Everything posted by ivantruckman
New 84 sooby owner here
Bucky 92 is Hot... a chick that can weld, thats what im talking about
Holy Stereo Soup Batman
the only other problem is that aftermarket radios are too mlong to fit the dash, they sell adapter kits that extend the opening about 2 1/2 inches. if your shifter is sloppy it may hit the volume button.. i got all my adapters at best buy. but they have to have a mobile eletronics department at the store
want to know the dimensions...
you know scott from bellingham has posted specs for his lift kit. out of the goodness of his heart, should be easy to find in the off road forum, scott rocks
starter motor, auto / manual trans ?
ufortunatly it a rebuilt starter, looks to be just installed. no history on it. every thing else is fine , new interstate 750 cca battery, all conections are perfectly clean. i may just go find a junkyard oem starter. maby the rebuilder rewound it wrong, who knows. another mystery
1994 Loyale, No Spark
i would definitly check the ground on the coil mount, like heartless said a few threads up .and all other grounds. intermittent problems as you describe when it actually failed wile driving. are usally a ground problem, if it were a t belt or other mec. failure it would have just died instantainuosly
i thaught i read somware that subaru had 2 different rpm starter motors, and that an automatic was different from a manual , my automatic trans 4x4 gl seems to crank over slowly, everything is is good working order, amp draw is normal, it cranks the same in 10 degree weather as it does in 40 degree weather, it just seems slower than normal ? could the previous owner hav replaced it with the wrong one ?
Rust repair: You don't have an excuse not to. Now with working photos.
[Q Me with a broken finger, having welded for an hour. I'm trying to flip off those of you that think welding (or owning a welder) is out of your realm. wow you look like mikey from american chopper
Advice on buying an ’85 Subaru GL Sedan
oh i forgot if its a auto 4x4 try to go on a dirt road. wile driving straight tru accelerating in 4 wheel drive from a start, than shift back into 2 wheel drive, you should notice a difference, this is to make sure it shifts in and out of 4 wheel drive, also make sure that it has all the same size tires on it. different size tires are hard on the rear clutch pack of the transmission.. i know im rambling... good luck
An automatic transmission subaru runs at a higher rpm, at 55 mph. (my auto subie runs at 4000 rpm at 55mph) its quite noisy and you can feel more vibration. i also had a catotrosphic transmission falure at just 150,000 miles, I kind of like it for around town use, but its a little uncomfortable for hiway use, i feel as if im pushing it too hard. it is a little slower on excelleration too. i find it to be an excellent city /commuter car, great for traffic james. less work bending the ole knee. i guess it all depends on the price and what you plan on doing with it. even an automatic trans subie is better than no subie
Whats ODD in this picture
i got it , NO rust
Online deals on snow tires????
my set of 175 -70- 13 mastercraft glaciargrip cost me 47 each. they are pricy. if im ever in the norwest, ill have to rent a uhaul just to get all the parts and tires home..lol
Exhaust Studs/Holes, Stripped, Suggestions?
Rock on Hilsdale, ill pm ya when im in the detroit area, well hook up get a beer. (after driving of corse). rock on
temp spare rims offroad?
Oh crap its almost impossiable to find an 80 series tire with any kind of tread, arrrgggg hopless
has anyone ever tryed to use the temp spare 15x5 inch rims to mount some narrow 15 inch tires, i think im crazy for the sugestion. im looking for some tires to fit. out in michigan i use the narrow ist tires for my snow plow truck. they seem to bite down to the road instead of float on top of the snow. hmmmmm
Michigan Meet And Greet
i live on 40 acres ,and live next to 5000 acres of state land . lots of trails, goodd mudd , but no moutains...
dosnt subaru have an extra set of holes in the cyl head . i just cut the flange and rotated it 90 degrees and used the other two holes. unless is been done already. dude hilsdale is just down the street.
BUMP yo me too central michigan, i wanna bruse up some fenders Is anyone still interested in some mudd boggin, camping. maby spring of 08 ??
2wd auto to 5 speed dr conversion
how hard is it to make a 91 loyale 2wd auto into a dr 4x4, i have a 85 with a rusty body, but a good dr and driveline, id like to keep the engine a spfi, can i use the same ecu ? or does it tie into the auto trans .
To Bleed the Brakes 87-GL-10 (scroll down)
yikes LF RF MF, im confused
Oil Seal Installer
to make a removal tool, i took a flat head screwdriver and heated it with a tourch and put it on the edge of an anvil , " 90% edge", and bent the tip at a right angle. it works good
92 Loyale 3AT 4WD won't go into any gear. Lost all gears at cruising speed on highway
- found some 13 inch snow tires
sweet, i just got a set of "mastercraft" "Glacier Grip 2" for my stock loyale. im impressed with the performance in the dirt, it hasnt snowed yet :-\ . i got them from my local independent tire dealer, in 175 70 13. they were only $46 each, with tax just over $200 mounted balanced , has anyone had them in snow yet. they sure look gnarley. i think the tire rack has them too.- better alternator?
i put a 70 amp gm alt on my gl. i can buy a compleat rebuind kit including a stator winding , all bearings reg, diode trio, etc for 25 bucks on ebay, the hatachi diode asy. cost me 30 bucks, plus the gm alt is good for 70 amps, you can buy a kit to convert it to 90 amps. it was a very easy conversion- Alternator gurus.
anyone have a cheaper source for the rectifier- The New Baby Is Home!New Pics added page 4
ivantruckman replied to Bucky92's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX"Here it is!!!!!! OMG Its so Beautiful!!" very beautiful ,and the car is nice too - found some 13 inch snow tires
