Everything posted by SoobGoob
getting the moisture out of headlights
cam someone please tell me the process of opening my headlights. i know you put them in the oven but i dont know for how long or what temp thanks! SG
Check out this old BRAT workhorse!!!!!
and the lifted purple truck in the backround
Who wants to drop $30k on this baby!
fun summer ride
subaru brat cameo comic
they may be inexpensive cars but thats not why we drive them
News thread has 2nd gen brat in background going through a big puddle
i cannot find it either
Oil smell inside car when running A/C or Heat???
sometimes when HG's go, coolant and oil mix. maybe there in some oil in your coolant running through your heater core. but as far as i know that is contained, just an idea. maybe check heater core hoses?
leaky transmission
problem solved! it was missing a DR LO switch, turns out before they put the LO light switch in the consloe there was one on the transmission itself. must be an 85 thing. there wasnt even casting for the single range lever. so now its holding fluid and shifting smoothly.
leaky transmission
thanks for the advice everyone, i am replacing the shift rod seals today and praying thats my problem. im spending more on trans fluid than gas to get around
leaky transmission
wasnt the output seal. does anyone have any other ideas? its loosing QUARTS at a time but about 1 1/2 quarts do not leak out. all fluid but that leaks out almost instantly. i cant see where its coming from but i know its near the rear somewhere around the output of the transmission and only really leaks when i drive
kerosene
checked around all i saw was other people on sites like these caliming it is kerosene. look around its out there
kerosene
cant remember. vwvortex fourms i belive, ill look into it further and let you know
kerosene
seafoam is kerosene, just a lower qualtiy not as strong
leaky transmission
could it possiably be the rear output? is there a seal in there?
leaky transmission
is there any place in partictular that a 5spd dual range transmission leaks? common? not common? has anyone else had this problem? its leaking pretty bad. just installed it too
EA82 production info
runs like a champ!
Will this fit on a Subaru wagon?
doubt it will fit i had a 90 civic and they didnt work on my wagon.
So I'm gonna buy another subaru....
that to me sounds like the distributer might be going. ticking at idle but going away at a higer rpm. but depends on the ticking
The time has come... bad RX
butternuts
is it the D/r trans? i need one because im going to attempt the 4.11 but just need a rx D/R trans. i have all the othert parts
Its 1986 Again!
i like how that soob is on the left side of the road
2 cool vids
heres a couple more. not very good but very fun to watch ah and look what these turds did to a touring wagon
Pics of where the wagon will spend the winter...
you can also just disconnect the - terminal of the battery and it wont die while being stored as well. IMO a cheap trashwagon ru would be awesome for those winters!
honda accord springs KICK @SS!
will they work on my loyale?
Snow!!!
i think everyone should get some subarus in action in the snow. i know ill be getting some this season
Help. need pinout pictures
i have all the indicatiors hooked up right but 1 its a black wire with white stripes i have no idea what it goes to
