24
Everything posted by 86BRATMAN
I'm pretty sure the pump mechanism could be flipped over and then it woul make it oump back into the passages correctly.
I should have clarified my statement. I meant with the ej knuckle it would workfine.
Ej18 and EJ20 rods are interchangable, not the pistons though. And you could make a turbo'd ej18. I know of someone on here doing it right now.
I think the only twin pot's that will allow 15's are from the 91-94 turbo legacy, and possibly the outback and early gt's. The rear can be done, either by buying a kit from these guys http://www.crossbredperformance.com Or by extensive modification. But its costly either way for the rear.
If you read carefully on the Crossbred site. You have to send them another set of backing plates as core. And the hubs are special machined parts to still use the ea axle. And yes, the e-brake parts on the legacy do mount to the backing plate. So no loss of ebarke needed.
They will fit the xt-6 just fine. For the loyale you'll have to do the normal 5-lug conversion mods.
You may be able to work with the man selling it. I've pm with him a few times, he seems to be a nice fellow.
'84 brat, troublehooters sharpen your pencils
86BRATMAN replied to DaveAP's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Does the brat have a/c? And does it only light up the lights when the pedal is fully depressed? If so, check for a short on the switch at the gas pedal. -
^^^ Good point...
You'll not hear any arguement from me...
After reading this I thought I'd verify... http://www.cars101.com/subaru/impreza/impreza2003.html Just before half page it lists the WRX final drive as 3.90. It doesn't make mention of the reduction that we all know is there at the rear. And to confuse you more... http://www.cars101.com/subaru/impreza/wrxsti2007.html This page for the 07's says the wrx final drive is 3.0:1 and the STi is front 3.90, center 1.1:1, rear 3.545.
Good to know that Will. This sounds like it should be a good running little beast.
I'd do a little checking about the 03 wrx tranny. Everything I've read ahs said they had a 3.90 front final. And after the 06 year they switched to a 3.70.
Looks like the whipper snappers have the farts out numbered, lol. Thanks for doin that Mick.
