Everything posted by abog
93 impreza 193k miles what to look out for?
abog replied to mattri's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis is a very good car, no real issues. Look for the usual higher mileage stuff, wheel bearings, axles, boots, brakes etc. Really all depends on the service history of the car. Get records if you can.
Acceleration rise and fall. I'm new to Subarus. Help!
abog replied to Uncle Don Clark's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPossible throttle position sensor, I would look at that also.
Changing headgaskets 97 outback ltd
abog replied to Digger19's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSubaru 360 is right on. I began working for Subaru dealerships in 1982, I have been a Senior Master technician since 1994. I have done hundreds of head gaskets on all subaru vehicles over the years. All the advice that I give people comes from massive experience with the product. Take from it what you will, but what I have seen in a lot of cases is that people over repair vehicles, either to safegaurd themselves or to give themselves a sense of security in their vehicle. There are many different opinions of how to do a job, as long as the vehicle is repaired they are all ok. My preference is to do what is necessary to repair the problem for the customer, not to add repair work that in my opinion is unnecessary. Oh and by the way, my work has always stood for itself with no comebacks.
Main gasket sealer?
Most of the " miracle " cure stop leak products have a large amount of ether in them. The ether causes the rubber in seals to swell. This swelling will usually reduce leaks, but only for a short time. And when the seals begin to leak again it will be much worse than when you started.
A/C question
abog replied to J A Blazer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSounds to me like your mechanic did not check for leaks the first time, just threw in some refrigerant and sent you on your way.
Wiper Bladess
abog replied to mrtoyou7747's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHey John, maybe they should seal new wipers in a vacuum at the factory to give them a shelf life!!! hahaha, or maybe they could actually use decent rubber to manufacture them.
abog replied to Digger19's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXChanging head gaskets does not raise compression. The bore / stroke and cylinder head cc's are not changed. If the cylinders are low on compression it is due to wear in the bore / rings, or bad valve seal. When a subaru head gasket goes bad on the 2.5, some cylinder pressure is bled off into the water jacket. This loss is slight and generally if the engine has not been severely overheated will not notice any operation difference when resealed. A compression test is a good idea on any engine before a teardown regardless of mileage. If you are not using oil or have a definite power loss , you are probably fine with new gaskets.
Burned valve after new timing belt?
abog replied to dave833's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIsn't 99 an interference motor? Possible that the timing belt broke and it has bent valves?
So, I think I need 2 new temp sensors + speed sensors.
abog replied to kirbykirb's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTemperature readings can fluctuate very rapidly when air pockets pass by the thermosensor, the sensors will not read correctly and can be very erratic when surrounded by air.
just test drove 07 STI.. owners inputed wanted!
abog replied to torxxx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGet a definite price quote from your insurance, better to know than not.
Battery Relocation :)
Go to summit racing, they have a kit that is reasonably priced. Definitely put a master disconnect switch in.
Looking at buying another Outback
abog replied to skibumm's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere is a clutch safety switch, the clutch has to be pressed before the engine will start, it is a safety feature.
abog replied to kirbykirb's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYour temp problem has all the signs of head gaskets, definitely as suggested have a block test done. You can get the exhaust gas test kit from Napa, and it is not very expensive. You should have done the rear main seal when the trans was out of the car.
Cv boot replacement
abog replied to murphsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPersonally, have never had any luck with those, easy to put on but never last very long.
Digital Dash question...
The button to switch from mile to kilometer is in the trip computer.
4EAT "free reving"
abog replied to Gloyale's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThats what I thought it sounded like. Make sure you take a look at the clutch's, more than likely they will be damaged or worn.
Can you adjust hyd. clutch...??
abog replied to vwbuge1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf the clutch has been replaced, they may have had the flywheel machined. If you remove too much material from the surface of the flywheel it will affect the pedal travel. You can adjust this, but not very much. Clutch should start to engage about 1/2 way , with about an inch or so of freeplay. Have also run into some aftermarket clutch sets that do this as well.
tips for removing hub/gear
abog replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf I remember correctly the gear comes off the shaft after the shaft is removed from the trans. The mesh of the gear that drives the gear you are trying to remove, keeps it from sliding out.
'95 Legacy - engine dies + electrical weirdness
abog replied to SeanC's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAlternator, output should be 14.2 to 14.5 1500 rpm with no load, about a volt to a volt and a half lower with all accessories on. Definitely check all of your grounds. It also never hurts to disconnect and check all of your connectors for loose or corroded contacts.
Converter Chatter
abog replied to fleming442's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXtypically a converter will chatter at the high rpm point just before the trans shifts up. Vibrations can come from anywhere in the driveline.
4EAT "free reving"
abog replied to Gloyale's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTest your line pressure, bet it's low. Clutch's aren't getting enough pressure to lock under load. If there has been any amount of slippage, the trans is done. Time for a rebuild.
O2 sensor, one wire or two?
abog replied to vwbuge1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHave seen many non OEM cats, they seem to work ok. Hard to beat the quality of the Subaru parts. But hard to swallow the price
Anti-Afterburning Valve
If I remember correctly, you can disable an air suction valve by removing the cover and flipping the reed over, then reassemble. we used to do this so that the valve was still there for the emissions inspector.
Hard Start
abog replied to Sundance's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHave you replaced the fuel filter lately? Poor fuel flow can cause this as can bad gas.
Trany Fluid Options
abog replied to Sundance's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJust for info, the campaign on the 90 Legacy's was to add an inline filter because the radiators have a screen in them that was determined to be to fine, and clogged very easily. This screen was blamed for many premature trans failures. So the fix was to backflush the screen and install the inline filter before the fluid entered the radiator. Back in the day I recall doing hundreds of these.
