Everything posted by The Beast I Drive
I ran the Beast with a 70's Ford 2bbl carb on an EA82 for a while, which ran awesome, much more power over stock, then I swapped that out for the EA81 in it now, but i kept the EA82 manifold and Ford carb, and I noticed more low end torque and power, but a little less high end power. I have done some pretty crazy angles with the EA81/Ford carb setup too. Right now the throttle plate on the carb is buggered though, so I will be swapping to a Weber i got cheap after I fix some other more important problems on the car.
Hell Yeah! Those hot wheels stickers are the shiznit! How much for a set? +1 on what sizes are available -Bill
EA82 Rear track width into EA81 Q
The Beast I Drive replied to newsoobdude's topic in Subaru Retrofitting
The EA82 rear assembly is about 3 or 4 inches or so wider than an EA71 rear, i swapped an EA82 rear assembly into my '80 Brat, I will be doing the front swap too, and discs all around. I believe Jerry told me the EA81 rear assembly is only 1 inch wider than the EA71 rear end. -Bill -
Ok, so I have seen it 3 times now, it is MINT! Its a black EA81 coupe with gold trim and gold 13 inch Enkie mesh wheels, the torsion bar is cranked up in the rear, and the body looks absolutely beautiful. Ive never gotten really close to it, other than getting passed by it on the road 3 times, up around the YVCC area. If this is a board member's car, pipe up cuz this car is the s**t! -Bill
k&n drop in filter
The Beast I Drive replied to cookie1's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I guess the oil deposit poblem would be for those with the hot wire MAF sensor, not particualarly with the flapper style unit. -
EJ22 1981 Brat Write Up
The Beast I Drive replied to jimbob_goatboy's topic in Historic Subaru Forum: 50's thru 70's
it looks wonderful, I love that brat, its just tooo bad @$$! Im finally gettin my brat built, slowly and intermittently, but its comin along, here's its thread, if youre interested http://www.ultimatesubaru.org/forum/showthread.php?t=85068&highlight=My+Brat -
DUDE! I HAVE DRIVEN THAT THING! IT IS AWESOME!!!!! How's the canopy workin out? -
the gearing in low range isnt quite the same as stock tires in high, running 31's on the highway, I am revving 3500 rpm going 55 in low in 5th gear, where as before I was revving 2750 in high. However, in high range with 31's, in 4th gear going 55mph I am revving at 2750 rpm. Ive had the vehicle up past 70mph, and it will hold 60 well. And Im running an EA81 in an EA82 car. Not so great for hardcore wheelin', but good enough for some fun offroad.
I run 31's, I use low gear 2wd in town, and I shift into 2wd hi on the highway after second gear. And 2 speed reverse kicks @$$.
If you are doing a carbed EA81 in an EA82 car, that is exactly what I did with the Beast. The intake from an EA82 should fit an EA81 fine, I know Jerry in Selah did this on his hatch brat, and I did it on the Beast, but on my motor I had to make spacers cuz the manifold was hitting the block in the middle. On the motor in my Brat though, the EA82 manifold went on with no problems.
Im pretty sure he is talking about alcohol as in like 450 proof everclear type stuff, ethanol is crap, and it will never EVER be able to fuel ANY country.
My dad ran alcohol on his 75 Ford for a few years, he says he had to clean the carb out every couple of weeks cuz sludge would build up inside all the parts.
He's prolly an unofficial spokesman. I also find that hard to believe. Also, with additives, you gotta consider cost effectiveness, as in how much of the stuff do you have to buy and what kind of gains you get. Prolly just bs cuz all it does is clean your system. so if your mileage increases its cuz you got a lot of crud built up in there.
sure, how much you want for em?
You should look into makin a 22r/20r hybrid, a 22r with a slightly modified 20r head, the 20r head flows better and boosts compression.
where did you get those mirrors, and do you have a drivers side one handy? I could use one for my wagon, for when I have the doors off cuz I broke the Brat mirror I had on when I rolled it. Or I could use your old door mirrors
