Everything posted by ()__1337_CRAYOLA__()>
does anyone make front and rear bumpers for brat my old ones are thrashed and id like to get some beefier ones
What distributor?
()__1337_CRAYOLA__()> replied to Rally_Blue's topic in Old Gen.: 80's GL/DL/XT/Loyales...
pretty sure it's hitachi and one way to tell... the cap's are different i believe one is taller than the other. but others would know better -
webbr carb on 1987 gl wagon
()__1337_CRAYOLA__()> replied to glh1975's topic in Old Gen.: 80's GL/DL/XT/Loyales...
check the jets to make sure they are right (other people on the board could tell u better what jets to use) maybe rebuild it if it looks well used and u sould be good that is if they are more expensive then the redline kit -
The 85 turbo wagon
()__1337_CRAYOLA__()> replied to ()__1337_CRAYOLA__()>'s topic in Old Gen.: 80's GL/DL/XT/Loyales...
and let me say the drive home from redmond on 3 cylinders was FUN!!! not.... got home my brother goes switch that injector out for another and bam peeerrrrrs like a cat but the injectors are finiky they'll be fine at one point and missfiring at another time:dead: -
what temp should it run at.... my gauge shows in the red but i can hold onto the hoses and when i shot it with my temp gun the temp wasnt over 200 degree's and my electric fan doesnt come on untill it's at a line below red leading me to believe it is wrong.... new thermostat fan switch and temp sender....
Passed it's last emmissions test it will ever need in washington state :banana: :banana: even after sitting for 5 years... fired it up drove it to the emmissions place and passed with flying colors.... the guy there was amazed because it was running so rough from sitting
i need rims
()__1337_CRAYOLA__()> replied to blindrummer's topic in Old Gen.: 80's GL/DL/XT/Loyales...
depending on whe you live im in washington but i have silver rims with snow tires on with no rust you can buy for 100 btw they are 4 x 140 unless u have wheel adapters -
Sticking Calliper?
()__1337_CRAYOLA__()> replied to Davalos's topic in Old Gen.: 80's GL/DL/XT/Loyales...
maybe your hill holder is out of adjustment i had my loyale do that and it was a bad hill holder -
Stereo install
()__1337_CRAYOLA__()> replied to scooby_down_under's topic in Old Gen.: 80's GL/DL/XT/Loyales...
why buy a adapter.... just cut the harness off the back of the stock radio and there u go an instant adapter that can be unpluged.... find the constent / switched/ ground and the speakers are easy to figure out i used the trial and error way but w/e -
Stereo install
last time i did this... and im not completely sure if you'll have to but i had to run new speaker wire because they share ground other than that find the switch 12v the constent 12v and find a ground and ur golden -
1985 ea82t timming
no info on the under hood ive got it parked so i dont hurt the rebuilt motor -
what should the timming be andwhat connector do i connect and it has vaccum advance... treat this like a carb version and disconnect it? and is half temp for a turbo car to high.. i have a new radiator on the way i was just curious... i have a factory t-stat in it and it just runs at half temp and 3/4 with the ac on... needless to say i dont use the ac
1985 ea82t
got the engine running like a dream.... it had a bad injector that led to it running like S*** tons of power and it actually moves and does the speed limit now
