Everything posted by Caboobaroo
P0441 won't go away.
Caboobaroo replied to 987687's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAccording to Alldata, this is what the code is for. DTC PO441: EVAPORATIVE EMISSION CONTROL SYSTEM INCORRECT PURGE FLOW Look for cracks in the lines or a plugged evaporation line. With it running, take a can of brake clean and spray it around the solenoid and the vacuum lines. Listen for a change in idle even if its the smallest one, while you spray a bit of cleaner. Looking at how the system is setup, it can be a couple things, like the ECU, purge solenoid, SBF-2 or main ignition relay as thats all thats in the electrical circuit.
hesitation on 81 hatch
The adjustment thats on the base directly in the center is the idle mixture screw. The other is the idle adjustment. As far as tuning them, I cannot remember off the top of my head as its been a few years since I've dealt with a Subaru with a Hitachi.
Stuck calipers
Here's what you do. Take the wheel off, crack the bleeder screw and let the pressure out. It'll help taking the caliper off a bit easier if its locked up. As for needing vise grips to "clamp" the line, not always needed. Leave the line hooked up until you replace the caliper (unless you're rebuilding it) and then just unbolt the line and quickly bolt it back onto the new caliper. Another option for capping the line would be to take a rubber plug that'll fit over the hardline where it threads into the rubber brake line that leads to the caliper.
86 3door Runabout:FWD<FT4WD, 4 lug<5lug, EA82 carb<EJ22 or ER27 swap, rust removal
What sucks is I have a rust free 3-door shell that I'm going to be getting rid of here this summer. Miles, do I hear a roadtrip to the NW again?
Radiator leak from cap
Its sounds like the thermostat didn't open yet. Replace thermostat, radiator cap and refill with new coolant, then go drive it for a bit to let it open the thermostat.
PNW Subaru Alignment Specialist!
Hump day bump! This Saturday from 12pm-4pm we are having a huge BBQ and Subaru meet at the shop. Free food and lots of fun including raffles, $25 carwashes by our awesome detail crew and $40 alignments done by yours truely! So hurry in as its a first come, first serve for alignments! The address if you guys want to attend is 12232 NE 116th St, Kirkland, WA 98034. Hope to see some of you then!
2.2T, What Trans????
I have a transmission from a '97 Impreza in my RX behind my EJ22T. I also just have a factory clutch as well, nothing too special. Transmission is a cable clutch style, 3.90 final drive.
RetroRoo
How much for the returned one?
ea81 hitachi carb missing choke pieces
I believe you can use parts from either the Hitachi 2 barrel EA71 carbs or the Hitachi 2 barrel EA81 carbs. Find someone who is doing a Weber swap and buy their old carb from them for parts. Of if you source up a good stock carb for not a lot, swap it on, should be pretty straight forward. Carbs to watch out for are the Carter-Weber single barrel EA81 carb, Hitachi 2 barrel EA81 computer controlled carb and the Hitachi 2 barrel EA82 carbs
85 GL wheel bearing problem, please help!
Ask for a bearing for a '90 Loyale. It'll be the same part but sounds like you might be getting the rear bearing for a 4wd EA81 car. I see you're in Corvallis. Head over to napa on 9th St and ask for Jimmy if he's in. Tell him Russ sent you to him and that he can help you out.
Wanted: Control Arm Measurements
Exactly. I'm going to be making these so that its easier to get axles (IE replacement EJ axles) instead of having to make axles that work. It also gets me back into fabrication so once I have a few other projects finished up, I can start making custom subframes to bolt EJ suspension onto so I can bolt it into an EA82 chassis. I might have to make a trip down there here soon. We're finally getting settled into the new place but I still gotta get the garage squared away, as it looks like poo:rolleyes:
I need some help on getting some control arm measurements for an EA81 and an EA82. Pics would also be great too. I'm fabricating up some custom control arms to do a 5-lug conversion on the front of an '82 Brat and plan on making some control arms for it and possibly more to sell. I need the outside diameter of the bushing housing where it bolts into the crossmember, length of bushing housing, length of control arm from where the bolt runs through the bushing to the center of the ball joint taper (it doesn't have to be exact but fairly close), the width of the largest area on the control arm and the distance from where the strut rod bolts onto the control arm from the center of the bushing. I'd also like some pics if they can be had without much hassle. Once I have one set done, I'll post pics and go over what I'm doing in a new thread.
intermittant SPFI issue
check the coolant temp sensor. It could have an affect on the driveability problem. I had a similar issue when I first put together my GL coupe and after replacing the fuel pump with a new one, I figured out the fuel injector was mostly plugged in. When the engine would warm up after driving for a bit, the connector for the injector would swell and cause it to lose connection. So make sure to double check the connections as well.
RX stuff to EA82 Sedan
I can see what I can do. The car lives down in Tacoma area and I'm further north in Kirkland, about 3 1/2 hours from Oregon City. I'm down in Milwaukie quite a bit myself but its usually in the girlfriend's car, '09 Hyundai Sonata Limited:slobber:
Alignment questions
Yay! Now I get to fill your head with mucho alignment information! In order to check the steering parts before an alignment, jack up the car with the suspension loaded (so a jack under the control arm to "load" the suspension like it would be sitting on the ground). You can now check a lot of stuff. If you put your hands at 12 and 6, you can check the play in the lower ball joints and the wheel bearings. If you put your hands at 3 and 9, you can check side to side play in the tie rods and tie rod ends. If there's any looseness in the bearings, you'll also feel it side to side as well as up and down. If it feels tight, then you can have it aligned. If not, well time to get the parts replaced and then have the alignment done. On an EA82, rear camber and toe can be slightly adjusted but not a lot of places will do it from what I've seen. The front, obviously is just toe since camber and caster aren't technically adjustable. You can loosen parts on the suspension up a little to get some adjustability out of it but thats about it.
Tranny Crossmember Question
I've also driven a Brat that had Jerry's conversion done to it and compared to the 4-speed, its heavenly. I did 75mph at 3k roughly from Portland to Seattle (about 3 hours) with the bed full of furniture and it made it up all the passes without any issues. So when you're ready to do a 5-speed, get in touch with Jerry and he'll hook you up with the good stuff
I'm still in touch with the current owner of at as he came by with a friend to get an alignment on his friend's car. He should be bringing it to me shortly to do some work on it for him, including replacing the rear gold hatch badge that some *&%@* stole off of it:mad:
What Rob says is true except on the sedan, there's no modifications needed to the RX bodykit. They did make the RX sedan with a full bodykit in '87.5 and '88. Bumpers will fit but also what Rob said about the rear plates is true.
92 Loyale "Clunking" on acceleration
They don't know what they're talking about. Worn steering parts can cause the axle to go bad? Never heard about that before. If the tie rods and/or ball joints have movement, it can cause a clunking on accell but should cause a rotational clunk. If the boot is torn on the ball joint and the tie rods have movement, I would replace them soon. Seen too many people with bad steering parts drive away because they'll "fix it later" and then it comes back a couple weeks later with a sheard off ball joint stud or broken tie rod end. For the rotational clunk, also check the brakes. Make sure the rotor isn't warped. A warped rotor can cause the brake pads to clunk around in the bracket, even if you have no brake pulsation. Seen a new rotor out of the box cause a clunking sound like that but no pulsation. Then obviously check the bearings and axles once again.
What's your wrenching experience?
I want to come work with you. We do some hotrod stuff here at my shop but no restos or builds:-\
Is there a pictorial walk-through for this?
Caboobaroo replied to Chefasaurus's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIts like pulling any other RWD automatic transmission except the front axles. You'll have to tap the roll pins out that hold the axles onto the transmission and undo the front struts to get them to pull out far enough to come off the transmission. Then its driveline, cooler lines, wiring harness, shift cable, torque converter bolts (which are accessible through the starter hole so you'll need to remove that), bellhousing bolts and transmission crossmember. There's going to be a few small items you'll realize that need to come off (like the pitch stopper) but its fairly easy to do. I would highly recommend a friend to help get the transmission out and in because the 4EATs are heeeeeeeeaavy!
Build page.
On 3AT cars, its easy to bypass that switch as its located in the shifter. Remove the 6 wire plug (I think its a 6 wire plug) from the shifter, find the biggest black and black/yellow wires, put a jumper between the two and start it up. My silver RX was a 3AT and I jumped it there when I swapped in the RX drivetrain (was a GL coupe) and ran it like that for a few years.
Build page.
Woah slow down there skip. Turbone is one of the guys who had a built EA82T and even his (rebuilt CCR engine) didn't last. I have posted up my information on my build numerous times and since I've realized from your other posts that you DON'T SEARCH, thought I'd give you a recipe for a blown engine, just like all the other EA82Ts that myself and Turbone have had. So unless you are going to search before asking questions that have been clearly covered in the past, stop making new threads. Now, go blow up your EA82T so you can come cry to us about it breaking and how to fix it. I know how to fix it and get more power from it, and thats to replace it with something like my or Turbone's swap.
Build page.
Build from my old '89 RX EA82 SPFI shortblock with factory internals 9.5:1 CR Rebuilt EA82T gen 2 turbo heads with full port and polish and gasket matching Delta Cams 260 street cams '88 XT N/A spider intake with reclocked throttle body and turbo water inlet adapter Nissan 280ZX turbo injectors Rising Rate Fuel Pressure Regulator WRX top mount intercooler Samco intercooler hose set TD04 turbo @12psi @7200 feet above sea level Megan Racing 3" bellmouth downpipe to 3" out the back AEM cold air intake with silicone connectors and K&N Filter Stage 2 kevlar clutch and XT6 flywheel Crawford Air/Oil Seperator Greddy Auto Turbo Timer Greddy Profec 2 B-Spec electronic boost controller I probably had more stuff done to it but once I blew the final engine, I was done with the EA82Ts
Rainy day BUMP!
