay on a lucky day. Have you tried there.
msmithmmx replied to xr2guy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat makes it even worse is they probally stole it off someone for 2,500 bucks. That price is insane. This may be the wrong place to ask for a good price, we are always looking for deals.
Looking at a 91 Legacy
msmithmmx replied to Optimator's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMe to, I needed window molding so I pruchased a whole sub.
Aftermarket Cruise Control???
msmithmmx replied to JT95's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPM'd if you need the parts.
Cruise control
msmithmmx replied to Downbound's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe starter has nothing to do with the cruise control. But the starter is near the cruise control cable, the may have stretched it out. Check to see if anything is loose
