				Posts5926
				Days Won5
Everything posted by Caboobaroo
	I used XT6 outer tie rod ends and have just enough movement before they bottom out to get the alignment I wanted.
	  Any Opinions out there on brake parts?Caboobaroo replied to Demon Brat's topic in Historic Subaru Forum: 50's thru 70's Why not upgrade to the vented front EA81 calipers and rotors, then do a rear disc brake swap from an EA82 and install an adjustable proportioning valve and done. She will stop on a dime:headbang:
	I know of a guy that could get it aligned up for you with your swap.
	Funny I should see this thread again. Replaced both front and rear pumps today on a '99 Legacy L. Best way to diagnose if you have a bad pump? Disconnect the plug(s) from the pump(s) and use a test lit or a multimeter to check for continuity. Have a friend operate the pump switches from inside the car as it can make it easier. Once you determine that you have voltage, clean up the connectors and see if it works but more then likely the pump has gone out.
	Ok it sounds like you might have a few issues. First off, the oil leak. Only way to know where it's coming from is to get underneath it up on some jacks to help pinpoint the source. Since its a '99, it probably still has a plastic separator plate on the back of the engine, which should be replaced with the updated steel one. The plastic warps and causes it to leak even after new silicone is applied. Or the head gaskets are leaking badly enough. Or the oil pan, or the oil pump, or or or.... The clutch judder is caused from uneven surfaces, like a warped brake rotor. So when the clutch was replaced, it's possible cheap parts were used which can cause a pretty bad judder. Other possibility is it wasn't broken in properly when it was replaced and it got hot. Without seeing the vehicle and proper diagnosis, this is only my perspective. The check engine light with a cylinder misfire code could be caused by a dropping valve guide. Seems to be pretty common. Other issues could be oil in the spark plug tube, corroded coil pack ends where the plug wires click on and possibly more. Just a few places you could start.
	  Should I try this engine swap?Caboobaroo replied to dancinghobotom's topic in Old Gen.: 80's GL/DL/XT/Loyales... For the most pair it will be a walk in the park. All you'll want is the long block, from valve cover to valve cover and you can do any engine resealing at this point in time. Then just put the intake from the car it's going into along with the power steering alternator and A/C compressor on it and you're done. Always make sure to yard the radiator with the fans out first.
	  washington and emissions testingCaboobaroo replied to ontherun987's topic in Old Gen.: 80's GL/DL/XT/Loyales... Check out the rules for emission testing and ages of vehicles. Vehicles over 25 years old do not need emissions testing in King County.
	  Was there a 1990 Subaru RS (Not RX) in the US?Caboobaroo replied to wtdash's topic in Old Gen.: 80's GL/DL/XT/Loyales... Yes they do exist and yes some of them came with an EA82T. The "Star Edition" I would gather is going to be a dealer specific edition not a FHI edition.
	Ok since you are now talking about swapping in a manual transmission, do that swap first, get it buttoned up and then swap in the EJ. You will need a few things for the manual swap but it's very easy to do. You will need... Manual transmission Clutch kit, flywheel and the flywheel bolts, not the ones for the flex plate (AT cars) as they are shorter then the flywheel bolts Pedal cluster. Easy to remove and install if the steering column is removed as well Driveline as it is longer then the 4eat but is still longer then the 3at I believe Shifters, boot and interior trim if you care Crossmember Clutch cable Speedometer cable as it is different then the autos Gauge cluster, again if you care Only thing you will need to do electrically is put a jumper wire in the 6 pin plug (might be 8) that plugs into the stock auto shifter assembly on the two largest wires that go into it. These are for the neutral safety switch which is located in the shifter assembly. You can also run these two wires to a hidden switch for a "kill" switch if desired.
	  wont idle until warmed upCaboobaroo replied to talk2elk's topic in Old Gen.: 80's GL/DL/XT/Loyales... Have you made sure the coolant temp sensor is still working properly? That's what I would replace first. Also check the connector on the harness for it as they can get corroded and cause the same issue.
	Exactly. You will have to remove the caliper bracket with the rotor at the same time. Then you can attempt to remove the broken bolt with heat. I've removed a couple after I got the bracket out of the car. Just make sure to run a thread chaser through the threads and use some anti-seize when you reinstall.
	Yes they do have drum brakes in the rear so you have to remove the drum to verify. Also, if you have another mode of transportation, you can take your rotors (if they are still thick enough) to a shop or sometimes some parts stores can turn them for you. You can technically pad slap it without having them turned but you will eventually glaze the rotors and your braking performance will become poor with longer stopping distance.
