Uberoo
Everything posted by Uberoo
  1. Uberoo replied to Uberoo's topic in Off Road
    I suppose I will just take an impact wrench to the adjusting bolt then..what happens if it breaks?
  2. Bust out the 10 lb hammer.
  3. make sure to tripple bag your weed in the bed panels so cops can't smell it. Same with the space in the Gen 1 steering wheel. I have a wagon put I will probally be making it into a brat.I need something to cover the holes in the cargo area that are normally covered by plastic paneling....the wheels are turning...even if they are in 1st gear lo range(sammmy low not subaru low...)
  4. Uberoo replied to Uberoo's topic in Off Road
    My front settled and now looks like its lower than the rear due to the body lines. although looking at measurements under the skidplade and rear diff its higher than the rear. Is the clearance under the rear diff supposed to be more or less than the front diff?
  5. Uberoo replied to Uberoo's topic in Off Road
    so than use an air gun should get me to 10" under the rear diff?When do I know when to stop? after the back end on the hatch was cranked up what was the clearance under the rear diff before the bigger tires? I am still not sure because I was using a small tire iron and it wouldnt budge. When it is cranked up all the way does the rear end sit level with the front?
  6. Uberoo replied to Uberoo's topic in Off Road
    how do you take pics of your car when out wheeling?
  7. Uberoo replied to Uberoo's topic in Off Road
    I cant turn the rear adjusters up very much than I guess.I cranked it up and gained an inch in the back.With no lift in the back I am at 16.5" from the hub to the top edge of the fender.I dunno but something tells me it should be more. That and I now have 9" under the front skid plate and 8" under the rear diff? doesnt seem right. unless the back end was lower than the front for some reason...I thought that the clearance under the rear diff was normally higher than the front? My springs must be shot look what I found "4wd Station wagon GL: 8.3" with adjustable suspension up to 9.3" so then with a two inch lift it puts me .3" less than what stock should be maxed out WTF. Although a friend does have some 235/75/15 all terrains I can have for free.Now to find some 15" 6lug chevies...
  8. Uberoo replied to Uberoo's topic in Off Road
    got the front in, although the camber on one tire is a bit wierd.i will see if it settles after i drive it around the block. to crank the back up which way do I turn the nut?I am trying to turn it clockwise looking towards the front and it is very hard.I am using a tire iron and I still can barely get it to budge.I suppose I could try a breaker bar as well but this is rediculus. How fast will it eat axles?
  9. Uberoo posted a topic in Off Road
    I am trying to do the two inch tube lift.I can't seem to get the strut down far enough to get both blocks on.This is an EA81 BTW. I was able to get one block on(the one towards the front but the back one I cant even get the block anywhere near the stud in the strut. Am i supposed to undo more of the suspension to get the clearance or what?How am I actually supposed to get the block in?
  10. How much horsepower can a rear LSD either from an EA series car or a legacy hold? I am looking to push about 300-350 HP through an IRS rear diff with a limited slip... if either diff isnt up to the task anyone know of a cheap rear diff for an IRS setup that would work?
  11. Uberoo replied to bigo1966's topic in Off Road
    it could be done but then the door wouldnt latch,because you would have cut the latch out. it could be done if you were willing to cut and reweld the door latch (and fender) to the new location. the edge of the door is at the inner fender edge...
  12. just put a 6" round driving light in the now vacant space and call it good for an offroad rig.Then just find some more argressive tires...
  13. I meant beater as in door beater, or rocker panel beater, or tree beater...Is there a straight panel on that car?
  14. Uberoo replied to Uberoo's topic in Off Road
    http://s109.photobucket.com/albums/n45/Uberoo/Subaru%20stuff/?action=view&current=wiring.jpg across the street is my parents house and where I reside...
  15. Uberoo replied to Uberoo's topic in Off Road
    some night pics with the car off. http://s109.photobucket.com/albums/n45/Uberoo/Subaru%20stuff/?action=view&current=allnight.jpg http://s109.photobucket.com/albums/n45/Uberoo/Subaru%20stuff/?action=view&current=sidenight.jpg in comparison to my last offroad rig: http://s109.photobucket.com/albums/n45/Uberoo/Subaru%20stuff/?action=view&current=4torches.jpg The two lights was all I had around at the time,although I suppose I could get off my a55 and go to my storage shed( 5 blocks away) and pick up a set of lights for a baja bug...Then I would need a bigger fuse,and maybe wire in a relay...right now it just takes power from the battery to a switch then to the lights...and find some black spray paint because the other lights have a chrome housing...chrome on an offroad rig, yuk...
  16. Uberoo replied to Uberoo's topic in Off Road
    the wire goes between the seal and the door around dash level,then it just snakes it way up the gutter.
  17. "you just broke a halfshaft"
  18. sarcasism is so hard to show on the internet...
  19. Uberoo posted a topic in Off Road
    So I just installed two lights on top of the subaru.There is room for more but give it time... They are only 55 watt so there is no point in taking a daytime pic with them on.Its a really freaking bright day... http://s109.photobucket.com/albums/n45/Uberoo/Subaru%20stuff/?action=view&current=lights.jpg http://s109.photobucket.com/albums/n45/Uberoo/Subaru%20stuff/?action=view&current=ears.jpg http://s109.photobucket.com/albums/n45/Uberoo/Subaru%20stuff/?action=view&current=wiring.jpg
  20. Uberoo replied to Uberoo's topic in Off Road
    its true.I couldnt find it in the car.When I got home it was sitting on my desk...
  21. low gears are overrated!!!
  22. so if that Is a two inch lift with 235's how much lift is on your beater wheeler? that brown wagon looks alot taller than your wheeler.
  23. Uberoo replied to Uberoo's topic in Off Road
    how well will a 255/60/15 tire fit under a subaru?
  24. Uberoo replied to Uberoo's topic in Off Road
    yea I know, was kind of a poor showing for suburus. Those tractor tires were just digging to much on the snow to be useful. I wonder if maybe some 26" or 27" all terrains on 14 or 15" wheels might be better. still though it will probally be like a month before I head out again.
